Marantz AV8801 Preamp/Processor Official Owner's thread - Page 396 - AVS Forum
post #11851 of 11872 Old 07-14-2014, 04:05 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 349 Post(s)
Liked: 1317
Originally Posted by kbarnes701 View Post
Does Marantz work the same way as Denon? if so....
a)6. Is it possible to save and recall an Audyssey MultEQ calibration?
Speaking of which, that post needs to be edited to remove the "CI" qualification as Denon no longer makes CI models.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - AVSForum sponsor for 15 years
Mon - Fri: 8am – 8pm EST (Sat/Sun, leave message)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is offline
post #11852 of 11872 Old 07-14-2014, 09:32 PM
Just add water and stir
zuluwalker's Avatar
Quoted: 18 Post(s)
Liked: 461
Tonight I finally found information for my amp, would someone please be able to help me with this?
My issue is a slight buzz at a very low level, only noticeable to me because my room noise floor is 30db, and I wish to stop it.
I am using balanced cables from the AV8801 to my amp, here are it's specs below. I recall someone using something to adjust the signal cable signal?? I tried to search for it, but gave up after the flood of crap the search spit back at me.
Thanks fellas!
Power Supply:
600 VA toroidal power transformer.
90,000 uF of storage capacitance.
Input sensitivity (for rated power; 8 Ohm load):
1.100 V
Gain:
32 dB
Input Connections:
Unbalanced (Tiffany style, audiophile quality, gold plated RCA); one per channel.
Balanced (XLR); one per channel.
Each input may be independently switched to either unbalanced or balanced.
Input Impedance:
23.5 kohms (unbalanced).
33 kohms (balanced).
zuluwalker is offline
post #11853 of 11872 Old 07-15-2014, 11:23 AM
beastaudio's Avatar
Quoted: 188 Post(s)
Liked: 543
a gain that high with higher sensitivity speakers is likely to buzz. This is why emotiva moved from 32 dB gain to 29dB gain in their second generation models.
(European models do not accept banana plugs.)
"If you done it, it ain't bragging." ~ Walt Whitman
AE TD12x SEOS12 Build
Beast's DIY Master Measurement Thread
DIY Emminence Coaxial Surround Thread
beastaudio is offline
post #11854 of 11872 Old 07-16-2014, 03:07 PM
pwong888's Avatar
Are you using xlr connection to your power amp?
You can use "line level attenuator" to see if there is help to reduce the buzz.
pwong888 is offline
post #11855 of 11872 Old 07-16-2014, 04:10 PM
discodol's Avatar
Liked: 26
Originally Posted by silverlight View Post
Thanks for the help, still trying to fix. I brought up the cable modem and tried connecting directly to the receiver but still no good. I then put back cable modem in it's place in the basement. There is an Apple Extreme base, and the receiver connects with a couple network bridges in between. It's worked in the past, so something seems to be different now. It's after hard rebooting (cutting power vs standby), and re-initiating the connection loop, it's connected a couple of times and partially completed the downloads (main downloaded, dsp 1, is on "sub" now), but haven't had any luck connecting in hours after probably 40-50 attempts. resetted all routers and couple bridges in the system and rebooted the AV a bunch of times. Fingers crossed I can get it to finish. Just trying to avoid the full setup again with a factory reset...
I had the same issue when I first got my 8801. My installer carried my 8801 next door to the neighbor who had a different brand modem/router and it connected right away.
I ended up having to put my Comcast Wireless Modem/Router in "bridge mode" and install my own wireless router.
Then finally I ended up having to get rid of the Comcast Wireless Modem/Router and just get their latest Docsis 3 Modem and another wireless router for the 8801 to connect consistently.
David Ferebee
discodol is offline
post #11856 of 11872 Old 07-16-2014, 06:29 PM
silverlight's Avatar
I ultimately solved it by analyzing the IP addresses on the system. I was stuck in the upgrade loop so couldn't access the setup config of the 8801. Using LanScan Pro on the Mac, observed it's IP address, and could see it was using a fixed assigned IP address, however this address was in conflict with one of the Apple Extreme routers acting as the bridge for our upstairs ethernet nodes. So I changed the DHCP setting of the Extreme to a fixed non-conflicting IP address and the update completed quickly, problem solved. We have quite a few devices and a 3-4 Apple routers in the setup (cable modem -> router -> several bridges, including a ethernet over coax to get the cable from basement to 2nd floor, so plenty of room for network issues). I also temporarily setup a "default host" (apple equivalent to a DMZ) on the IP the Marantz was set to which I think was important in getting the update to work, and then turned it off for security reasons after the update completed. Hope that helps others trying to solve this issue as well
markrubin likes this.
AV stuff here
silverlight is offline
post #11857 of 11872 Old 07-18-2014, 10:21 PM
Kaorin's Avatar
Sorry if this is a dumb question, but is there any way we could add Atmos to an 8801 via some kind of outboard processing? So for example if Oppo releases a new player with Atmos processing and analogue outputs, would it be possible to wire the signal back into the 8801? So the 8801 processes the 7.1 signal and the Oppo would process the additional x.x.4 Or have the Oppo decode the whole signal and pipe the 7.1.4 signal to the 8801 in analogue.
I seem to remember there's only 7.1 analogue inputs on the 8801, is there any way to feed the other 4 channels into it?
Any thoughts? Sorry if my rambling is unclear.
Kaorin is offline
post #11858 of 11872 Old 07-18-2014, 10:32 PM
Franin's Avatar
Quoted: 57 Post(s)
Liked: 176
Actually I thought they could of at least updated via firmware and change the wides for the rear heights. I personally believe it could be done but it ain't going to happen regardless.
Franin is offline
post #11859 of 11872 Old 07-19-2014, 04:15 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 349 Post(s)
Liked: 1317
No as the 8801 would require 11.2 EXT IN inputs for the Atmos ceiling channels and only has 7.1 as you noted.
post #11860 of 11872 Old 07-19-2014, 07:54 AM
zuluwalker's Avatar
Quoted: 18 Post(s)
Liked: 461
I have heard that, but no experience with the brand. Thanks for the tip though.
I am using XLR. Is there a great level of difference in the quality of "line level attenuators"?
Thanks for the reply.
post #11861 of 11872 Old 07-19-2014, 08:11 AM
coli's Avatar
Quoted: 16 Post(s)
del
coli is offline
post #11862 of 11872 Old 07-19-2014, 11:47 AM
MagnoliaMOE's Avatar
I have a quick question. If I copy the flat curve to the graphic equalizer will the subwoofer settings from audyssey be lost? Sorry if this question has been asked before.
MagMo
Elite 70" (PRO70X5FD), Oppo BDP-105, Marantz AV-8801, Marantz MM-7055, PS4, PS3 (Fatty SACD), MartinLogan Theos, MartinLogan Stage, MartinLogan Montage, MartinLogan Descent-i
MagnoliaMOE is offline
post #11863 of 11872 Old 07-19-2014, 09:26 PM
DRC3's Avatar
Liked: 0
Pioneer elite sc-57 to Marantz 8801
Just switched from elite sc-57 to 8801. Elite was no slouch. I have 4 seaton sm's for bass and wasn't lacking in depth and sound stage, but needed a receiver for powering great room 5.2. Decided to move sc-57 to great room and get the 8801 for theater room. 8801 is amazing with emotiva amps. Love it's ease of use and setup. xt32 is amazing. Like both, and definitely not disappointed in the move.
DRC3 is offline
post #11864 of 11872 Old 07-19-2014, 10:32 PM
Roger Dressler's Avatar
Quoted: 122 Post(s)
Liked: 164
Have you done some tests?
1) Disconnect the speakers. If buzz remains, it is mechanical (transformer/chassis).
2) Disconnect the inputs. If buzz continues, it is generated in the amp. If buzz goes away, not the amp, not the gain.
We can continue based on what you find.
Roger Dressler is online now
post #11865 of 11872 Old 07-20-2014, 12:46 PM
zuluwalker's Avatar
Quoted: 18 Post(s)
Liked: 461
Thank you.
I really enjoy my AV8801, so this is a small nuisance. I am going to conduct more tests later today, though I believe I have already done this a while ago? Hell, I can't remember what I had for lunch yesterday.
post #11866 of 11872 Old 07-20-2014, 03:38 PM
Bryan Jozwiak's Avatar
Has anyone had issues with clipping on the AV8801?
I played IronMan at reference level and had clipping in the beginning scenes of the movie.
I had Dynamic EQ on so changing the reference offset seemed to help this. I then watched a DTS movie last night at about -6db with Dynamic EQ reference offset of 5db. I again had some clipping. Seems like I dont have much headroom with this processor.
I used to use a Anthem AVM30 and playing movies at these levels never resulted in clipping. I could push it further without any issues. This makes me think it is the processor that is clipping and not my AMP or speakers.
Any similar experiences?
-- Bryan
Bryan Jozwiak is offline
post #11867 of 11872 Old 07-20-2014, 04:09 PM
matthewa's Avatar
Liked: 26
Is it like you loose fragments of sound? I get this on Jack Reacher when he slams it into reverse to get out of the motel it momentarily looses sound
matthewa is offline
post #11868 of 11872 Old 07-20-2014, 04:12 PM
It usually sounds like a loud "CRACK" or "SNAP".
-- Bryan
post #11869 of 11872 Old 07-21-2014, 08:05 AM
Selden Ball's Avatar
Quoted: 38 Post(s)
Liked: 323
I'm not sure what you mean by "subwoofer settings". The crossover frequency settings won't change. However, enabling the graphic equalizer disables Audyssey room correction entirely.
Selden
Selden Ball is offline
post #11870 of 11872 Old 07-21-2014, 06:48 PM
mdrums's Avatar
Liked: 26
I replaced a Integra DHC80.3 and am really liking my Marantz AV8801. I was going to splurge a get a McIntosh MX151 but backed off due to the $12k price and was about to pull the trigger on the McIntosh MX121...until my local store said I should really get the Marantz for slightly less. They have played with all 3 of these pre/pros and said yes the $12k MX151 would sound a little better but the Marantz 8801 would be as nice or even better than the MX121.
They said with technology changing so fast to not waste money on high end processors unless you have money to burn. They saw I was seriously stretching to get the McIntosh....to go with my McIntosh amps....but didn't really see the need for me. cool!
Mikes Stuff
McIntosh MC207 Amps.........................DarbyVision Darblet
Marantz AV8801 Processor.................Da-Lite Screen
Klipsch Reference Series 7.2................Panasonic BluRay BDT500
Epson Pro 6010 Projector.....................Sony Playstation used for SACD and BluRay
mdrums is offline
post #11871 of 11872 Old 07-21-2014, 08:07 PM
DRC3's Avatar
Liked: 0
Mdrums- Totally agree on technology changing quickly, especially with Atmos coming out. The 8801 seems to be the best of the affordable pre/pros right now. $12k is some serious jack. Enjoy!
DRC3 is offline
post #11872 of 11872 Old 07-21-2014, 10:57 PM
Thanks for the reply. I wanted to know if audyssey settings for the sub would still be available if I used the graphic eq. I verified with omnimic after I posted the question that indeed the audyssey settings for sub are not in play.
MagMo
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
