Marantz AV8801 Preamp/Processor Official Owner's thread - Page 398 - AVS Forum | Home Theater Discussions And Reviews
 279Likes
post #11911 of 13418 Old 08-09-2014, 09:10 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 8763 Post(s)
Liked: 3974
Originally Posted by dlynch34 View Post
I have tried to do that but it doesn't seem to keep the new settings
The settings stored under Audyssey Setup will remain unchanged, while the settings under Manual Setup will be the "active" settings based on any changes you have made (eg. Subwoofer Volume).
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is online now
post #11912 of 13418 Old 08-09-2014, 10:37 AM
Waboman's Avatar
Quoted: 3866 Post(s)
Liked: 7582
Are people really boosting their subs by 3db? That seems a bit hot to me. I'm assuming Dynamic EQ is turned off? Audyssey set my subs at -9db and -9.5db. At first it seemed soft. But put in a movie with a good mix, i.e. Transformers 3, and the bass was rocking. It just blended so well.
Waboman is online now
post #11913 of 13418 Old 08-09-2014, 11:08 AM
audiofan1's Avatar
Quoted: 1377 Post(s)
Liked: 1354
I just added a second sub yesterday and after getting both dialed in i checked the speaker levels with an DTS setup disc and had to add 5 db to both subs for 75db , Audyssey DEQ was off of course and this was after it set both very close to the same values as yours 9.5 and 9.0.
audiofan1 is online now
post #11914 of 13418 Old 08-09-2014, 11:15 AM
Roger Dressler's Avatar
Quoted: 1447 Post(s)
Liked: 659
Originally Posted by RichB View Post
There are rumored enhancements that may be supplied in future versions of Atmos.
What sort of enhancements are rumored?
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #11915 of 13418 Old 08-09-2014, 04:08 PM
Oppo Beta Group
RichB's Avatar
Quoted: 597 Post(s)
Liked: 396
I am not sure, perhaps actual speaker position processing. FilmMixer dropped hints about Atmos first release and advancements that might be coming down the line.
- Rich
Oppo BDP-105D | Oppo HA-1 | Emotiva XMC-1 | Oppo PM-1 | ATI AT6002 + AT4006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15
RichB is offline
post #11916 of 13418 Old 08-09-2014, 06:52 PM
dlynch34's Avatar
Quoted: 132 Post(s)
Liked: 58
are you running this with audyssey deq off?...mine is presently on I believe...
Don
Anthem AVM 60, Emotiva XPA-1l x4,Emotiva MPS-2. SVS PC12 Plus, Magnapan 3.7i, Magnepan CC5,Magnepan MC1,Epson 6030UB, SI Zero Edge Slate 110.
dlynch34 is online now
post #11917 of 13418 Old 08-10-2014, 01:33 AM
audiofan1's Avatar
Liked: 1354
Off ! as it will add a 3-5 db boost of its on. I did use it when running my single depending on mood and playback level with an offset of 5 and sometimes 10 for television material, I really haven't gotten around to trying it since the second sub addition.
post #11918 of 13418 Old 08-10-2014, 10:01 AM
jdlynch's Avatar
Quoted: 95 Post(s)
Liked: 38
AirPlay
Last night I finally got around to running a cat5e cable to my 8801 so that I could perform the software update, and, connect to my network.
I am trying to learn how to use AirPlay so that my son can stream music from his iphone5 through the 8801.
Do I need a wireless adapter to use AirPlay, or, does it stream through the network?
David Lynch Current Equipment: Marantz AV8801, Proceed HPA3, Parasound HCA-1206, Aerial Acoustics LR5's (LCR), Aerial Acoustics LR3's (sides), RBH in-walls (rears), Seaton Submersive, Marantz VP15s1, 106" Carada BW screen, Oppo BDP-103.
jdlynch is online now
post #11919 of 13418 Old 08-10-2014, 10:38 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3974
Streams through the network once the Airplay icon is selected in iTunes on the iPhone.
post #11920 of 13418 Old 08-10-2014, 12:52 PM
jdlynch's Avatar
Quoted: 95 Post(s)
Liked: 38
Thanks JD.
I finally got it to work; I was having an issue getting my sons iPhone to find the Marantz in our network. Turns out it was a router issue.
post #11921 of 13418 Old 08-10-2014, 05:13 PM
admranger's Avatar
Quoted: 13 Post(s)
Ok, my limited searching skills failed me again...
I would like to stream high resolution (192/24) FLAC files from a NAS to my 8801. I am looking at a Synology 412+ and a WD My Cloud EX4, but I'm not hard over on either. I really want to be able to control the music from an iPad or similar device, essentially running something that mimics iTunes controller (without using iTunes and their limit of 44.1/16 unless you use the toslink out from the macbook).
I don't intend to stream video.
I would use this NAS for the aforementioned streaming, as well as a backup for my 2 windows based laptops and my one macbook.
If someone could point me to a good solution or thread, I'd appreciate it.
Marantz 8801 Arcam P1000 Oppo 95 SystemDek IIX turntable ATC SCM 19 V2's (L&R) B&W LCR6 (center and heights) B&W in ceiling surround speakers Velodyne SPL-10 Subs (2) Sony xbr65x850a
admranger is offline
post #11922 of 13418 Old 08-11-2014, 04:32 AM
AVS Club Gold
bobpaule's Avatar
Liked: 33
Originally Posted by Dave Vaughn View Post
Quote:Originally Posted by Mad Norseman
Dave, how do you have them 'triggered'?
Do they come on and off with the equipment?, or are they thermostat controlled?
(And they don't look too bad - recessed back a ways like they are...).
Temperature controlled with one of these: http://www.coolerguys.com/840556093695.html
All told, I bought 4 fans and the controller for about $150 or so, but I'm only using three right now. I plan on adding the fourth to the right side of the unit to move additional cold air through the back of the unit, but I need to pull all the equipment out in order to cut a hole for air movement.
As a longterm Onkyo/Integra man and survivor of 2 HDMI board fryouts, I use 120mm fans resting flat on silicone feet pulling air out of the processor, off cell phone charger hooked Panamax M7500 Pro's switched outlet actuated by a 12v trigger from the processor.
My AV8801 arrives Friday replacing the PR-SC5509, finally the spell is broken. In addition to bringing nothing like HDAM to the analog end, Onkyo also messed up by opting to delete the 7.1 inputs on the PR-SC5530. No Audyssey for me either, the correctly toed in and placed speakers with a treated room will do. I only use sub where it is natively recorded on the source, i prefer as close to one step as possible D/A conversions and leave the rest to the analog stage complimented by a CP700 in processor bypass mode, and the superb Signature S8s matched system. I have used my last 3 processors with and w/o calibration, and I noticed that once I moved to the higher end of mid-fi the equalization did more harm, rendering the auditioning sterile so to speak, especially with the uncompressed music.
Question, which part of the top plate runs hottest on the AV8801? I am planning on putting one single fan on top directly over the hottest area.
bobpaule is offline
post #11923 of 13418 Old 08-11-2014, 05:02 AM
Oppo Beta Group
RichB's Avatar
Quoted: 597 Post(s)
Liked: 396
Good plan.
Center back gets hottest.
- Rich
Dave Vaughn likes this.
RichB is offline
post #11924 of 13418 Old 08-11-2014, 06:15 AM
AVS Club Gold
bobpaule's Avatar
Liked: 33
Good plan.
- Rich
Thanks! That's where the fan will pull then.
bobpaule is offline
post #11925 of 13418 Old 08-11-2014, 06:48 AM
Oppo Beta Group
RichB's Avatar
Quoted: 597 Post(s)
Liked: 396
You won't have any trouble finding the right spot
- Rich
RichB is offline
post #11926 of 13418 Old 08-12-2014, 01:48 PM
Point Source
beastaudio's Avatar
Quoted: 2807 Post(s)
Liked: 2237
I am tagging you over in the new NC/SC thread I started that will hopefully take off and people can come to and meet other avs'ers in the Carolina areas Come join in! I just started it today....
dlynch34 likes this.
beastaudio is online now
post #11927 of 13418 Old 08-15-2014, 05:40 PM
coli's Avatar
Quoted: 203 Post(s)
Liked: 42
The AV8801 doesn't support Dolby Volume?
coli is offline
post #11928 of 13418 Old 08-15-2014, 11:10 PM
Chopsus's Avatar
Location: Arse End of the World: http://en.wikipedia.org/wiki/Warrnambool
Originally Posted by Hawkstar View Post
Hello Everyone,
2.  I recently updated to the latest firmware and since then my speakers are now popping whenever the AV8801 turns On/Off or mutes/un-mutes.  It never did that before.  Is anyone else experiencing this?
I have just bought and installed an 8801 and it is doing the same thing.
Does anyone recall or know a solution/reason?
On setup Audessey required me to reverse all the speaker interconnects because they were out of phase ... They were not with the Integra 80.3 however ... I'm wondering if this is some sort of XLR pin reversal issue?
Chopsus is offline
post #11929 of 13418 Old 08-17-2014, 05:35 AM
Selden Ball's Avatar
Quoted: 2258 Post(s)
Liked: 1087
Onkyo (Integra) intentionally stopped reporting "out of phase" errors several equipment generations ago just because of the large number of false positives. Sometimes incorrect "out of phase" errors are caused by reflections from nearby surfaces, so you might check for that. Otherwise, just select the "skip" option.
Selden
Selden Ball is online now
post #11930 of 13418 Old 08-17-2014, 06:20 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3974
Correct. D&M dropped Dolby Volume starting with 2011 models, the last models to have it being the Denon 4311CI and A100.
post #11931 of 13418 Old 08-17-2014, 06:26 AM
Chopsus's Avatar
Thanks guys ... My real problem is the speaker pops and I thought the reversed XLR pins might be a clue?
As per my quote of Hawkstar:
Chopsus is offline
post #11932 of 13418 Old 08-17-2014, 08:37 PM
coli's Avatar
Quoted: 203 Post(s)
Liked: 42
Correct. D&M dropped Dolby Volume starting with 2011 models.
Doh, this might be a deal breaker. I only recently discovered Dolby Volume, it blows DynamicEQ + Dynamic Volume away so completely I couldn't believe it...
coli is offline
post #11933 of 13418 Old 08-19-2014, 12:22 PM
jacovn's Avatar
Quoted: 127 Post(s)
The 2 sub outputs, is there bass managment which makes it possible to have sub in front and back, and send lf below xover from front speakers to front sub, and from rear/side to back sub ?
Or is this more a Y cable with seperate volume control of both subs (when using 2 different ones for example)
jacovn is offline
post #11934 of 13418 Old 08-19-2014, 12:26 PM
Liked: 1087
Audyssey SubEQ calculates independent distance and sound level settings for the two different subwoofer outputs, but then sends the same audio to both (just as happens during a movie) to determine their combined in-room frequency responses.
erhurd likes this.
Selden
post #11935 of 13418 Old 08-19-2014, 01:41 PM
erhurd's Avatar
Location: Buckeye, Arizona (Phoenix); USA; Planet Earth
Quoted: 44 Post(s)
Liked: 42
Okay, Seldon: lets take this a bit further. What if I were running a front and rear sub using the sub outputs and decided that two pair of subs would be of benefit to my room response (of course, depending upon placement). So I insert Y-cable splitters on each of the subs and run connecting cables to each of the additional (new) subs. How would I predict how Audyssey SubEQ would manage that situation?
Edwin R. Hurd
AVS Forums Lurker-In-Training!
My Tight-space A/V Setup
erhurd is offline
post #11936 of 13418 Old 08-19-2014, 01:49 PM
Liked: 1087
If the two subs plugged into a given sub output are the same model and both are at the same distance from the main listening position, then things will calibrate reasonably well. If that's not the case (i.e. if they're "randomly" positioned in the room with each at an "ideal" location), then you need a more sophisticated EQing method than Audyssey can provide on its own. As I recall, there have been long discussions about this in the REW thread.
erhurd likes this.
Selden
post #11937 of 13418 Old 08-19-2014, 01:54 PM
sdurani's Avatar
Quoted: 3736 Post(s)
Liked: 2285
As far as Audyssey is concerned, you still have 2 subs: one in the front and one in the back. You might know that each "sub" is two physical units, but Audyssey doesn't know that (nor does it need to know in order to work effectively). Audyssey isn't EQing each individual subwoofer, it is EQing the interaction between all your subs, no matter how many you have.
kbarnes701 and erhurd like this.
Sanjay
sdurani is online now
post #11938 of 13418 Old 08-19-2014, 02:21 PM
erhurd's Avatar
Quoted: 44 Post(s)
Liked: 42
i had a feeling that would be the response to me question… makes sense.
Edwin R. Hurd
erhurd is offline
post #11939 of 13418 Old 08-19-2014, 02:28 PM
erhurd's Avatar
Quoted: 44 Post(s)
Liked: 42
Thanks for the reply, Selden. I actually just added a matching third sub to me setup about a month ago (and currently looking for a fourth matching sub). Placements are determined by "ideal" positioning.
Thanks for directing my attention to the REW thread, and, my apology for veering off-topic.
Edwin R. Hurd
erhurd is offline
post #11940 of 13418 Old 08-19-2014, 03:17 PM
sdurani's Avatar
Liked: 2285
It basically means: don't worry. When listening to your system, you're always hearing the combined output of all your subs. So whether you have 4 subs or 40 subs, it makes sense for Audyssey to measure the combined output of all your subs. Whatever peaks & dips Audyssey finds in the combined response, it will try to EQ away in order to give you smoother bass. That means never needing to be concerned with how many physical subwoofers you have.
Sanjay
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
taboola here
