Marantz AV8801 Preamp/Processor Official Owner's thread - Page 399 - AVS Forum | Home Theater Discussions And Reviews
 293Likes
post #11941 of 13529 Old 08-20-2014, 10:57 AM
neverwouldof's Avatar
Liked: 0
I just bought AV 8801 and MM8077 Amp. Question is how can I Bi-amp my Von Schweikert VR4-Jr Front speakers?
I thought I would plug in to the SL and SR outputs on amp and change settings in the processor, don't see an option.
Keith
neverwouldof is offline
post #11942 of 13529 Old 08-20-2014, 10:57 AM
Liked: 0
Keith
post #11943 of 13529 Old 08-20-2014, 11:13 AM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
I also have VR-4Jr's and AV8801, unfortunately there is no option to set it up in the bi-amp mode.
Just use the RCA y-cable to drive 2 amps from a single Right or Left output. This setup sounds the best when driving Gemstone amp.
I wasn't getting good results with XLR y-cable setup, perhaps due to strange input impedance loading of my amps.
The Jr's sound much better when bi-amped.
- Alex
AlxG is offline
post #11944 of 13529 Old 08-20-2014, 11:22 AM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
I forgot to mention, be carefully with your amp when bi-amping the lower section of your VR-4Jr. Your amp may not like driving 2.3 ohms load across the bass section.
- Alex
AlxG is offline
post #11945 of 13529 Old 08-20-2014, 01:43 PM
Liked: 0
Could you explain that further? Lovely I spent the money to get XLR cables across the board.... So if I use RCA Y's to the amps channels 1&2 of 7 , the higher and lower section of speakers are different ohm loads?
Should I sell the amp and get some Parasound A21's, I really can't believe you can't bi-amp a $3000 AV Receiver
post #11946 of 13529 Old 08-20-2014, 01:49 PM
Selden Ball's Avatar
Quoted: 3356 Post(s)
Liked: 1637
The AV8801 is not a receiver: it's a preamp/processor. Since it doesn't include internal amps, it doesn't need to include internal biamp features that receivers have to include. Whether or not you bi-amp is determined by how you connect it to the external amps that you have to add to it anyhow.
Selden
Selden Ball is offline
post #11947 of 13529 Old 08-20-2014, 10:06 PM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
Yo got it, you can use either XLR or RCA y-splitter to route AV8801 left output and feed channel 1&2 of your amp, then route right output and feed channel 3&4 of your amp. Try both configurations to determine which one sounds best to you. In my case, I wasn't able to find an XLR y-splitter that sounded to to me. So I ended-up not-bi-amping my speakers (just bi-wiring) because my amp sounds the best through the XLR path.
Based on my measurements, the impedance of mids/highs VR-4Jr enclosure varies from 4 to 8 ohms across various frequency ranges.
The bass enclosure varies from 2.3 ohms from 60 to 120Hz and closer to 3~4 ohms at other frequencies.
I'm not sure if the Parasound amp can drive 2.3ohms loads for a long period of time at very loud levels without frying it. It will get HOT.
My amp is a Simaudio Aurora replica, so it easily drives my speakers via XLR or RCA when bi-amped.
- Alex
AlxG is offline
post #11948 of 13529 Old 08-21-2014, 06:49 AM
CIH USER
Franin's Avatar
Quoted: 2355 Post(s)
Liked: 1451
Originally Posted by joerod View Post
I have mine which is about a month old if anyone is looking.
MARANTZ AV 8801 like new
Sticker is still on it!
Upgrading to the 8803 Joe?
_________________________
Franin is offline
post #11949 of 13529 Old 08-21-2014, 07:06 AM
joerod's Avatar
Quoted: 704 Post(s)
Liked: 633
Possibly eventually. First is the 7009 and Onkyo 3030 Reviews.
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is online now
post #11950 of 13529 Old 08-21-2014, 07:17 AM
CIH USER
Franin's Avatar
Liked: 1451
If I remember correctly you also have a Mcintosh ?
Franin is offline
post #11951 of 13529 Old 08-21-2014, 07:38 AM
Waboman's Avatar
Quoted: 4874 Post(s)
Liked: 11301
So we're skipping right over the 8802? I'll wait for the 8809.
Waboman is online now
post #11952 of 13529 Old 08-21-2014, 09:35 AM
CIH USER
Franin's Avatar
Liked: 1451
Lol good pick up
Franin is offline
post #11953 of 13529 Old 08-21-2014, 09:45 PM
admranger's Avatar
Quoted: 14 Post(s)
The 8901 will be so much better.
Marantz 8801 Marantz 7055 Merrill Thor Monobolcks Oppo 95 SystemDek IIX turntable ATC SCM 19 V2's (L&R) B&W LCR6 (center and heights) B&W in ceiling surround speakers Velodyne SPL-10 Subs (2) Sony xbr65x850a
admranger is offline
post #11954 of 13529 Old 08-22-2014, 05:26 AM
CIH USER
Franin's Avatar
Liked: 1451
I'm looking forward to that one. That has hdmi 9.0B.
Franin is offline
post #11955 of 13529 Old 08-22-2014, 05:42 AM
jdsmoothie's Avatar
Quoted: 14339 Post(s)
Liked: 6768
jdsmoothie is offline
post #11956 of 13529 Old 08-22-2014, 06:40 AM
CIH USER
Franin's Avatar
Liked: 1451
Yup ... and 16k video as well.
Im there
Franin is offline
post #11957 of 13529 Old 08-23-2014, 12:42 PM
bdp2008's Avatar
Liked: 0
I recently bought the AV8801, but I am having a strange issue. The subwoofer is not active on certain inputs and I can't figure out why. Specifically, and most importantly, it's not active when using the two channel balanced inputs. When that input is selected, all of the subwoofer settings are grayed out and inaccessible. How do I make the sub active for all inputs? Thanks.
bdp2008 is offline
post #11958 of 13529 Old 08-23-2014, 12:51 PM
Dave Vaughn's Avatar
Quoted: 1041 Post(s)
Liked: 1512
Dig through the setup menu...there's an option in there somewhere, but I don't remember where. I had the exact same issue a while back. I turned it off accidentally using D-remote.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is offline
post #11959 of 13529 Old 08-23-2014, 02:33 PM
Chopsus's Avatar
Location: Arse End of the World: http://en.wikipedia.org/wiki/Warrnambool
Try pressing and holding the Music Mode on the remote, then select Stereo.
It sounds as though One of the Direct Modes has been selected on that (and other) input(s) which by design can't include the LFE channel if it's not there (ie in stereo media).
Chopsus is offline
post #11960 of 13529 Old 08-23-2014, 06:03 PM
dlynch34's Avatar
Quoted: 308 Post(s)
Liked: 132
Has anyone experienced an issue with their Marantz that it doesn't seem to output video? I get sound but no video. I have changed outputs from main 1 to main 2. Nothing. I bypassed the receiver then I get video...Anyone have any suggestions?
Don
Anthem AVM-60,Sunfire Cinema Grand Signature Five-Channel Power Amplifier, Emotiva XPA-1l x2,Outlaw 5000. Rhythmik DIY 15inch x2, Plus, Magnapan 3.7i, Magnepan CC5,Magnepan MC1,JVC RS400, DIY 125" 2:35 Elite Screen cinegray 3d .
dlynch34 is offline
post #11961 of 13529 Old 08-23-2014, 06:32 PM
JaremyP's Avatar
Quoted: 463 Post(s)
Liked: 260
At a fairly close price point, would you take an AV8801 or an AV7702?
Consider that you may not end up running Atmos for a good long while and that a new unit is needed eventually anyway for HDCP 2.2.
JaremyP is online now
post #11962 of 13529 Old 08-23-2014, 08:05 PM
Chopsus's Avatar
Try
Settings>Video>HDMI Setup>Video Output
Either set it to the connected display (as per the back panel) or set it to dual and it should output to either when turned on.
If you are swapping cables while on you may have confused it, or worse, blown the HDMI card as the voltage in the cable itself is known to short on hot plugging - so be careful and switch it all off when fiddling.
Chopsus is offline
post #11963 of 13529 Old 08-24-2014, 04:04 AM
Liked: 1637
I'd get the 7702 because it includes Audyssey MultEQ XT32. The 7701 has only Audyssey MultEQ XT. XT32 provides substantially better room EQ than XT does.
Selden
post #11964 of 13529 Old 08-24-2014, 06:51 AM
dlynch34's Avatar
Quoted: 308 Post(s)
Liked: 132
still no go on video on my unit... it seems to have lost all video including the menu osd. Wondering since I have had it over a year if Marantz will address it or not... Does anyone know of any hard reset I can do? I left it unplugged all night with no success.
Don
dlynch34 is offline
post #11965 of 13529 Old 08-24-2014, 07:10 AM
Chopsus's Avatar
It sounds like the HDMI board is fried ... Marantz have. Two year warranty (worldwide I think) so it should be covered.
I hope this is not another Onkyo/Integra HDMI like debarkle, as I just bought an 8801 to replace an Integra 80.3 with a shot HDMI board.
Chopsus is offline
post #11966 of 13529 Old 08-24-2014, 07:32 AM
jdsmoothie's Avatar
Liked: 6768
First try powering off and disconnecting ALL devices for at least 10 minutes. Then reconnect and power on the TV, wait 4-5 seconds, power on the 8801, wait 4-5 seconds, power on the source device. Sometimes it just takes a bit longer for a secure HDMI handshake. If no joy, then you can do a microprocessor reset (p. 186 Owner's manual) and if still no joy, the 8801 has a 3 year warranty if purchased from an authorized dealer so call Marantz tomorrow.
post #11967 of 13529 Old 08-24-2014, 10:16 AM
bobpaule's Avatar
Quoted: 42 Post(s)
Liked: 52
AV8801 in da house. Former PR-SC5509 owner.
Smaller, OMG 1/3 the depth of the Onkyo.
Looks good, such a beautiful sight to see it and the UD9004 in the rack.
Setup a breeze, only moment of doubt came when I was looking to assign the 7.1 analog inputs, it would have been nice to have it on the Inputs weegee board. Kudos to Marantz for that one single page, what a breeze. Finding a decent printable diagram of the rear to mark my inputs for Harmony programming a whole another story.
All speakers LARGE, no LFE, no EQ/Audyssey. Treated room with fiberglass panel to insulate a small ship and Paradigm S8 and matched 7.1.
The sound stage albeit filtered at the front by the CP700 in proc. bypass mode is wide and detailed, YES detail like never before, I had listened to Quadrophrenia BD-A at least 3 times this past 2 weeks, let me reassure you that the difference is clear, and comes in the most subtle details, some surprising, such as the musicians breathing at times. Can't comment on stereo as I have a balanced stage bypassing the processor entirely.
The biggest surprise was when I went downstairs for my AM workout, the only time I listen to compressed music in my home, put on the Roku M2000, but now there is a whole new level of quality differentiation among the 8-10 stations I saved as top quality, resulting in no workout but comparative listening (NSTEMI later?), Traxx.fm Dance/Trance the ultimate winner. The night before Mr. Nobody on Netflix sounded very detailed, picture obviously good in bypass mode on a PS3/HC5/110" setup.
Very satisfied to say the least.
audiofan1 likes this.
bobpaule is offline
post #11968 of 13529 Old 08-25-2014, 07:59 AM
dlynch34's Avatar
Quoted: 308 Post(s)
Liked: 132
anyone else have to deal with Marantz for service? So far no luck with their tech support or service center. One tells me to talk to the other etc... this is very frustrating. The service center is telling me if I have had it for over a year it is not under warranty...ugh...
Don
dlynch34 is offline
post #11969 of 13529 Old 08-25-2014, 08:34 AM
Liked: 1637
You might try contacting whoever you bought it from to get the correct problem reporting procedures. As JD mentioned above, the 8801 has a 3 year warranty if you bought it from an authorized reseller.
FWIW, the one time I reported a problem with one of my pieces of Marantz equipment (not an 8801), I described the problem in an email that I sent to the address in the manual, and they told me to ship it to the repair center. That email from them was all that was needed to get it fixed. I had purchased it from a local brick-and-mortar store, though, and they took care of the shipping for me, offering a loaner while it was out. That's one of the reasons I do business with them, although their prices are not the lowest.
Selden
post #11970 of 13529 Old 08-26-2014, 01:59 AM
jdsmoothie's Avatar
Liked: 6768
If you purchased a "refurbished" unit then yes, there is only a 1 year warranty; however, if purchased with a credit card, many card issuers will add an extra year and if that is the case, you can likely get it repaired via the credit card issuer.
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
