Marantz AV8801 Preamp/Processor Official Owner's thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 293Likes
post #91 of 13529 Old 10-17-2012, 01:45 PM - Thread Starter
exm
exm's Avatar
Quoted: 136 Post(s)
Liked: 83
Originally Posted by Selden Ball View Post
As best I can determine, the "warm" sound of Marantz is a myth and/or a placebo effect. (Although I'll admit that I thought I heard a very subtle effect when I replaced my Pioneer receiver by a Marantz pre/pro & amp about a decade ago.) The bench tests that I've seen show Marantz equipment to provide as flat and accurate an output as any other quality equipment. See, for example, http://www.hometheaterhifi.com/processors/processors-reviews/marantz-av7005-processor/page-5-the-marantz-av7005-ssp-on-the-bench.html and http://www.hometheaterhifi.com/receivers/receivers-reviews/marantz-av8003-and-mm8003/page-5-the-marantz-av8003-a-v-processor-and-mm8003-power-amplifier-on-the-bench.html
I can tell you this... I've owned:
Marantz AV600 to Lexicon DC1/MC1/MC12 to Onkyo Pro 885 to Marantz AV7005
The step-up from the AV600 to the Lexicon was huge. The switch from the Lexicon to the Onkyo extremely disappointing, and from the Onkyo to the Marantz huge again. In fact, I had my Lexicon hooked up the AV7005 using the 7.1 analog in and I decided to sell my Lexicon after I switch to the Marantz. Does the Marantz sound "warm"? I don't know if that's the right term but it sound a heck of a lot better than the Onkyo 885
exm is offline
post #92 of 13529 Old 10-17-2012, 05:15 PM
judge25's Avatar
One of the differences I believe between Denon and Marantz is that Marantz have their own designed HDAM's in their units, which should change the audio output.
judge25 is offline
post #93 of 13529 Old 10-17-2012, 08:55 PM
Woof Woof's Avatar
Quoted: 224 Post(s)
Liked: 118
Elsewhere I've been reading that the Marantz is not true balanced. If it is based off the 4520, there might be some truth in that.
Has there been confirmation otherwise?
Woof Woof is offline
post #94 of 13529 Old 10-17-2012, 10:45 PM
audiofan1's Avatar
Quoted: 1738 Post(s)
Liked: 1788
Most gear at this price level isn't, non the less I for one hear a difference when using balanced.
audiofan1 is online now
post #95 of 13529 Old 10-17-2012, 11:09 PM
Woof Woof's Avatar
Quoted: 224 Post(s)
Liked: 118
I have an 8m run to my centre speaker that's single ended and there's a noticeable hum when the AC is on.
post #96 of 13529 Old 10-17-2012, 11:31 PM
audiofan1's Avatar
Liked: 1788
From what I know, which is little on the complexities of the subject, I believe the grounding benifts of a balanced connection help with noise, which wither fully balanced or not, issues such as hum ( I've been there) are sometimes cured! at present I have a mix of both RCA/XLR and have test both using the same cables and I personally feel with all the components in a rack with the various power supplies and such, its bound to be a noise factory unto itself. So is it just a placebo lower noise floor ? who Knows! but I now choose balanced when the option is available.
post #97 of 13529 Old 10-18-2012, 01:01 AM
gurkey's Avatar
Quoted: 240 Post(s)
Liked: 140
Balanced connections come from the studio and performance environment, where long cable runs where needed to interconnect equipment. It uses a differential signal, which allows to compensate for hum and other noise introduced alongside the connection.
It usually does not have any audible advantage in a home environment, although some believe otherwise...
gurkey is offline
post #98 of 13529 Old 10-18-2012, 01:16 AM
Woof Woof's Avatar
Quoted: 224 Post(s)
Liked: 118
I also have the same lengths x 4 for my 2 subs and front L/R power amps which are XLR and these are dead quiet.
post #99 of 13529 Old 10-18-2012, 10:58 AM
apesma's Avatar
Another competitor would be the Sherbourn 7030 if they ever release it. It's already 4 month behind schedule.
apesma is offline
post #100 of 13529 Old 10-18-2012, 11:32 AM
Selden Ball's Avatar
Quoted: 3356 Post(s)
Liked: 1637
Unfortunately, your comment is very ambiguous.
Do you mean there is 8 meters between your pre/pro and the amp that drives the center speaker, or do you mean that you have self-powered speakers with RCA cables running to them?
Since line-level signals are much more sensitive to noise pickup than speaker-level signals, external amps should be as close as possible to a pre/pro in order to minimize the length of the RCA cables. Cables carrying speaker-level signals can be much longer.
By AC, do you mean Air Conditioner or Alternating Current power?
In other words, do you hear noise only when an air-conditioner turns on or do you hear it immediately when you turn on your hifi equipment?
Do you have all of your equipment connected to the same power outlet, or to different power outlets in the wall?
Connecting them all to a power strip which is plugged into a single wall outlet minimizes ground-loop hum.
You should also make sure that any other electrical equipment (like air conditioners and refrigerators) are connected to a different phase of your incoming power. (In the U.S, most houses are served by two different phases of the three power phases coming from the power company. I don't know what's done in other countries.)
Selden
Selden Ball is online now
post #101 of 13529 Old 10-18-2012, 11:34 AM
ssabripo's Avatar
Quoted: 67 Post(s)
Liked: 38
Hey MARANTZ:
ssabripo is offline
post #102 of 13529 Old 10-18-2012, 11:40 AM
Geronimo.USMC's Avatar
Quoted: 146 Post(s)
Liked: 91
Originally Posted by ssabripo View Post
Hey MARANTZ:
LMAO +1
Between this processor and The Galaxy Note 2, Ouch!
SOUND: 7.2 via Marantz AV8802A | Wyred4Sound monoblocks + Halo A51 | Paradigm 100'sV5, ADP590'sV5, 690v5, 20v5's | Dual SVS SB16-ULTRA Subs
VIDEO:
SONY OLED 65A1E | OPPO UDP-203 and SONY UBP X800 UHD Blu Ray Players
- 40TB of Blu ray .iso's in a Synology DS1815+ controlled by a Dune Solo 4K
- HTPC/Gaming Rig:
Silverstone CW02B, Core i7-5820K, ASUS X99-A, 16GB, EVGA GeForce GTX 1080 SC GAMING ACX 3.0, Auzen HDMI XFi
Geronimo.USMC is online now
post #103 of 13529 Old 10-18-2012, 01:59 PM
erwinfrombelgium's Avatar
Quoted: 438 Post(s)
Liked: 237
Originally Posted by Bill Mac View Post
So if the 8801 is a 4520 without amps why would it sound any different? What internal components (DACs, analog stage etc.) would the 8801 have to provide better SQ than the 4520? I would say the 4520 and the 8801 would have a very similar feature set. So I'm not sure what you mean inregard to the 4520 being about features and the 8801 being about SQ.
Bill
1/ I wrote "aimed" towards more SQ. That's the whole bloody point of separates. May we please wait until the thing is actually avalable before the flaming bursts out.
2/ I did not write that the 4520 was all about features (hence not about SQ as you clearly imply) but that 4520 and 8801 are (probably) the same as far as features go.
I know I am not a native english speaker, but I thought I was clear enough.
Building a 9.3.4 HT: DIYSG Titan LX [LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX custom [TF+TR] • LLT Mal-x 18" subs [2] • XPR-5 • MM8003 [8ch] • XMC-1 [RMC-1 wanted] • PT AT6000E • 130" Seymour Center XD • Oppo 103EU • WTB: 1 extra Mal-x 18" SW
erwinfrombelgium is offline
post #104 of 13529 Old 10-18-2012, 02:04 PM
Quoted: 438 Post(s)
Liked: 237
Ofcourse it's not truly balanced. It only has balanced stereo input and balanced 11.2 outputs.
If I am not mistaken, the Denon AVP is truly balanced. Someone correct me if am wrong.
post #105 of 13529 Old 10-18-2012, 03:23 PM
Bill Mac's Avatar
Quoted: 1494 Post(s)
Liked: 1729
No flames here just responding to your post with questions in a respectful way. Any insight into how Marantz will "aim" to get better SQ than the 4520? By that I mean better internal components as I asked earlier. I feel your english is fine and I understood your post that I quoted quite well.
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #106 of 13529 Old 10-18-2012, 05:01 PM - Thread Starter
exm
exm's Avatar
Quoted: 136 Post(s)
Liked: 83
I highly doubt the Denon AVP is truly balanced
exm is offline
post #107 of 13529 Old 10-18-2012, 06:58 PM
Quoted: 146 Post(s)
Liked: 91
I believe the AVP-A1HD is truly balanced when pairing it with the amp they sell that complements it. The
POA-A1HD.
VIDEO:
- HTPC/Gaming Rig:
post #108 of 13529 Old 10-18-2012, 07:49 PM
Woof Woof's Avatar
Quoted: 224 Post(s)
Liked: 118
My main gear are all behind the sofa and I run 8m interconnects to the power amps in front, placed near the front LCR and subwoofers.
Only the C interconnect is RCA. Everything else is via XLR using my sub integrator and the front preamp (HT bypass).
post #109 of 13529 Old 10-19-2012, 01:27 AM
mikejedi123's Avatar
Quoted: 72 Post(s)
Liked: 63
This looks like a cool unit.. always was looking at the AV8003... which i think is now way outdated,, for the money this looks like a good deal.. I love my Yamaha RX-z7 as a pre-amp with my Parasound amps.. but i am pretty sure the AV8801 will outperform it.. ok i gotta start saving my chips... but I am trying to have children now too.. well my birthday is in June.. smile.gif I am sure the price will be lower in a another year .. hopefully! smile.gif
mikejedi123 is offline
post #110 of 13529 Old 10-19-2012, 03:20 AM
Woof Woof's Avatar
Quoted: 224 Post(s)
Liked: 118
Same power line running off a Sound Application conditioner.
So the only difference is just the interconnects. Even the amps were similar. And the hum came when the air conditioner was on.
post #111 of 13529 Old 10-19-2012, 09:54 AM
Kevin C Brown's Avatar
Liked: 27
4520 vs 8801: I always wonder about this stuff. I am a prime candidate for the 8801. I have the AV7005 now, and it's been trouble free and great sounding since I got it maybe 14 months ago.
I would not be surprised if the components in the 4520 and 8801 are identical. But ... could the 8801 spec higher quality parts? IOW, better matching between resistors, caps, op amps, etc, between the channels? A picture of the insides would not tell you that.
But it is true that typically displacing the amps of an AVR from the electronics portion of the SSP can improve sound quality. Additionally, you could run the amp(s) from an analog AC plug on a power conditioner vs a digital AC receptacle for the SSP. Can't do that with an AVR.
So I was thinking of a funny way to say this: I already have separate amplification, so why would I pay less for an AVR with amplification that I already have? biggrin.gif
I had an A100 (4311) here for XT32. But try as I might, I couldn't open the box. So I sent it back. I want an SSP, not an AVR.
Plus, me myself, and I: I don't plan on paying anywhere list price for the 8801. $2500 is my number.
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ... Something old and something new :-)
Kevin C Brown is offline
post #112 of 13529 Old 10-19-2012, 10:15 AM
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 181
Different DAC’s and power supply. XLR’s are 3 things different between them
Life is enjoyable with good quality
Dr_Mark is offline
post #113 of 13529 Old 10-19-2012, 10:56 AM
Liked: 1637
Getting hum from the air conditioner means that noise is being introduced into the audio system somewhere: either in the power line or in the audio interconnects. Since you have a power line conditioner, and only the center channel is affected, this suggests the noise is due to radio-frequency interference in the center channel's RCA interconnect. The RFI noise spikes generated by components within the air conditioner might be radiated directly by those components or they might be radiated by the air conditioner's power line due to that noise getting into it.
In order of difficulty, some options that I can think of are
1. Move the center channel's amplifier as close to the preamp as possible, so you can use a 2 meter or shorter RCA cable and an 8 meter speaker cable
2. If your air conditioner has a short cable which plugs into the wall nearby, get an appropriate power line conditioner so noise can't get from the air conditioner into the long power run to its circuit box.
3. use XLR instead of RCA interconnects (which might require replacing the preamp and/or the amp before the 8801 is available) or
4. rewire the air conditioner so its power line does not come anywhere near any audio cables.
Selden
post #114 of 13529 Old 10-19-2012, 11:13 AM
Quoted: 146 Post(s)
Liked: 91
I have 4311 & It is great on movies, but harsh sounding on music only. I believe this unit will alleviate that. I'm with you on $2500
VIDEO:
- HTPC/Gaming Rig:
post #115 of 13529 Old 10-19-2012, 11:23 AM
Woof Woof's Avatar
Quoted: 224 Post(s)
Liked: 118
which is my point in the first place.
post #116 of 13529 Old 10-19-2012, 12:26 PM
Bill Mac's Avatar
Liked: 1729
Do you have specific information showing the DACs and the power supplies used in both the 8801 and the 4520?
Bill
post #117 of 13529 Old 10-19-2012, 12:41 PM
wse
wse's Avatar
Quoted: 2200 Post(s)
Liked: 805
Originally Posted by Simple SU View Post
I can't tell you how and where I got this but here's a picture of the back panel of the new AV-8801. I'm sure everyone will enjoy this. This thing is going to be a BEAST!!!!!!!!!!
Cool 11.1 Balanced hopefully it is fully differentially balanced (http://en.wikipedia.org/wiki/Balanced_audio). If only they could offer it in Silver in the US. This should be fully loaded let's hope!
I know that AVP-A1HDCI was supposed to be fully balanced? Cost of Marantz is $3000 I wonder how it will compare to Denon AVP-A1HDCI $7,500
I have the SSP-800, wished it could do 11.2 but it only has 9.1 still I am not sure it is worth changing for now smile.gif Maybe when DTS MDA and Dolby Atmos are incorporated then I will consider it smile.gif 2014 most likely
wse is offline
post #118 of 13529 Old 10-19-2012, 02:12 PM
audiho's Avatar
The 8801 isn't worth $3,000.
audiho is offline
post #119 of 13529 Old 10-19-2012, 02:14 PM - Thread Starter
exm
exm's Avatar
Quoted: 136 Post(s)
Liked: 83
How do you know? We don't even know the full/all specs. To me, based on what I know now, this sounds like a great deal especially comparing the 8801 to $5k+ units
exm is offline
post #120 of 13529 Old 10-19-2012, 02:19 PM
Liked: 27
Bill
Well, the power supply has to be different ... because you don't need power for the power amps in the 8801.
But I bet the DACs are the same.
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
