Marantz AV8801 Preamp/Processor Official Owner's thread - Page 409 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
post #12241 of 13500 Old 11-05-2014, 06:42 PM
DrMichael's Avatar
Quoted: 75 Post(s)
Liked: 40
I have a pressing question for anyone who can help. I know this is off topic for this forum but do not know where else to post it. I have been having a lot of 30 second power outages in our area and want to make sure my gear is protected. I currently have a Furman Elite 20 pfi and want to know of that's enough or should I get something more or different? My conditioner does not have a battery backup and I don't know how important that is. Any help would be greatly appreciated. Thanks
LG OLED 65 E6
Marantz AV8802a / Rotel RMB - 1585
Martin Logan Motion 50XT Center
Martin Logan Motion 60XT Fronts / 40 Rears
SVS PB13-Ultra (2)
Oppo UDP-203/Furman ELITE-20 PF /Playstation 4/ Apple TV/Nintendo Switch
DrMichael is offline
post #12242 of 13500 Old 11-05-2014, 09:11 PM
retate's Avatar
Quoted: 40 Post(s)
Liked: 44
Voltage transients are often a factor with 30 second power outages, however, the Furman should be able to handle anything that is dangerous. That is assuming that all of your AV equipment is connected via the Furman including power amps and video equipment. If any of your equipment is not connected via the Furman, then review what you have to protect that equipment from spikes. In terms of battery backup there are two considerations. The first is capacity. The Furman is capable of 16 to 20 amps output. Battery backup with capacity for more than a few amps gets large and very expensive. The second consideration on battery backup units is whether they claim to output a sine wave. The lower cost units typically have an output that only somewhat resembles a sine wave. Whether the battery backup output wave form is a concern in regards to audio and video quality depends on the design of the unit as to whether it has any impact on the output wave form when not in backup mode.
In your situation if you do not have some type of whole house suppression (typically a suppression device that is attached to the breaker box or mounted in the breaker box), that would be the area I would address first as it would give you protection for all of your electronics and appliances. The whole house surge suppression devices that I am familiar with mostly cost $100 or less. However, if you are not familiar with doing electrical work, hiring an electrician to do the install will add to that cost.
Bob
retate is offline
post #12243 of 13500 Old 11-06-2014, 04:53 AM
avman09's Avatar
Originally Posted by RichB View Post
... by limiting airflow and keeping them nice and toasty .
I predict the copper plate goes the way of the network hub
- Rich
I'll welcome that if they use that real estate to put back a couple of coax and optical outputs while keeping the analog media player RCA outputs. That apparently won't happen.
avman09 is offline
post #12244 of 13500 Old 11-06-2014, 07:05 AM
DrMichael's Avatar
Quoted: 75 Post(s)
Liked: 40
Thank you for the great info!
LG OLED 65 E6
SVS PB13-Ultra (2)
post #12245 of 13500 Old 11-07-2014, 08:15 AM
joeycalda's Avatar
Quoted: 49 Post(s)
Has anyone else found the dialog enhancer a good feature? I noticed I like it quite a bit better on medium than off. Sounds like you are getting more info, what does it actually do?
Is this a feature in all SSP preamps?
Joey
joeycalda is offline
post #12246 of 13500 Old 11-07-2014, 08:16 AM
joeycalda's Avatar
Quoted: 49 Post(s)
Joey
post #12247 of 13500 Old 11-07-2014, 08:26 AM
jdsmoothie's Avatar
Quoted: 12255 Post(s)
Liked: 5583
The Dialog Enhancer setting boosts the "voice frequencies" rather than boosting the entire center channel volume as is the case on the lower models. This feature is also on the Denon 4520CI, X5200W and likely on the new soon to be released flagship models, X7200W and AV8802 as well.
jdsmoothie is offline
post #12248 of 13500 Old 11-07-2014, 09:02 AM
BVLDARI's Avatar
Liked: 27
Joey
I think I use it and I like it at lower volumes.
BVLDARI is offline
post #12249 of 13500 Old 11-08-2014, 09:43 PM
Audiguy3's Avatar
Quoted: 123 Post(s)
Liked: 68
Joey
I have found that it is useful sometimes when a center channel is not positioned correctly - too many reflections from surrounding items or being positioned too low or high. The thing to remember is that it can affect music but usually I find I don't listen to much surround music
Reggie
Family Room:75" 4K HDR Sony 940D/Marantz AV8802A/MM8077/GoldenEar:Triton Ones (superseding Triton 2s),/SuperCenter XXL center channel/ SuperSat 60surrounds/Oppo BDP-105/Directv C61K/Roku 4K
Basement: 70" Sharp Elite/Marantz AV8801/Marantz MM8003/PSB Stratus Gold Front,Center,Left, Surrounds/ Directv Genie HR-54/Roku 4K
Audiguy3 is offline
post #12250 of 13500 Old 11-11-2014, 03:20 AM
anoutsos's Avatar
Quoted: 37 Post(s)
Is there a way to bypass all video processing on the AV8801? I have an Oppo BDP-93 connected to the Marantz via HDMI (using the Marvell chipset) and I would like to benefit from the superior picture processing of the Oppo, without any additional processing.
Also, I have read in some forums that the best way to connect the Oppo is to use an HDMI connection directly to the TV and send the audio via the other (inferior) HDMI output on the Oppo. Apart from this being slightly inconvenient, as the Oppo is far from the TV, so I would need another 5m HDMI cable, I am worried about audio/video sync problems. Is it not the same to turn all the Marantz video processing off?
Finally, does my TV (Panasonic TX-P65VT30) do additional processing of the signal? Is there normally an option for disabling that? I currently use aspect ratio "16:9" but I've heard that the true picture can only be viewed in "Just Scan" mode.
anoutsos is offline
post #12251 of 13500 Old 11-11-2014, 03:21 AM
anoutsos's Avatar
Quoted: 37 Post(s)
anoutsos is offline
post #12252 of 13500 Old 11-11-2014, 05:49 AM
jdsmoothie's Avatar
Liked: 5583
Set the "i/p Scaler" setting on the 8801 to OFF. Setting "Video Conversion" to OFF will disable GUI overlay on source video so not recommended unless necessary.
post #12253 of 13500 Old 11-11-2014, 06:48 AM
anoutsos's Avatar
Quoted: 37 Post(s)
Thanks. So, keeping the "Video Conversion" ON does not add extra video processing, it just overlays the GUI? To be honest, most of the time I find the overlaid GUI difficult to work with, especially when the displayed source is bright. So, if that is the only thing that "Video Conversion" does, I may want to disable it anyway. Or am I missing something?
anoutsos is offline
post #12254 of 13500 Old 11-11-2014, 07:01 AM
jdsmoothie's Avatar
Liked: 5583
If the GUI overlay isn't used and only using HDMI sources, disable that as well. Whether a direct Oppo --> TV connection provides a better picture, only you can decide.
post #12255 of 13500 Old 11-11-2014, 08:59 AM
Quoted: 1395 Post(s)
Liked: 589
Well my fronts are large, side surrounds are small, but that shouldn't make a difference anyways as the LFE should go to the subs regardless.
Joey
You'd think that would work that way but unfortunately, when sound tracks are mastered they often put the LFE in with the bass signal and expect you to seperate it with your crossovers and send it to the subwoofer.
At one time, I was trying to figure out a way to use highly accurate subs for bass redirection and a different type of sub for the LFE signal. It would have worked if the industry would be consistant about sending the LFE signal only to the subwoofer and keep the bass redirects out of the xx.1 channel.
JimP is offline
post #12256 of 13500 Old 11-11-2014, 10:48 AM
Audiguy3's Avatar
Quoted: 123 Post(s)
Liked: 68
Right and it will pass the video on without processing.
Reggie
Audiguy3 is offline
post #12257 of 13500 Old 11-13-2014, 05:33 AM
buckley44's Avatar
Quoted: 56 Post(s)
Liked: 33
So if you have a 4k projector, we would be better off leaving the Marantz set to off
and let the Projector do the processing? I'm speaking about the Sony VW600 4K Projector
buckley44 is offline
post #12258 of 13500 Old 11-17-2014, 10:42 AM
Audiguy3's Avatar
Quoted: 123 Post(s)
Liked: 68
Set it to pass through
Reggie
Audiguy3 is offline
post #12259 of 13500 Old 11-17-2014, 02:37 PM
discodol's Avatar
Quoted: 22 Post(s)
Liked: 34
I'm sorry but if you are talking about HDMI Pass through according to page 128 in the manual Pass Through set to ON passes the selected HDMI input through the AV pre tuner's HDMI output when the AV pre tuner is in standby mode. OFF No HDMI signals are passed through the AV pre tuner's HDMI output in standby mode. This setting has nothing to do with whether or not the Marantz or the Oppo is processing the video signal.
If you are talking about video conversion page 129 describes the possible HDMI output settings. If you want the Oppo to do all the processing I would set Video Mode to Auto, Video Conversion to Off, i/p Scaler to Off, Resolution to Auto, Progressive Mode to Auto.
buckley44 likes this.
David Ferebee
discodol is offline
post #12260 of 13500 Old 11-19-2014, 09:14 AM
turnne1's Avatar
Quoted: 1755 Post(s)
Liked: 410
Looking at the possibility of buying an 8801
Onkyo is going to replace my 5508 pre/pro with a 5509...under warranty
I am contemplating selling the 5509 when I get it and buying a Marantz 8801
In looking at what I think the value proposition is of the two 5509/8801
if anyone knows where I might be able to buy a new unit from an authorized dealer for $1800.00 ish...or less
please send me a PM with that information
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is offline
post #12261 of 13500 Old 11-19-2014, 09:34 AM
Oppo Beta Group
RichB's Avatar
Quoted: 881 Post(s)
Liked: 577
Warren
Check out the AV7702 thread. There are AVS folks like Mike and jdsmoothie that can get you pricing:
The **OFFICIAL** Marantz AV7702 Pre/Pro
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
post #12262 of 13500 Old 11-22-2014, 04:25 PM
etc6849's Avatar
Quoted: 168 Post(s)
Liked: 124
This type of pricing wasn't possible last year when I bought mine. I still don't think it is since I've seen used units sell for more... Maybe once it's discontinued if you wait?
Warren
Premise, a FREE home automation program. Open-source Z-Wave Premise Module found here.
etc6849 is offline
post #12263 of 13500 Old 11-22-2014, 05:22 PM
turnne1's Avatar
Liked: 410
I am not sure where you have looked at sales of used units
I have seen a couple in the last 30 days on Ebay for $1500 ish from an individual....dealers seem to get about $100-125 more
Net to the seller after paypal/ebay fees and shipping is probably $1350 individual and $1450 dealer
IMO...when the 8802 hits the shelves the market value of the 8801 will probably take another 20% dive
that's typically the way it seems to work with the Asian electronics in my experience
Warren
turnne1 is offline
post #12264 of 13500 Old 11-22-2014, 05:35 PM
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
I got rid of my 5508 for a 8801 also. I had numerous Onkyos over the years, while they were great, I had two that acted up and had to be serviced.
I love the Marantz. Also, Im not sure where you would find a brand new 8801 for that cheap.
nezff is offline
post #12265 of 13500 Old 11-22-2014, 06:37 PM
turnne1's Avatar
Liked: 410
I will let you know when/if I find one that cheap
I actually looked at the Yamaha Cx-a5000 ...it was available for that price from a dealer in the Baltimore area while they had inventory
Yamaha seems to be the most reliable brand from all they I see and have experienced...but the price I found is no longer available when that dealer sold their existing inventory
So...quite honestly...I am taking a little dip in reliability and looking at the Marantz
I personally have had mixed reliability issues with both Onkyo and D&M products...with both companies replacing units under warranty programs
Warren
turnne1 is offline
post #12266 of 13500 Old 11-22-2014, 06:41 PM
bweissman's Avatar
Quoted: 224 Post(s)
Liked: 88
Why is the 7702 $1000 cheaper than the 8801?
bweissman is offline
post #12267 of 13500 Old 11-22-2014, 07:20 PM
turnne1's Avatar
Liked: 410
D&M profit margin
Warren
turnne1 is offline
post #12268 of 13500 Old 11-23-2014, 07:13 AM
Selden Ball's Avatar
Quoted: 3108 Post(s)
Liked: 1517
D&M profit margin
Warren
For example: the 7702 is made in China, while the 8801 & 8802 are made in Japan. Japanese workers are paid more then their Chinese counterparts. Also, Chinese assembly plants often are adjacent to the factories which provide the components, which further reduces overhead costs. In addition, higher quality (=more expensive) components, physical design and construction are used in the 8801 & 8802, like having a separate HDAM circuit board for each output. The HDAMs in the 7702 are all on the same single circuit board.
Selden
Selden Ball is offline
post #12269 of 13500 Old 11-23-2014, 07:24 AM
turnne1's Avatar
Liked: 410
increased costs associated with worker compensation and relative proximity of parts supply don't benefit the consumer at all at time of purchase
Further I would think that the Chinese made boards that go into all of their products are not that expensive...and the fact that they use the same box for many of their products gives them some great economies of scale
Then..I could also mention the sharing of parts and design with the Denon branded products
Of which..I really question how much difference there really is in an Denon 4520 AVR and the Marantz 8801
I will give you maybe 20-30% increase in price based on parts and labor
I am betting the other 60-70% of the difference is profit
Warren
turnne1 is offline
post #12270 of 13500 Old 11-23-2014, 05:28 PM
etc6849's Avatar
Quoted: 168 Post(s)
Liked: 124
Maybe $1500 for used one, although I haven't seen one that cheap and wouldn't sell mine for that. I do think folks sell used gear cheaper than normal as it gets closer to Christmas, but I looked through the completed auctions and most used units bring $1799 or more.
I also didn't see $1600+ new units from dealers. I'm not saying they're not there. I bought mine from ebay and saved $500 over what AVS quoted me, so definitely submit a best offer on ebay and the seller just might bite.
Warren
etc6849 is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
