Marantz AV8801 Preamp/Processor Official Owner's thread - Page 412 - AVS Forum | Home Theater Discussions And Reviews
 293Likes
post #12331 of 13529 Old 12-21-2014, 07:22 AM
Selden Ball's Avatar
Quoted: 3356 Post(s)
Liked: 1637
Originally Posted by audiofan1 View Post
Can't wait to find out if its indeed contributing anything or nothing but I suspect it has to do with bandwidth
All of the Atmos discs that I've watched use the standard 48K/s sampling rate. Soundtrack quality normally is the result of the quality of the people doing the audio mixing.
ffiandaca and audiofan1 like this.
Selden
Selden Ball is offline
post #12332 of 13529 Old 12-21-2014, 11:31 AM
Norcuron's Avatar
Liked: 25
Max Volume Issue
HI,
I have had a Max volume issue for a while. It will not currently turn up past 91.5. I have the Marantz App on my iphone and have made sure the Max volume is set to off. I went in and moved it to a max, allowed it to set the level and then went back turn it to off to make sure that is reset. I have also gone into the Marantz menu and made sure it is turned to off. Any other ideas? Yes 91.5 is loud but there are some songs that would be nice to have the max available. Thanks for input and ideas.
Marantz AV 8801 Processor
Sunfire Signature Amp 400x7
Oppo DV971H DVD Player
PS3
PS4
Klipsch RF-7
Klispch RS-7
Klipsch RC-7
Sharp Aquos 80; 3D Quattron
Power Sound Audio Triax Subwoofer
Norcuron is offline
post #12333 of 13529 Old 12-21-2014, 11:47 AM
kbarnes701's Avatar
Quoted: 6818 Post(s)
Liked: 5247
Originally Posted by Norcuron View Post
HI,
What are your speaker and sub trims set to? If they are set quite high then the max volume is limited in order to preserve headroom. For example, if you have a total trim boost of 15dB then your max volume will be 15dB down. I am not familiar with the absolute volume scale, so not sure how much higher than 91.5 it should go, but if you set it to the relative volume scale it will tie in with the dBs as indicated in your trim settings.
kbarnes701 is offline
post #12334 of 13529 Old 12-21-2014, 11:53 AM
Norcuron's Avatar
Liked: 25
Front L -5, Front R -5.5, Center -3.5, Sub shows -6 in Audyssey but I fluctuate the sub all the time depending on what I am listening to.
PS3
PS4
Klipsch RF-7
Klispch RS-7
Klipsch RC-7
Norcuron is offline
post #12335 of 13529 Old 12-21-2014, 01:27 PM
kbarnes701's Avatar
Liked: 5247
Then it isn't that which is causing the problem. I am out of ideas now though, sorry. At least, one possible cause has been eliminated.
post #12336 of 13529 Old 12-21-2014, 09:38 PM
mikejedi123's Avatar
Quoted: 72 Post(s)
Liked: 63
Ok fellow AVS friends, i have been messing with this beast for the past few days.. on my adventure I encountered a small ground loop hum... flipped my ground switch on my A52 amp and 2125 amp, back and forth and let the Parasound's warm up a bit .. voilia... Gone! Haven't heard it since.. maybe i got lucky , i don't know .. but i seem to get it when i first hook up the amp's to a new pre/pro.. it did the same thing to me when i used the Yam Z7 at first and then went away...!! YAY! #2 cable/sat went haywire on the audio.. reset the microprocessor once.. and then my cable box.. all gone..... #3 I wasn't getting alot of bass.. turns out i didn't set audessey right the first time and had accidentally skipped the subwoofer calibration test, DOH! LOL... fixed all of that business.. and i am starting to dial this thing in and OMG ... it is sounds amazingly different than my old piece, and in a good way , of course.. rich, yet clear.. there is more "there", there.. if you get my drift.. movies sound more real.. i am listening to a dexter gordon blue note Ron Mcmaster cd on my Oppo 105 as I type this..i feel like i am there with him.. it sounds more like an LP.. this is a true pre-amp IMO.... man ... and i have barely scratched the surface of this thing.. Thor sounded unlike i have heard it in my room... more to come guys.. i may have some more to ask you guys possibly.. thanks to Audiofan1 and the rest of you guys for guiding me on this fun journey..
audiofan1 likes this.
mikejedi123 is offline
post #12337 of 13529 Old 12-21-2014, 10:27 PM
audiofan1's Avatar
Quoted: 1738 Post(s)
Liked: 1788
Big congrats! Dexter Gordon is a great musician indeed! kudos on that one. It's indeed true the 8801 as a preamp is its hidden gem feature as it allows the something like the 105 to really shine without hindrance and I was as shocked as you on the Oppos analog like SQ. Great tip on the flipping the ground switch on the Parasound's my A21 does give some faint hum but I've always wondered why some flips of the ground lift where better than others, I'll have to give it a go
Enjoy the movies and music
mikejedi123 likes this.
audiofan1 is online now
post #12338 of 13529 Old 12-23-2014, 12:52 AM
Quoted: 72 Post(s)
Liked: 63
I am further along on my journey tonight.. I hooked up a digital coaxial cable to my old Arcam CD73 to see if it sounds better than the analog outputs , which are pretty darn good to begin with, and guess what? You are 100% correct, audiofan1! The DAC's inside the 8801 are awesome as well.. they sound different than the 105, but in a toe-tapping rythmic way! Way cool.. i am listening to one of my favorite Rippingtons jazz cd's on the Arcam right now via the coax cable!!! Sounds live!
post #12339 of 13529 Old 12-23-2014, 04:13 AM
EZ-Rhino's Avatar
Liked: 32
Welcome to the club. Good to hear you are enjoying it. I don't if anyone has mentioned the cooling issue to you. Most of us are using external fans on our 8801's as the rear gets very hot.
EZ-Rhino is offline
post #12340 of 13529 Old 12-23-2014, 10:21 AM
Quoted: 72 Post(s)
Liked: 63
Luckily mine hasn't gotten too hot.. it is on an open rack.. although i will look into a cooling option just in case it starts to get real hot if i play it for real long periods... i will keep an eye out.. thanks!! Yeah, it does sound good.. i am enjoying trying out all of my movies and music!!
post #12341 of 13529 Old 12-23-2014, 10:33 AM
audiofan1's Avatar
Liked: 1788
Nice indeed to have so many awesome playback options
post #12342 of 13529 Old 12-23-2014, 01:01 PM
Point Source
beastaudio's Avatar
Quoted: 4005 Post(s)
Liked: 3308
HI,
See if you only have the issue when streaming (using the network source or airplay in general) content to the unit, as opposed to other sources like a blue ray player. NOTE: if switching to another source, you HAVE to pause whatever you were previously using the network streaming option for. This is an issue I ran into as well and never found out the source of the issue. Unfortunately, I wasn't even able to find out which component it originated from. I too was on an iphone, so I bought a new android, still the volume stuck. I thought it was the app so I deleted the app, and went with deremote. Nope, not that either.
Here was the rough part: I could switch from my phone to my wife's or friend's iphone when they wanted to stream music to the 8801 and viola, they could get the volume to crank the rest of the way just fine. It was only when I switched back to my control and streaming that the issue would immediately pop back up. Obviously even on a brand new phone, on an entirely different OS never fixed what what happening. I got so frustrated by the end of all of that and running around in circles for so long that I just went and bought two sonos units and haven't looked back since. I would still try:
Microprocessor reset on the 8801 (Might have to do 3 in a row to fully reset the unit)
deletion and reinstallation of the marantz app
checking other sources to see if volume sticks on those whilst not streaming period to the 8801 even when not selected as source.
FS: BossoBass A-14K amplifier
beastaudio is offline
post #12343 of 13529 Old 12-23-2014, 08:20 PM
Quoted: 72 Post(s)
Liked: 63
Listening to James Taylor/Carole King Live at The Troubador 2007 CD, wow!! on CD Direct setting with my Oppo 105D.. wowza!!! Awesome, i think JT and CK are in my condo , along with their band!!!
post #12344 of 13529 Old 12-23-2014, 09:14 PM
Point Source
beastaudio's Avatar
Liked: 3308
Sorry if I missed, what speakers are you using along with the 8801?
post #12345 of 13529 Old 12-23-2014, 10:23 PM
Quoted: 72 Post(s)
Liked: 63
Cool speakers
Hi there, I have the Definitive Technology BP7002's (mains), Def Tech CLR 2500 (center), Infinity Entra .1 rears... and Infinity Entra Center rear center along with my Def Tech Trinity Subwoofer...... They sound great.. i love the Def Tech BiPolar sound.. i believe these sound superior to the newer Def Tech line IMO..... on movies and music.... and with my Parasound A52, 2125 and now adding the 8801 , the system shines even more!!
beastaudio likes this.
post #12346 of 13529 Old 12-26-2014, 01:19 AM
Quoted: 72 Post(s)
Liked: 63
Listening to some Hell Freezes Over by the Eagles XRCD2 in Direct CD and also in DTS NEO X Game mode.. sounds different in good ways in each mode.. I like the detail of the direct CD mode but i also like the spaciousness of the DTS NEO X setting.. it gives it a little extra on this particular live recording.. I am impressed at the versatility of this Marantz.. the midrange is so sweet and it just sounds so balanced.. i can hear all of the high's mids, and lows.. it is totally a transparent pre/pro to the source IMO.. Also was watching my Star Wars Blu-Ray's and my Man of Steel BD as well and i just can't stop listening to moves and music.. i can't wait to fire up Transformers 4........................!!!!!!
JimP and audiofan1 like this.
post #12347 of 13529 Old 12-26-2014, 06:21 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7411 Post(s)
Liked: 4120
My apologies for a slightly off-topic question. I will be receiving an 8801 soon, and have a question regarding using XLR cables. I recently installed an XPA-7, and am using seven un-balance digital audio cables from Monoprice for the connections. The cables are very stiff, and routing them in my equipment rack was a bear. Are XLR cables inherently more flexibile and easier to handle, or does it depend on the cable brand? I am thinking of getting the cables from Monoprice.
Thanks in advance for any feedback.
AustinJerry is offline
post #12348 of 13529 Old 12-26-2014, 09:23 AM
Dave Vaughn's Avatar
Quoted: 1041 Post(s)
Liked: 1512
The Monoprice XLR cables are more flexible than their RCA cables by far. That's what I've been using to good success. I also use their XLR to RCA cables to my subs (actually to the wall plate then a different cable to the subs). I like the secure connection that XLR provides.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is offline
post #12349 of 13529 Old 12-26-2014, 12:10 PM
Point Source
beastaudio's Avatar
Liked: 3308
any particular reason you are using DTS neo X "game" setting instead of DTS neox "Music?" You do know you can hold down each of the 4 colored audio buttons to get a quickscreen to pop up with all the audio options for each (Movie/music/game/direct)? Just thought I would point that out in case you didnt know
post #12350 of 13529 Old 12-26-2014, 02:12 PM
Quoted: 72 Post(s)
Liked: 63
Thanks man, i hadn't realized that.. thanks for the heads up.. i will also try DTS Neo music again today.. In fact.. i was just trying to add something to the TrueHD track on Star Trek Into Darkness and i couldn't add DTS neo or anything else except for Virtual and Multi Channel Stereo... IS it becasue its a TrueHD track or am i doing something incorrect? I know how to add it to the stereo CD's, but i pressed the same buttons and i an getting different options on the movie tracks.. Stereo , Dolby TrueHD (in this case), Multi-Channel and Virtual .. it doesnt look like i can add NEo or Dolby iix etc.. even though in the manual it says i can add for movies.. maybe i disabled it somehow when i was listening to music earlier? Any thoughts.. thanks guys...
post #12351 of 13529 Old 12-26-2014, 06:37 PM
Liked: 1637
The various upmixers can't do anything if the original soundtrack is already occupying all of your speaker channels. STID has a 7.1 channel soundtrack: Front LCR, Side Surround and Rear Surround. DTS Neo:X is only available to augment it if you have Front Wide and/or Front Height speakers in addition to the traditional surround speakers.
Selden
post #12352 of 13529 Old 12-27-2014, 02:30 AM
Quoted: 72 Post(s)
Liked: 63
thanks selden... STID is an awesome sounding track!!! In fact , i knew it sounded good, but with my 8801 its like its a whole level up...!! I used the music mode with my CD's , it's a nice sound as well when i don't want to use Direct , which i often do. I also like using DTS NEO X Music on my 5.1 DTS HD MA and TrueHD Blu-Ray concerts!! Really cool, i was using it on BadCo Live @ Wembley and wow!! And on Live at Montreux: Return to Forever.. also better than i ever heard it!! I am always learning something new.. I also started playing my Xbox One and it actually sounds best on the standard auto mode.. i tried adding the DTS GAME NEO and it sounds werid to me.. maybe cause i am already upscaling the sound thru my Oppo105D and it sounds good enough through that @ auto Call Of Duty Advanced Warfare sounds amazing.. i can hear much more of the surrounds bullet sounds etc now.. I feel that XT32 Audessey makes a real difference in my room.. seems like it is much better than my old Yammie DSP's.. but thats just IMO and who knows it was an older Yammie model RX-z7 ....I am sure the new ones are better..... but I am loving my New 8801..!! i will keep playing with it though.. I think my neighbors thought i had a real space battle going on in my condo with Star Trek Into Darkness!!!
post #12353 of 13529 Old 12-27-2014, 09:49 PM
admranger's Avatar
Quoted: 14 Post(s)
Guys, my lovely wife bought me (after much begging) two new front speakers: ATC SCM 19's (had to be stand mount). They are lovely in 2ch mode, with a much wider and deeper soundstage as well as incredible resolution (I'm hearing new, subtle parts of the music that I *thought* knew every note/nuance of). Still getting them broken in, but they are darned impressive speakers. Their resolution is nearly the same as the Vivid B1's (driven by Luxman Class A amp, etc., etc.) I heard in my house during an audio club event. I don't have the SCM 19's four feet out into the listening room though!
So, I have the old B&W LCR's and I am thinking of trying them in my system for a 7.2 system (vs. the 5.2 that I'm used to). Should I use them as wides or highs? Eventually, my wife will decide (aesthetics). I'm just wondering which one is preferred over the other? For wides, I can get about 6' or so wider than my front speakers. However, the left one will be quite a bit forward from the right one, though processing should take that out. If I go with the speakers in the 'high' position, they'll be about 3.5 - 4' above the mains, but narrower in width than the mains.
Looking forward to your input/ideas on this.
Marantz 8801 Marantz 7055 Merrill Thor Monobolcks Oppo 95 SystemDek IIX turntable ATC SCM 19 V2's (L&R) B&W LCR6 (center and heights) B&W in ceiling surround speakers Velodyne SPL-10 Subs (2) Sony xbr65x850a
admranger is offline
post #12354 of 13529 Old 12-27-2014, 10:09 PM
Quoted: 72 Post(s)
Liked: 63
I would say go with the high one's , since they will be more even.. I mean i am sure the marantz processing should take care of the other way.. but personally it would drive me nuts seeing one more forward than the other.. i guess i am OCD .. we tend to be in this hobby huh? Yeah, i would think it would sound better and you wouldnt have to futz with the processing as much to get the other way to sound right.....
It's funny you are talking about this tonite.. becasue my wife and I want to sell our condo and buy a little bit bigger free-standing home this coming year.. and she said she would be OK if added 3 more speakres to make it 9.1 but she said she is not going for the full 11 channels and she said i have to figure it out since we only have so much room.... as she kept reminding me , yes we are getting a bigger house.. but the living room will likely be the same size or only slightly larger because most of the new space will be in the 3rd bedroom in a free-standing home (we have a 2 bedroom condo now).... luckily we have pretty understanding wive's that put up with our hobby .. !
Let us know what you decide....
post #12355 of 13529 Old 12-28-2014, 02:50 AM
jdsmoothie's Avatar
Quoted: 14340 Post(s)
Liked: 6768
Definitely Front Wides as doing so will help to open up the front sound stage much more effectively (all the time) as opposed to Front Heights which will rarely be used.
jdsmoothie is online now
post #12356 of 13529 Old 12-28-2014, 07:37 AM
discodol's Avatar
Quoted: 22 Post(s)
Liked: 34
Originally Posted by Dave Vaughn View Post
Just found out yesterday I'll be reviewing the 8802...should get it sometime next month Time to get ready for an Atmos upgrade
Awesome, what speakers placed in what configuration are you planning on using?
I hope you are going with one of the 11 speaker layouts!!
David Ferebee
discodol is offline
post #12357 of 13529 Old 12-28-2014, 08:21 AM
Expletive's Avatar
Quoted: 47 Post(s)
Are there any DIY options that will have a fan switch on/off with the power of the 8801? Right now i'm using a USB powered fan on the rear of the unit but that fan stays powered on all the time since the USB ports aren't switched. Any ideas welcome!
Expletive is offline
post #12358 of 13529 Old 12-28-2014, 08:25 AM
jdsmoothie's Avatar
Liked: 6768
The USB should power off when the NETWORK setting is set to "Off in Standby."
post #12359 of 13529 Old 12-28-2014, 08:36 AM
Expletive's Avatar
Quoted: 47 Post(s)
Great tidbit, thanks! I assume the only downside here is if someone wanted to turn the 8801 on using the iOS app?
post #12360 of 13529 Old 12-28-2014, 08:40 AM
jdsmoothie's Avatar
Liked: 6768
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
