Marantz AV8801 Preamp/Processor Official Owner's thread - Page 417 - AVS | Home Theater Discussions And Reviews
post #12481 of 12498 Old 01-20-2015, 08:20 AM
Selden Ball's Avatar
Quoted: 1010 Post(s)
Liked: 593
Originally Posted by ballpark View Post
I would be interested to hear if anyone has used a Speaker Switch/Selector with the AV8801. I would hate to spend the money if it's not the best route to take.
Sorry, I can't help directly with the choice of speaker switches since I've never used any.
However, bear in mind that you should use two different Audyssey calibrations: it'll be different for different speakers.
D+M equipment, including the AV8801, can save and restore their internal settings if you use the Web interface, so you could save the settings after calibrating each speaker set, then restore the appropriate one when changing between speakers. Unfortunately, however, that takes about 10 minutes or so, which might be longer than you're willing to wait.
Selden
Marantz SR7009/7.1.4/FH+TM/DefTech PM1000/LCR+TM amped
Selden Ball is online now
post #12482 of 12498 Old 01-20-2015, 08:35 AM
BVLDARI's Avatar
Quoted: 17 Post(s)
Liked: 26
My wife has an iPhone and the airplay off youtube works beautifully. I have an android and have no idea how to make that work. Any suggestions?
BVLDARI is offline
post #12483 of 12498 Old 01-20-2015, 08:39 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 2699 Post(s)
Liked: 1910
There are a number of Android apps to include DoubleTwist - MagicPlay which I've used with a Samsung GS3 to Airplay audio to the AVR.
https://play.google.com/store/apps/d....android&hl=en
"JD" – jd@avscience.com ; Call me --> 585-645-1006, AVScience - AVSForum sponsor and dealer for AVRs and Speakers
Daily 8am – 8pm EST
Call for info on Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #12484 of 12498 Old 01-21-2015, 06:09 AM
viper72's Avatar
Hi. If you are rooted "Allstream" works really well and is simple. On my GS4, I can stream any music app (G Music, Pandora, Amazon, etc) using either Airplay or DLNA. Quality is better than bluetooth as well. There are some other apps that do video as well, but I have not tried those because I use my BR player for that. Regards.
Sent from my SCH-I545 using Tapatalk
Xbox Live ID- STRONGBOWSIX
viper72 is offline
post #12485 of 12498 Old 01-21-2015, 09:03 AM
BVLDARI's Avatar
Quoted: 17 Post(s)
Liked: 26
The only reason I am interested in this is so that I can play youtube music for the kids every once in a while. at the moment I have to go get an iPhone to do that LOL... So quality of sound is really of no concern - I only care about functionality. The iPhone/Airplay is so simple I am shocked Android doesn't have something similar. Any other suggestions that do not require rooting the phone?
BVLDARI is offline
post #12486 of 12498 Old 01-21-2015, 09:05 AM
Say No to Auto EQ
beastaudio's Avatar
Quoted: 1129 Post(s)
Liked: 1047
Google chromecast bro. Piece of cake
(European models do not accept banana plugs.)
"If you done it, it ain't bragging." ~ Walt Whitman
AE TD12x SEOS12 Build
Beast's DIY Master Measurement Thread
DIY Emminence Coaxial Surround Thread
beastaudio is online now
post #12487 of 12498 Old 01-21-2015, 09:31 AM
viper72's Avatar
Yep. Can't go wrong for 35 bucks or less on sale.
viper72 is offline
post #12488 of 12498 Old 01-24-2015, 10:54 PM
DrMichael's Avatar
Quoted: 21 Post(s)
Question for anyone who can help. I was finishing Schindler's List tonight and the audio went completely silent. It occured when the survivors were walking over the hill and it changed from black and white to color. I watched in silence to the end credits. Paused the movie and it didn't help. I FF a few seconds and the audio came back on. I then rewatched the scene and it did not repeat. Is this just a random dropout on a defective disc or is it something with the Oppo or Marantz? I have never had this happen before. Thanks for your help.
Panasonic TC-P65ZT60
Marantz AV8801 pre-pro / MM8077 amp
Martin Logan Motion 50XT Center
Martin Logan Motion 60XT Fronts/40 Rears
REL R-528 SE (2)
Oppo BDP-103D/Playstation 4/Furman ELITE-20 PF i
DrMichael is offline
post #12489 of 12498 Old 01-24-2015, 11:07 PM
AustinJerry's Avatar
Quoted: 1645 Post(s)
Liked: 1028
I have never had that happen on a disk, but have had similar experiences when watching my DTV DVR's. I think it is probably random, and unless it happens often, you should not be concerned.
AustinJerry is online now
post #12490 of 12498 Old 01-27-2015, 01:49 PM
PauldF's Avatar
Temporary Amp ideas?
Hi all, I have the following system currently:
7.1 Paradigm Ref Studio 100 mains and center, matched side and rear surrounds
Harmon Kardon Citation 16 amp running the mains
Denon 3805 AVR running the center and surrounds
Denon 3930 Universal player
Panasonic BDP, STB, etc.
I would like to upgrade to the AV8801, but don't have the coin right now to add the matching MM8077 amp - even with with 8801 selling for under $2K. If I bought the 8801 with the intent of buying the 8077 next year, is there a way I could add it to my current system now? Use the HK and Denon AVR to power the speakers, but use the 8801 to handle all the processing etc? If so, how?
PauldF is offline
post #12491 of 12498 Old 01-27-2015, 02:08 PM
Liked: 593
There's no reason to buy a Marantz amplifier other than to have the same logo on all of your equipment. Just about any other amp will work with Marantz equipment just as well. (Although some older high gain amps from Emotiva have difficulties when used with high efficiency speakers.)
In the short term, you could use your Denon AVR to act as a stereo amp. You'd have to do without the center speaker (i.e. use a "phantom center") until you can afford a multi-channel amp. Emotiva's current amp lineup is reasonably priced and have a good reputation.
Dave Vaughn likes this.
Selden
post #12492 of 12498 Old Yesterday, 07:05 AM
blazar's Avatar
Quoted: 179 Post(s)
Liked: 322
Gonna test the 8801 with the new NAD M22 (with hypex modules) this week to see how the combo performs with high efficiency speakers.
For very high efficiency speakers, the 8801 NEEDS XLR attenuation pads (around -10db per channel), otherwise you cant level match your mains correctly and the ambient hiss from the marantz will be unbearable.
I hope hypex solves at least the amplifier part of the hiss. Perhaps the new marantz 8802 will solve their noise levels by an order of -10db.
blazar is offline
post #12493 of 12498 Old Yesterday, 08:08 AM
Say No to Auto EQ
beastaudio's Avatar
Liked: 1047
Not likely. But that is what the attenuators do anyways
post #12494 of 12498 Old Yesterday, 02:11 PM
Craig Peer's Avatar
Location: In my home theater ( when I'm not rock climbing, cycling or kayaking ) - Sacramento CA area
Quoted: 508 Post(s)
Liked: 403
We happen to have one brand new 8801 left, at a great price. Call if interested !!
Craig Peer, AV Science Sales. Call me on my direct line - 585-671-2972, 8:30am - 4:30pm PST, Monday - Friday
Email me at craig@avscience.com http://shop.avscience.com/
Yes, we sell Home Theater gear right here at AVS !!
JVC, Sony, Epson, DPI, SIM2, SV Sound, Martin Logan, RBH, and many more!
Craig Peer is offline
post #12495 of 12498 Old Yesterday, 04:07 PM
DrMichael's Avatar
Quoted: 21 Post(s)
An update on the Schindlers List audio drop out: I let the movie run from the beginning and around the same time as previously mentioned the audio dropped out again. It was in a different spot about 30 seconds pats the previous drop out. The audio comes back on after a rewind but not after a pause. It does not Drop Out if I start a chapter over it appears like the whole movie has to be played. The disc is clean and I don't know why it keeps doing this. Any thoughts? Bad disc?
REL R-528 SE (2)
post #12496 of 12498 Old Yesterday, 05:24 PM
Redbeemer's Avatar
I am a reviewer and currently have the Marantz 7702 in my HT setup for review. The sound is excellent. However, I contacted a VP at Marantz with his recommendation regarding my purchasing either the 7702 or the 8801 based on sound quality alone. He told me that if I didn't need/want Dolby Atmos, to get the 8801. I ordered the 8801, but have not received it yet, so can't compare the two, but presumably the Marantz exec has heard them both. Hope this helps!
Redbeemer is offline
post #12497 of 12498 Old Today, 03:12 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1910
More than likely disc related, especially if this is the first disc to present this issue.
Daily 8am – 8pm EST
post #12498 of 12498 Old Today, 08:51 AM
btran33's Avatar
Hi Everyone:
I tried to search for this problem but can't seem to find a solution. Last night, when listened to music I started to notice that the Front Left Channel volume was lower than the right. Took out my trusty Radioshack sound meter and it confirmed that the left channel was indeed ~6 db lower than the right! I didn't do anything to the AV8801 since installed about 3 months ago. Anyway, I reset the AV, changed out the cables, switched to a different amplifier, rerun Audyssey but nothing work. The Left channel is still around 6 db lower than the right, etc after Audyssey the front left is +0.5 gain and the front right is at -6.5. They were about +/- 0.5 db gain the first time I set up. The sound quality, after balance out the channel, seems to be fine. I didn't notice anything bad in the sound. However, this is really bugging me as something is not right. Did any one have this problem before? Should I contact Marantz for service?
Thank you,
Bao Tran
btran33 is online now
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
