Marantz AV8801 Preamp/Processor Official Owner's thread - Page 418 - AVS Forum | Home Theater Discussions And Reviews
 293Likes
post #12511 of 13521 Old 01-29-2015, 06:15 PM
DrMichael's Avatar
Quoted: 91 Post(s)
Liked: 54
Originally Posted by DrMichael View Post
An update on the Schindlers List audio drop out: I let the movie run from the beginning and around the same time as previously mentioned the audio dropped out again. It was in a different spot about 30 seconds pats the previous drop out. The audio comes back on after a rewind but not after a pause. It does not Drop Out if I start a chapter over it appears like the whole movie has to be played. The disc is clean and I don't know why it keeps doing this. Any thoughts? Bad disc?
I think I can rule out the 8801 being the cause of the audio dropout as I played the movie 2 times on my PS4 (that is apart of my HT setup) and no audio drop. So it must be a disc/Oppo compatibility issue....
LG OLED e6 65
McIntosh MX160 precessor / McIntosh MC8207 amp
Martin Logan Motion 50XT Center
Martin Logan Motion 60XT Fronts / 40 Rears
SVS PB13-Ultra (2)
Oppo UDP-203/Furman ELITE-20 PF /Playstation 4/ Apple TV/Nintendo Switch
DrMichael is offline
post #12512 of 13521 Old 01-29-2015, 06:18 PM
btran33's Avatar
Quoted: 58 Post(s)
Originally Posted by jjazdk View Post
Are you using balanced interconnects?
If yes, then my guess is you have a bad interconnect cable, as that can give you exactly 6dB less gain if either + or - in the cable has no connection.
For a start try switching the interconnect cables to check if the issue follows the cable.
I have tried the on/off...off/on method with no luck! And yes, I have balanced interconnects cables (monoprice) and had tried to swap the cable around. Let me try another cable swapping tonight and see if this is the problem.
Many thanks...
bt
btran33 is offline
post #12513 of 13521 Old 01-30-2015, 03:39 AM
jdsmoothie's Avatar
Quoted: 12967 Post(s)
Liked: 5986
Originally Posted by AustinJerry View Post
I mean no disrespect, Beast, but can you explain to me why several resets accomplish more than one reset? Based on my understanding of electronics, this doesn't make any sense. I hear the recommendation many times, but no one has ever presented evidence that proves to me why more than one reset would be required.
The evidence is those forum members who have posted that multiple resets resolved their issue when a single reset did not and I've seen enough posts to that effect that it prompted me to change my long time last line in my sig to what it is today.
jdsmoothie is offline
post #12514 of 13521 Old 01-30-2015, 12:52 PM
Quoted: 28 Post(s)
Liked: 2
Quick Question on 9.1 with Heights
I'd like to run a 9.1 with 2 surround backs and 2 heights. I see in the AV8801 manual that if the source is Dolby True HD, for example, then the output modes possible include Dolby True HD +PLIIx (for SB) *or* Dolby True HD + PLIIz (for heights).
I'd like to run PLIIx and PLIIz at the same time to get the 9.1, will it do this automatically?
I was not a fan of the Audyssey height processing, so I'd like to stick with Dolby's version.
Thanks for any input,
Jon
JonnyFive54950 is offline
post #12515 of 13521 Old 01-31-2015, 11:21 AM
AndyN's Avatar
Quoted: 23 Post(s)
Does a microprocessor reset delete all settings ie audyssey, speaker distance, etc?
AndyN is offline
post #12516 of 13521 Old 01-31-2015, 11:50 AM
Audiguy3's Avatar
Quoted: 123 Post(s)
Liked: 69
Andy the answer is yes
Audiguy3 is offline
post #12517 of 13521 Old 01-31-2015, 12:03 PM
audiofan1's Avatar
Quoted: 1669 Post(s)
Liked: 1697
Guys I've been meaning to post this as I just found it but if one needs to do a microprocessor reset and want to retain there Auydssey and all other configuration settings , here's a tip and a feature that's still around I got direct from a Marantz tech!
To Save
Display & Zone Select for 4 seconds
To restore
Setup & Zone Select
This saves a lot of headache and gets you back to that good run of Audyssey you may have liked after a reset
Audiguy3 likes this.
audiofan1 is offline
post #12518 of 13521 Old 02-03-2015, 12:56 PM
Quoted: 28 Post(s)
Liked: 2
Answered my own question. PLIIz = PLIIx + heights, so I can achieve the 9.1 with Dolby PLIIz. And also with Audyssey DSX and DTS NEO:X.
post #12519 of 13521 Old 02-05-2015, 01:49 PM
Point Source
beastaudio's Avatar
Quoted: 3704 Post(s)
Liked: 2981
Hey dudes, just for those that might not have noticed, I posted my 8801 in the classys
beastaudio is offline
post #12520 of 13521 Old 02-05-2015, 01:54 PM
Quoted: 1474 Post(s)
Liked: 608
beast....what are you replacing it with?
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is offline
post #12521 of 13521 Old 02-05-2015, 01:56 PM
Point Source
beastaudio's Avatar
Liked: 2981
Got the 7702 in the rack last night....It will live there until the 8802 comes out. Yea right, I didn't even consider another brand unit after how much I have enjoyed the 8801
post #12522 of 13521 Old 02-06-2015, 08:47 AM
Dave Vaughn's Avatar
Quoted: 1004 Post(s)
Liked: 1480
So you have a two week purchase or are you going to wait until the Marantz 8802 is fully "upgraded" from the factory before purchasing?
labman1 likes this.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is offline
post #12523 of 13521 Old 02-06-2015, 09:13 AM
Point Source
beastaudio's Avatar
Liked: 2981
Gonna hang around for the fully upgraded deal.
Dave Vaughn likes this.
post #12524 of 13521 Old 02-06-2015, 10:55 AM
audiofan1's Avatar
Liked: 1697
I sure hope the fully "upgraded" includes DTS X as all else is ticking my audiophile boxes, if it can best my Oppo 105 for 2/ch this paired with a 103D or Oppo 4k will be a killer combo
post #12525 of 13521 Old 02-06-2015, 05:47 PM
labman1's Avatar
Quoted: 79 Post(s)
Liked: 24
Have a question. I have an 8801 and was thinking about Atmos like everyone else. Would selling the 8801 then buying a 7702 be a lateral move or waiting for the 8802. I see the 7702 does not have 2.2 for 4k protection. I only have 7.2 channels and it will be awhile before I let go of my calibrated plasma. Wondering what 8801 owners are going to do? Thanks for your help. Love the Marantz sound btw!
labman1 is offline
post #12526 of 13521 Old 02-06-2015, 06:01 PM
Kal Rubinson's Avatar
Quoted: 703 Post(s)
Liked: 482
Try this thread: The **OFFICIAL** Marantz AV7702 Pre/Pro
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #12527 of 13521 Old 02-06-2015, 06:07 PM
CIH USER
Franin's Avatar
Quoted: 2234 Post(s)
Liked: 1348
Personally I'd wait, but it's up to you. We don't know what's happening with DTS X plus there is very little titles on Atmos at the moment. If your happy with your setup I'd say stick with it but if your in a rush for the next best thing then go for it. Be prepared though if you do upgrade now you might have to upgrade again very soon. My 2 cents
Frank
_________________________
Franin is offline
post #12528 of 13521 Old 02-06-2015, 10:07 PM
WestCoastD's Avatar
Quoted: 272 Post(s)
Liked: 98
I think I'm gonna wait a few months myself, see how all goes. I'm sure they will be good performers
WestCoastD is offline
post #12529 of 13521 Old 02-06-2015, 10:10 PM
WestCoastD's Avatar
Quoted: 272 Post(s)
Liked: 98
setting-up a brand-new AV8801 (still), contemplating whether to use built-in hub to connect all other devices (Oppo BDP-105, etc.,...) to network? Or, instead, employ a third-party switch (Netgear GS605)?
post #12530 of 13521 Old 02-07-2015, 10:23 AM - Thread Starter
exm
exm's Avatar
Quoted: 135 Post(s)
Liked: 82
I think most users here are not using the built-in hub. Don't forget also that it's not a gigabit hub
exm is offline
post #12531 of 13521 Old 02-07-2015, 10:31 AM
Oppo Beta Group
RichB's Avatar
Quoted: 967 Post(s)
Liked: 638
... and it is not a switch.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is offline
post #12532 of 13521 Old 02-07-2015, 10:38 AM
audiofan1's Avatar
Liked: 1697
I've used the hub in the past and it works great
post #12533 of 13521 Old 02-07-2015, 12:47 PM
Liked: 1480
I have a gigabit switch in my rack and use that.
post #12534 of 13521 Old 02-07-2015, 02:23 PM
WestCoastD's Avatar
Quoted: 272 Post(s)
Liked: 98
yeah, I will probably go with my NetGear GS605 Gigabit switch.
post #12535 of 13521 Old 02-07-2015, 02:28 PM
WestCoastD's Avatar
Quoted: 272 Post(s)
Liked: 98
regardless, I'm gonna wait a little while before I spring for an AV8802 (maybe until summer 2015 or so). While I would love to have an Atmos capable set-up, I only use 5.1 configuration at the moment. But I am intrigued with analog audio differences, improvement, new updated HDAM circuitry may yield.
post #12536 of 13521 Old 02-07-2015, 08:18 PM
labman1's Avatar
Quoted: 79 Post(s)
Liked: 24
I found an Onkyo 626 that I picked up for $160, they said it turned on then off. It was in protection mode. since it was under warranty sent it in and they repaired it. just go it back yesterday thought I might play with the atmos in this and see how it sounded. Nothing like the 8801 but it would give me an idea. What switching would I need or do I just hook my speakers up to the Onkyo. Now to find some Atmos speakers to go with my VonSchweikert Audio speakers.
labman1 is offline
post #12537 of 13521 Old 02-08-2015, 01:52 PM
Volpar's Avatar
Quoted: 31 Post(s)
Liked: 2
I have been reading a lot of this thread and have not seen a lot people saying that the AV8801 sounds good. the price has dropped a lot and I was concentering getting one (1799.00) .
dose any one have any good things to say about it sonically or is this just a ok buy?
Volpar is offline
post #12538 of 13521 Old 02-08-2015, 02:52 PM
AndyN's Avatar
Quoted: 23 Post(s)
Audi- thank you.
audio- just missed your post due to my impatience but this is great to know.
AndyN is offline
post #12539 of 13521 Old 02-08-2015, 02:58 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
Originally Posted by Volpar View Post
I have been reading a lot of this thread and have not seen a lot people saying that the AV8801 sounds good. the price has dropped a lot and I was concentering getting one (1799.00) . dose any one have a good things to say about it sonically or is this just a ok buy?
Buying previous gen model is a good option, I've seen the 7701 pretty cheap too. lowest £999
fatbottom is offline
post #12540 of 13521 Old 02-08-2015, 03:28 PM
bweissman's Avatar
Quoted: 225 Post(s)
Liked: 89
I use the hub because the 8-port switch in my rack is full.
bweissman is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
