Marantz AV8801 Preamp/Processor Official Owner's thread - Page 421 - AVS Forum | Home Theater Discussions And Reviews
 294Likes
post #12601 of 13537 Old 02-27-2015, 06:05 AM
Quoted: 28 Post(s)
Liked: 3
Originally Posted by leo2498 View Post
one question about XT32, it set my speaker like large(even 805D) and I have plenty of tight bass with this setup but I wondering if I change this to small I will lose the filters of the XT32 did. What do you think? I did changed it to small but the bass was more boomy.
The resolution is the same in sub and satellite filters, so any degradation to performance with an XO could be from 1) Not a good Audyssey run on the sub. Was the sub loud enough? Did you use all 8 positions? 2) The mains are in a more bass-friendly place than the sub. Audyssey can only do so much.
If I XO at 80hz I observe a degradation in performance, but this is because my room has a resonance at 80hz with the sub in it's current location. If I XO at 40hz, it sounds much better. Try a lower XO?
JonnyFive54950 is offline
post #12602 of 13537 Old 02-27-2015, 06:23 AM
leo2498's Avatar
Quoted: 63 Post(s)
Originally Posted by blazar View Post
Way too many devices are selling due to cosmetics as opposed to brute force measurements and capability. And this is fact.
this is not correct at all, all audio stuff are designed with a target customers in mind and if you sonically you are testing the dac's in both equipments the classe "to my ears" is more accurate because of this I bought it. many user will buy stuff that not needing for example I not need more then 5,1 channels processor so DTS X or dolby atmos never will be in my list, I was looking for better performance in concerts and movies and I found it with the AV8801 and a 50% of the retail price is a bargain.
if you are looking to exceed audio performance and "musicality" I don't think that you will get it with the 8802 but with a SSP-800 or high end processor you will be. if you want a good audio performance with multiples options, room correction, dolby atmos and 13.2 channel handling so the answer is easy "8802".
BTW classe CP800 have magnificent performance with technical aspects and I hear a small hiss if I put my ear 1" from my tweeter and to 1 feet I couldn't. when I did the same test with the AV8801 in my center and surround speaker the hiss is even lower than my front speakers(I bypass the CP800 when I listen multichannel content). maybe I'm wrong but low hiss noise is not a accurate measure of quality of equipment.
Leo,
Saludos
My HT: B&W 804D fronts, HTM4D center, 805D rears, Classe CA-2300 Main amp, Preamp Stereo CLASSE CP800, Preamp Multi Channel Marantz AV8801, A31 parasound center and Surround Amp, Source Oppo BDP-95 screen Samsung 55" UE55d8000 SVS SB12-NSD
Stereo: B&W 804S fronts, Pre: Denon AVR-2809CI amp Rotel RB1582.
leo2498 is offline
post #12603 of 13537 Old 02-27-2015, 06:51 AM
leo2498's Avatar
Quoted: 63 Post(s)
thanks for your answer.
The resolution is the same in sub and satellite filters, so any degradation to performance with an XO could be from 1) Not a good Audyssey run on the sub. Was the sub loud enough? Yes it was 76 dB according to marantz guide Did you use all 8 positions? Yes I did, even I put the mic’s in the same position that the marantz assistant required 2) The mains are in a more bass-friendly place than the sub. Audyssey can only do so much. I guess so, I planned my setup for two channels content mainly so I think that room acoustic I put in my room are helping this.
If I XO at 80hz I observe a degradation in performance, but this is because my room has a resonance at 80hz with the sub in it's current location. If I XO at 40hz, it sounds much better. Try a lower XO? Ok I will do.
BTW I have another doubt, finally I could use the XLR output to center and surround speaker and run again audyssey and I was surprised that the level set for it in this speaker was lower than before, for my center with rca cables was -3 dB and now with xlr is -1dB and the same thing happened with my surround, if the xlr have a gain of about 6dB why Audyssey set it with more gain that before?
After my last Audyssey reconfiguration the sub was taken of my system, not sound are coming from it, I think this room correction are not ok.
the XLR cables are musically II straightwire and for my fronts are kingcobra audioquest, in my fronts it was set to the level of -7.5 dB and during the audyssey configuration was way louder than my center and surround.
Leo,
Saludos
leo2498 is offline
post #12604 of 13537 Old 02-27-2015, 08:41 AM
Selden Ball's Avatar
Quoted: 3371 Post(s)
Liked: 1659
This suggests to me that you have not read the Audyssey 101 and FAQ. The instructions in the equipment manufacturers' owners' manuals are woefully inadequate and often misleading (as for the microphone positions). The Audyssey 101 document here on AVS will help you to get a better calibration.
The actual gain difference depends on the implementation of the two types of connections in your amps. Different designs have different gains.
Check the subwoofer channel's trim level in the receiver. If it's "too low", the signal getting to the subwoofer might not be high enough to trigger the sub's auto-on feature. i.e. turn down the gain on the subwoofer itself so that the 8801 will turn up its output signal. Also, you'll have to manually change the settings for your front speakers from "Large" to "Small" in order to enable bass management with low frequencies redirected to the subwoofer. (This is all explained in the Audyssey FAQ.)
Selden
Selden Ball is offline
post #12605 of 13537 Old 02-28-2015, 11:56 AM
leadliner's Avatar
Quoted: 39 Post(s)
anyone with a 8801 willing to dump there prepro now to get a 8802 or 7702 is going to be really pissed off in about 2 yrs because once all the other competitors come out with there new codecs and,
If you do want 4k content, every device in your video chain must have HDCP 2.2.
HDCP stands for High-bandwidth Digital Content Protection. time to chill out and let these companies get there act together.
leadliner is offline
post #12606 of 13537 Old 02-28-2015, 02:29 PM
Dave Vaughn's Avatar
Quoted: 1047 Post(s)
Liked: 1520
And while you wait for 2.2, 2.4 will be in the works along with something else new. It's just the way of the world now.
YellowC4S, leadliner and audiofan1 like this.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is online now
post #12607 of 13537 Old 03-01-2015, 03:24 AM
kbarnes701's Avatar
Quoted: 6818 Post(s)
Liked: 5249
Absolutely. Buying AV gear isn't an "investment". It's about enjoying what is available, when it is available, IMO. I could have waited for DTS:X before I bought my Atmos unit. And then I would have missed out on a whole year of Atmos and DSU goodness. I decided to jump for Atmos and I will keep my Denon 5200 for two years, which means I will then miss out on a year of DTS:X goodness. But as there isn't likely to be much content for DTS:X for a while after launch this fall, that shouldn't be too bad. And any DTS:X discs that do become available, I can enjoy with DSU - and then enjoy them all over again when I get my DTS:X-capable unit.
Dave Vaughn and leadliner like this.
kbarnes701 is offline
post #12608 of 13537 Old 03-01-2015, 09:11 AM
awardb's Avatar
Quoted: 21 Post(s)
So I just re-ran the Audyssey setup on my 8801. I noticed during the setup that the mic positions, as shown on the monitor screen, are opposite of the ones laid out in the Audyssey FAQ on this forum. Which one to believe for best results?
awardb is offline
post #12609 of 13537 Old 03-01-2015, 09:21 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7440 Post(s)
Liked: 4140
It doesn't matter. Mic positions should follow general guidelines (ear height, stay away from walls and setbacks, position the mic 6-18" apart, use all 8 mic positions, etc.). The actual order of placement has no affect on the calibration. Don't obsess--sit back and enjoy your system.
Edit: A lot of work went into the FAQ, with contributions from many long-time users in the Audyssey thread, and wonderfully edited by Kbarnes701. You should feel completely confident that the advice therein is accurate.
YellowC4S likes this.
AustinJerry is online now
post #12610 of 13537 Old 03-01-2015, 11:21 AM
awardb's Avatar
Quoted: 21 Post(s)
I have full confidence in the FAQ, and deeply appreciate the work that went into it by forum users. I used the FAQ mic positions, NOT the Marantz positions on the screen. And the technology guy in me thought there was a chance the the order of placement didn't matter, but I thought I'd ask.
awardb is offline
post #12611 of 13537 Old 03-03-2015, 10:25 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3829 Post(s)
Liked: 3824
We have one 8801 left at AV Science at a special price - call for details.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #12612 of 13537 Old 03-04-2015, 03:28 PM
Liked: 0
Just recieved a av8801 and playing around with it for a few days in Stereo mode with just the two main speakers which are Vandersteen 2c's. I don't know if im just used to a ton of bass but I feel the music is hallow without any punch to it. I have gone through all the settings multiple times but for the life of me still feel like it is just way too much treble and not enough bass. I hooked up my old 18+ year old Harmon Kardon avr200 mkII and that can pretty much shake the house with the amount of bass that it can produce even at low volumes. It does have a "Loudness" button on the HK and that is what boosts the sound to seem a lot fuller. Just wish this preamp had more oomph in the mids and down low.
BroodNV is offline
post #12613 of 13537 Old 03-04-2015, 03:45 PM
Liked: 4140
You provide little information on how you have configured the AVR. Are your speakers set to large or small? Do you have a sub? Have you run Audyssey room correction yet?
post #12614 of 13537 Old 03-04-2015, 03:52 PM
WestCoastD's Avatar
Quoted: 285 Post(s)
Liked: 106
there's pretty much a two-year cycle on this stuff, period. That's why I just invest in a good multi-channel amp, then upgrade pre-pro/receiver when major codec/formats/technology cycle
Franin, leadliner and audiofan1 like this.
WestCoastD is offline
post #12615 of 13537 Old 03-04-2015, 03:58 PM
Liked: 0
Speakers set to large. Ran Audyssey and I do not have a subwoofer.
BroodNV is offline
post #12616 of 13537 Old 03-04-2015, 04:16 PM
Liked: 4140
Obviously something has changed. Audyssey likely is producing a flatter response in the low end, and flatter can sound weaker. I wouldn't expect an 8" woofer to produce thunderous bass, but I also wouldn't expect the 8801 to be a step down when compared with your older AVR. I am a proponent of measuring audio response, and I am sure that measuring your old system vs. the new one would shed light on the situation.
post #12617 of 13537 Old 03-05-2015, 04:44 PM
Liked: 4140
I use the HDMI connection on the front of the 8801 to connect my laptop to run REW. However, the HDMI connection works intermittently. Sometimes the laptop connects, other times it doesn't. I did not have similar issues with my previous 4520, so I don't think it is the laptop or the cable. Anyone else having issue with the front panel HDMI connection?
post #12618 of 13537 Old 03-06-2015, 08:28 PM
DrMichael's Avatar
Quoted: 116 Post(s)
Liked: 85
So I just going out (after a year) that dolby true hd turns my loudness management compression to auto Obviously I turned it off but to fulfill my curiosity when does the compression kick in when it is on auto?
DrMichael is online now
post #12619 of 13537 Old 03-06-2015, 08:47 PM
bigguyca's Avatar
Quoted: 372 Post(s)
Liked: 253
I've fed Netflix and REW from a PC into the front HDMI port of the AV8801 on a number of occasions without any problems; so it can work. While expensive HDMI cables aren't required, some cables are defective from the start and some get damaged. There are very small wires in the cable that depend on precise geometry to do their job. Some of the connectors also aren't the best or with manufacturing tolerances the connectors on the two devices just don't match well. The same cable may fit OK to another device.
I had one of those Monoprice HDMI cables, with what I guess is a ferrite filter a few inches from the connector, not a Redmere. After a few years attached to back of my TV, the weight of the filter deformed the cable and I started to have intermittent dropouts. I replaced the cable with an inexpensive unit made by Mediabridge and purchased on Amazon. It works fine.
bigguyca is online now
post #12620 of 13537 Old 03-06-2015, 09:17 PM
Liked: 4140
When I can't get the front panel HDMI to work, I simply plug the same cable into HDMI6 on the back panel and it works fine, so I don't think it is a cable issue.
post #12621 of 13537 Old 03-06-2015, 10:50 PM
bigguyca's Avatar
Quoted: 372 Post(s)
Liked: 253
I don't mean to beat a dead horse, but I suggest you try several different cables if you have them. The match between the connectors on the cable and piece of equipment can vary and give inconsistent results. In addition, it would be so much nicer if it were the cable (or connector match) and not some equipment problem!
It can of course be an HDCP problem if the firmware/software has changed on one of the pieces of equipment.
post #12622 of 13537 Old 03-07-2015, 04:55 AM
turnne1's Avatar
Quoted: 1914 Post(s)
Liked: 473
I used a relativistic term such as "very little" difference between mainstream pre-pro vs high end such as classe. This is not a false statement when looking at featuresets or available codecs or even processing channels. In some ways the marantz is better if you want audyssey or dts neo x. This isn't just opinion, its simply a line by line evaluation of features.
In either case if I spring for one, the datasat or trinnov will eat the classe for breakfast in every regard.
The achilles heel of the ultra high end is their very long refresh cycle in addition to price. These barriers make them a problem for folks that want the latest and greatest features.
Marantz 8802 vs classe pre-pro? Marantz will win on almost every metric except perhaps cosmetics.
Anyway i think all the current designs suck. I want a rack mount processor with outboard 8 channel dac/channel breakout boxes. Theta is approximately doing this but the price points aren't there. Perhaps the emotiva folks will get it right. This would making changing a processor much easier while allowing you to spend as much as you need for fidelity.
breakout cables are commonly used in pro environments ... But of course we all know pro gear is "lo-fi" and doesn't qualify as audio jewelery.
I think a buyer of the Classe would disagree with you....and assuming you own the 8801...I think you have stated your opinion
So..it becomes an aspect of what the market is willing to pay
I assume Classe is making a profit and has buyers that will pay $X..Because they value the "very little"
The high end components do have longer refresh cycles and in fact don't ever even embrace certain features....for instance I don't think you are going to see an Ethernet port grouping on the back of one of their units
But..have you ever noticed how the pieces never really get discounted and how much resale they hold?
The Asians are a great buy...I have bought several pieces over the last few years at 25-35% of MSRP 10-18 months after it was introduced
The high end audio components street price tends to be fairly close to their incredibly high MSRP
But as someone told me years ago
A product is only worth what the market is willing to pay ..no more and no less
Warren
Rm 1 Samsung 65KS9800 Marantz 8802A prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Vizio P50 Denon 4520 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 55KS8000 Pioneer SC95 Mirage Omni sat speaker system
turnne1 is offline
post #12623 of 13537 Old 03-07-2015, 04:59 AM
turnne1's Avatar
Liked: 473
absolutely accurate
I follow the same path you do and start thinking about a new unit when I find a deal somewhere in the 25-35% range of what the MSRP was
Warren
turnne1 is offline
post #12624 of 13537 Old 03-07-2015, 05:10 AM
DrMichael's Avatar
Quoted: 116 Post(s)
Liked: 85
So I just found*
post #12625 of 13537 Old 03-07-2015, 05:33 AM
kbarnes701's Avatar
Liked: 5249
When the disc has a flag to tell it to turn it on. The only one I can recall that has the flag set is Iron Man (the first movie).
Dave Vaughn likes this.
post #12626 of 13537 Old 03-10-2015, 03:49 AM
con219's Avatar
Quoted: 61 Post(s)
Liked: 51
I have just acquired a near new 8801 coming from the Denon 4520. Must say I noticed the improved audio straight away.
I have been using my 4520 as a pre pro.
I think I will be hanging onto the 8801 for a while as I have divorced myself from the "early adopter scene" a couple of years ago and I have noticed how healthy my bank account looks.
audiofan1 likes this.
con219 is offline
post #12627 of 13537 Old 03-10-2015, 12:12 PM
twinturboaudi's Avatar
Quoted: 48 Post(s)
Liked: 25
I've tried all options except reading the manual. How does one turn off the blue ring?
twinturboaudi is offline
post #12628 of 13537 Old 03-10-2015, 12:26 PM
audiofan1's Avatar
Quoted: 1781 Post(s)
Liked: 1818
Behind the flip down panel, press and hold display for 4 seconds
audiofan1 is online now
post #12629 of 13537 Old 03-10-2015, 12:45 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3824
I always recommend reading the manual as a first resort !
We still have one brand spanking new 8801 " cheap " - and it comes with a manual to read.
post #12630 of 13537 Old 03-11-2015, 02:42 PM
Quoted: 48 Post(s)
Liked: 25
Thank you. That worked perfectly. A simple, straightforward answer is always appreciated on my end.
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
