Marantz AV8801 Preamp/Processor Official Owner's thread - Page 423 - AVS | Home Theater Discussions And Reviews
post #12661 of 12672 Old 03-24-2015, 07:58 AM
grigorianvlad's Avatar
Quoted: 68 Post(s)
Liked: 596
In a 5.1 setup, there are no SBL/SBR speakers which only exist in a 7.1 setup. Connect the speakers to the SL/SR speaker posts. Ideally these speakers should be placed to the side of your main listening position but regardless of whether you physically place them behind your couch, they are still considered side surrounds.
Thank you JDSmoothie and everybody else. After switching SBL/SBR to SL/SR the magic "Skip Error" button appeared and I can finish running Audyssey.
grigorianvlad is online now
post #12662 of 12672 Old 03-24-2015, 08:11 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3341 Post(s)
Liked: 2079
Wohoo! Now back to our regularly scheduled programming.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #12663 of 12672 Old 03-24-2015, 08:31 AM
Quoted: 68 Post(s)
Liked: 596
LOL, not really. After running Audyssey the old problem with not enough encodings shows up. Where did they all go? I love DTS Neo X, sounds amazing! Now it only shows these , and in any of the choises - MOVIE, MUSIC or GAME. I pushed the buttons on the unit, but this time it didnt create more encodings like PL or NEO. How do I get them back?
Much obliged, gentlemen!
post #12664 of 12672 Old 03-24-2015, 08:34 AM
AustinJerry's Avatar
Quoted: 2154 Post(s)
Liked: 1162
Something is not right. Can you post a screenshot of the speaker configuration? If you have a 5.1 configuration, you should be getting Dolby PLII Cinema as a choice.
AustinJerry is online now
post #12665 of 12672 Old 03-24-2015, 08:54 AM
Quoted: 68 Post(s)
Liked: 596
Thank you for the idea. Indeed, I checked the speaker settings, as you posted. It said 5.1, which is correct. But Neo X takes 5.1 and basically converts it to 9.1 or 11.1. If the speaker configuration is 5.1 it cannot upprocess the signal because there are not enough speakers to play with for the end result. I changed it to 11 speakers and Neo X and bunch of other encodings showed up immediately.
You have been a tremendous help, thank you!
ID:	622025   Click image for larger version
ID:	622033   Click image for larger version
post #12666 of 12672 Old 03-24-2015, 09:13 AM
Selden Ball's Avatar
Quoted: 1253 Post(s)
Liked: 671
Also, some options don't appear unless you actually have an incoming signal. (E.g. the decoder needed for a particular type of input signal.)
audiofan1 likes this.
Selden
Marantz SR7009+MM9000/Atmos 7.1.4 (FH+TM:DefTech PM1000)/LCR+TM amped
Selden Ball is offline
post #12667 of 12672 Old 03-24-2015, 10:05 AM
Liked: 1162
Still not understanding. How many speakers do you actually have? 5.1, 7.1, 9.1, or 11.1?
And I still don't see the right choices in your screen shot. I should be seeing Dolby Digital, Dolby DigitalEx (if you have at least 7.1), and PLII Cinema. As Seldon says, you must be feeding the AVR a 5.1 signal to see these choices.
What are all those MULT CH IN choices? How are you feeding the signal to the AVR, through the 7-channel analog inputs, or using a HDMI connection?
post #12668 of 12672 Old 03-24-2015, 11:01 AM
Quoted: 68 Post(s)
Liked: 596
Sorry, English is my third language. I must not have been clear.
I have 5.1 speakers.
The following choices show up in the MOVIE mode if I fake 9 or 11 speakers in Speaker Configuration:
STEREO
DOLBY PLIIz MOVIE
DOLBY PLIIz MOVIE
DTS NEO X: CINEMA
PLx MOVIE: ADX (Wide/Height)
PLx MOVIE: ADX (Wide)
PLx MOVIE: ADX (Height)
MULTI CH STEREO
VIRTUAL
I am feeding HDMI from a BluRay player, so probably Dolby Digital 5.1
But if I change Speaker Configuration to the actual number - 5.1 - then I only see the four choices:
STEREO
DOLBY PLII MOVIE
DTS NEO X: CINEMA
MULTI CH STEREO
VIRTUAL
Is this how it is supposed to work. Also, what is strange is that if I set number of speakers to a higher number than I have STEREO sounds about 5dB quieter. But this is STEREO! It should use the same two speakers. It should not be sending bits and pieces of the signal to the speakers I dont have. But it does sound quieter for sure.
post #12669 of 12672 Old 03-24-2015, 11:14 AM
bweissman's Avatar
Quoted: 75 Post(s)
Liked: 43
You'll see the MULTI CH IN choices if you are feeding the 8801 LPCM as opposed to Bitstream. This is normal.
OPPO BDP-103, Comcast DVR, Sony FMP-X1 4K server
Marantz AV8801 pre/pro, Yamaha MX-A5000 amp
Sony VPL-VW600ES projector, Stewart StudioTek130 103" diag screen
7 Thiel speakers (3 SCS4, 2 PowerPoint, 2 PowerPlane), 2 JL Audio E110 subs
Harmony Ultimate remote
bweissman is online now
post #12670 of 12672 Old 03-24-2015, 11:43 AM
Liked: 1162
STEREO
DOLBY PLIIz MOVIE
DOLBY PLIIz MOVIE
DTS NEO X: CINEMA
MULTI CH STEREO
VIRTUAL
STEREO
DOLBY PLII MOVIE
DTS NEO X: CINEMA
MULTI CH STEREO
VIRTUAL
PLIIx, Neo:X and DSX are all modes requiring more speakers than 5.1. Why are you trying to trick the AVR into playing modes without the proper number of speakers?
post #12671 of 12672 Old 03-24-2015, 12:54 PM
Quoted: 68 Post(s)
Liked: 596
I had SBL/SBR connected. They stayed ON in the menu after I connected SL/SR, so I saw more choices of codecs than my speakers can supports. Of course, there is no point in using Neo and others if i dont have that many channels. Thanks
post #12672 of 12672 Unread Today, 09:02 PM
Quoted: 68 Post(s)
Liked: 596
I apologize for being the one who posts here the most. I have a question. I tried to connect my HDMI headphones to the Marantz. It didnt work. I think I know the reason. Basically, the headphones need a regular HDMI out from the processor, both video and audio or audio only. But the Marantz probably outputs video HDMI only from monitor 1, 2 and HDMI out zone 4. How do I switch Marantz so it outputs HDMI audio out to TV. Here is how it is connected now. I took HDMI from the Marantz monitor out, connected it to HDMI headphones processor in, from the headphones I used HDMI out marked "to TV" nad connected it to TV.
In the Pioneer (my previous AVR) I had to go to AVR audio parameters and switch HDMI=>AMP to HDMI=>THROUGH. It basically made the Elite silent (bypassed audio) while video worked fine to TV. But the headphones would immediately turn on. There is gotta be a similar function/button in the AV8801. What is it?? Thanks.
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
Gear in this thread - Av8801 by PriceGrabber.com
