Marantz AV8801 Preamp/Processor Official Owner's thread - Page 427 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
post #12781 of 13500 Old 04-22-2015, 05:32 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3091 Post(s)
Liked: 3021
Originally Posted by AustinJerry View Post
Do you have price protection that covers the one that you sold me at the end of last year? I guess I should have waited...
The boss wasn't on vacation that week !
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #12782 of 13500 Old 04-22-2015, 08:02 PM
turnne1's Avatar
Quoted: 1755 Post(s)
Liked: 410
better than the black Friday deal I received?....
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is offline
post #12783 of 13500 Old 04-25-2015, 03:35 AM
grigorianvlad's Avatar
Quoted: 120 Post(s)
Liked: 611
I have a problem. My surround HDMI headphones dont work with the AV8801. They did work fine with my previous AVR, a Pioneer Elite VSX-53. I am attaching a screenshot of connections. It is in Japanese (they are sold there mostly, there is no English manual, sorry), but the diagram is pretty simple and does not need a translation. Basically, monitor out from AV8801 goes into the headphones processor , from there HDMI out goes into the TV. Simple. But it does not work. The only explanation thaat comes to mind is HDCP or a higher HDMI version in the AV8801 as opposed to the Pioneer Elite I used to have.
There are a couple of workarounds.
1) Get a 6.35mm 1/4" Stereo plug to 2 x RCA Female Socket Audio Headphone Adapter, connect headphones out on the AV8801 and it will work (I hope). I dont want to go this route because the surround capability will be lost. Besides, this ugly adapter and unsightly RCA cables will be hanging on the front panel of the otherwise gorgeous Marantz!
2) Connect Media Server RCA out on the back panel of the Marantz. This is what I have now. The problem that this ONLY sends the Media Server audio to the headphones, BluRay, DVR and all other sources do not.
Question: why wouldn't HDMI work with the headphones? What would you suggest I do? Thanks a lot.
DAC: Wyred4Sound DAC1LE || Processor: Marantz AV8801 11.2 Ch || Power Amps: Audio Research VS110 (100W tube) || Emotiva XPR-2 (600W), Emotiva XPA-5 Gen 2 & UPA-500 (200W/80W) || L/R Speakers: Eminent LFT-8b , Magnepan 2.7, Center : Polk LSiM-704C, Sur: Polk LSiM-703 || Sub 1: Rythmik F25 (800W). Sub 2: Sunfire True Signature TS-EQ12 (2,700W) || Cables: MIT terminator 2 Biwire, 4, Exp; Cardas Crosslink || Power: Panamax M5300 || HP: HifiMan HE560
grigorianvlad is offline
post #12784 of 13500 Old 04-25-2015, 03:46 AM
jdsmoothie's Avatar
Quoted: 12249 Post(s)
Liked: 5579
If connected to one of the main zone HDMI outputs, the "HDMI Audio Out" setting would have to be set to "TV" in order to pass the audio along with the video, otherwise the Zone 4 HDMI Out will pass audio/video by default.
grigorianvlad likes this.
jdsmoothie is online now
post #12785 of 13500 Old 04-25-2015, 05:04 AM
Quoted: 120 Post(s)
Liked: 611
I cannot tell you how much I appreciate your help, JD. Switching to "TV" did the trick! This is the third problem you helped me resolved. Thanks a lot.
WLGeter likes this.
post #12786 of 13500 Old 04-25-2015, 05:09 AM
jdsmoothie's Avatar
Liked: 5579
Note also that if using an analog connection to headphones, you can also connect to either the Zone 2/3 pre-outs or the Media Player analog output (mirrors Zone 2 pre-out) but doing so would not pass HDMI sources, rather only analog and networking (unlike the newer AV8802 which can also pass 2.0 HDMI and optical/digital coax to Zone 2).
post #12787 of 13500 Old 04-25-2015, 05:51 AM
Quoted: 120 Post(s)
Liked: 611
It all works now. For a minute there was another issue. I tested the BluRay player. The signal was DTS-HD MSTR on disk. But the AV8801 showed "Stereo". As soon as I switched from "TV" to "AVP", the signal was correct, but there was no sound in the headphones. But as soon as I switched back to "TV" the Marantz showed the correct DTS-HD MSTR and headphones started to work as well. Must have reset somehow. So, it all works now.
So, thanks guys!
post #12788 of 13500 Old 04-25-2015, 11:38 AM
edfowler's Avatar
Quoted: 153 Post(s)
Liked: 83
Is there a way for me to do a firmware update if the networking card is not present in my 8801? I bought it 'for parts or not working' and it is missing the network card.
edfowler is offline
post #12789 of 13500 Old 04-25-2015, 01:44 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6635 Post(s)
Liked: 3662
Not that I know of. An 8801 without network connectivity is really crippled. No web access. No configuration load/save. No network apps. No firmware update. Have you considered purchasing a network card?
AustinJerry is online now
post #12790 of 13500 Old 04-25-2015, 03:49 PM
edfowler's Avatar
Quoted: 153 Post(s)
Liked: 83
Maybe, but a network card costs $234. If I buy one of those then I will have $335 in it. I don't know if it is worth that to me since I only use it for two channel playback.
edfowler is offline
post #12791 of 13500 Old 04-25-2015, 03:53 PM
jdsmoothie's Avatar
Liked: 5579
Not as an owner, no. A repair facility could likely do it though.
post #12792 of 13500 Old 04-25-2015, 03:56 PM
edfowler's Avatar
Quoted: 153 Post(s)
Liked: 83
Problem is, I cannot get in contact with the Marantz repair facility closest to me. They don't answer their phone or respond to emails.
edfowler is offline
post #12793 of 13500 Old 04-25-2015, 05:19 PM
Liked: 3662
Wow, $335 invested in a $3,000 piece of equipment. What were you thinking?
Why do you think you need a firmware update? Are you missing a feature, or having an issue?
post #12794 of 13500 Old 04-25-2015, 05:40 PM
edfowler's Avatar
Quoted: 153 Post(s)
Liked: 83
I am not having any issues, I have just read in a few places that a certain firmware update had improved the sound quality or something like that.
And thanks for noticing my fortunate investment. There was one other guy that tried to snipe the auction but I was fortunate enough to bid $101.99 while he tried to snipe in at $101.00 even. I don't think I will ever run across a deal like that again. I will have to hand it to the seller too. He packed it very well and went through with the sale even though it was a give away. I'm just tickled that it works.
It was missing the network card, two knobs, and the top and side covers. I think I may make my own covers out of copper and the knobs are cheap. Like I said though, the only thing I would use the network card for would be firmware updates.
It does sound nice
edfowler is offline
post #12795 of 13500 Old 04-25-2015, 06:04 PM
turnne1's Avatar
Liked: 410
I certainly hope no one actually paid $3000...
It does sound nice
sounds like a good deal
IMO...I would not invest that amount in a network card
Warren
turnne1 is offline
post #12796 of 13500 Old 04-28-2015, 12:10 AM
Liked: 0
Originally Posted by btran33 View Post
Hi Everyone:
I tried to search for this problem but can't seem to find a solution. Last night, when listened to music I started to notice that the Front Left Channel volume was lower than the right.
Bao Tran
I have an AV8801 and I have found a similar fault but with the right hand channel. I am not using balanced interconnects, but phono cables.
I tried the usual things e.g. swap cables and change amp channel but to no effect.
I contacted the suppling dealer, and after trying a factory reset which didn't wori, they arranged for collection so they could test the unit themselves. They tested it and confirmed the right hand channel volume was faulty.
It was then returned for repair back to Marantz. Marantz sent the unit to SST for repair. After a couple of weeks I followed up to find what was happening to be told by an SST engineer that there is no fault with the unit and it is perfect.
I am presuming this must be an intermittent fault, so I pushed a bit further and they are now suggesting as a precautionary measure they want to change the HDMI board.
I was wondering if btran33 managed to get a resolution to the issue he found, or whether anyone else had come across this issue?
eddiesteadygo is offline
post #12797 of 13500 Old 05-02-2015, 07:55 AM
robert555's Avatar
Quoted: 13 Post(s)
Hi Res Audio File
I just bought my first Hi Res album that I play through I-Tunes hard wired to my Marantz 8801. The file size is about 20 times a 256 kpbs file
at 192/ 24. Do I have to adjust any audio setting in the 8801 for the DAC's to play 192/ 24 files or is it done automatically? Thanks.
robert555 is online now
post #12798 of 13500 Old 05-02-2015, 08:06 AM
Audiojan's Avatar
Quoted: 18 Post(s)
I think I know the answer already, but just in case that I missed it… The 2 subwoofer outputs can't be designated as front and rear, can they? I'd like to use 2 of my subwoofers for the front and the other output for rear speakers only.
"Suddenly the thought struck me, my floor is someone elses ceiling" - Nils Ferlin
Audiojan is offline
post #12799 of 13500 Old 05-02-2015, 08:47 AM
Liked: 3662
Subs receive re-directed bass from any speakers set to Small. It is not possible to separate the speakers into two groups and re-direct a group's bass to a specific subwoofer. So the answer is no.
Since low frequencies are omnidirectional, it is not likely that you would hear any difference anyway, were this possible.
post #12800 of 13500 Old 05-02-2015, 10:31 AM
Audiojan's Avatar
Quoted: 18 Post(s)
Thanks AustinJerry. That's what I was afraid of. The reason why I'd like to do this is so I can use one set of subwoofers with the front speakers (i.e. when listening to stereo music) and the other set only when watching movies. I guess I can figure out a way to remote control the power outlet (ZigBee for example) for the rear subwoofers...
Audiojan is offline
post #12801 of 13500 Old 05-02-2015, 11:30 AM
Liked: 3662
I still don't understand. The overall objective for both music and movies should be smooth, balanced bass. Assuming you have gone to the trouble to make sure the subs are positioned for best bass response, the combined output of four subs is likely to be much smoother than just two subs. And since the bass is Omani-directional, you won't be able to isolate the rear subs when listening to two-channel stereo music.
This assumes, of course, that all your subs are of reasonable quality and closely matched. If the front subs are significantly better quality, or different output, then perhaps my conclusion would be different.
So, I don't mean to be disrespectful, but I think your objective is flawed.
post #12802 of 13500 Old 05-14-2015, 02:53 PM
baranowski's Avatar
Quoted: 41 Post(s)
Does anyone use the Ir extender for the marnatz? the RX101?
I am looking for your thoughts and possible one to try.
shoot me a PM.
Bill
baranowski is offline
post #12803 of 13500 Old 05-21-2015, 12:09 PM
Mikenificent1's Avatar
Quoted: 76 Post(s)
Just curious why you dumped the 7702 for the 8801 in the first place? From a lot of accounts, including my own, the preference is the sound and format of the 7702 over the 8801.
Does anyone else agree with this? Is this with an apples to apples comparison? i.e. no Atmos etc. The 8801 has better build quality, chassis, transformer, made in japan, and 32-bit DAC's etc.
Mikenificent1 is offline
post #12804 of 13500 Old 05-22-2015, 07:04 PM
HB GAMER's Avatar
We still have one new 8801. The boss is on vacation - so I can sell it dirt cheap ! Give us a call at AV Science if interested.
Totally interested. PM me a price. My Onkyo HDMI bit the dust! Done with them.
HB GAMER is offline
post #12805 of 13500 Old 05-22-2015, 10:03 PM
skimrn's Avatar
Quoted: 18 Post(s)
Liked: 9
Please help! I just hooked up my new AV8801 and I just cant get 2 channel stereo into Pure Direct mode. I am using my bluray player as CD player and every time I try pure direct, I get multi channel which my stereo sound comes out of all my surround speakers!
I just want to be a purist 2 channel stereo CD! Please help.
skimrn is offline
post #12806 of 13500 Old 05-23-2015, 01:27 AM
jdsmoothie's Avatar
Liked: 5579
Sold last month; however, the newer AV8802A (w/HDCP 2.2 upgrade) is now available.
post #12807 of 13500 Old 05-23-2015, 01:30 AM
jdsmoothie's Avatar
Liked: 5579
You select the various surround modes by pressing either the MOVIE, MUSIC, GAME, or PURE buttons on the remote. If you want PURE DIRECT, select the PURE button until you see PURE DIRECT.
post #12808 of 13500 Old 05-26-2015, 10:12 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 3021
Sorry - it's gone!
post #12809 of 13500 Old 05-29-2015, 10:38 PM
Quoted: 182 Post(s)
Liked: 42
How are the signals routed on the 8801? If I am connecting an external dac to the xlr inputs, is there any noticeable sound quality loss in pure direct mode in comparison to connecting the external dac (with volume control) directly to a power amp?
STIGUY2014 is offline
post #12810 of 13500 Old 05-31-2015, 12:40 AM
Quoted: 182 Post(s)
Liked: 42
Well I went ahead and purchased the AV8801 and should have it next week. I got a great deal on it since it is discontinued. I got it because I just could not get the surround sound stage field correct using just the outputs from the Oppo 105D going to volume control and then to amps. Although sound was coming from all speakers, there was virtually no panning of the sound. I decided I need a dedicated surround processor. I hope it will be able to correct my problem.
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
