Marantz AV8801 Preamp/Processor Official Owner's thread - Page 428 - AVS | Home Theater Discussions And Reviews
post #12811 of 12819 Old 05-31-2015, 08:51 AM
Bookedup's Avatar
Originally Posted by STIGUY2014 View Post
Well I went ahead and purchased the AV8801 and should have it next week. I got a great deal on it since it is discontinued. I got it because I just could not get the surround sound stage field correct using just the outputs from the Oppo 105D going to volume control and then to amps. Although sound was coming from all speakers, there was virtually no panning of the sound. I decided I need a dedicated surround processor. I hope it will be able to correct my problem.
Hi Stiguy,
Did you find a slammin deal on your 8801? I'm in the market. How extensive was your research? Can you share?
Rob
Bookedup is offline
post #12812 of 12819 Old 05-31-2015, 11:17 PM
chingon510's Avatar
Best buy seems to have reduced the price significantly if anyone is in the market for one
chingon510 is offline
post #12813 of 12819 Old 06-01-2015, 05:26 AM
turnne1's Avatar
Quoted: 1156 Post(s)
Liked: 250
It would be pretty hard to find an 8801...unless you went to a Magnolia Design Center
They were special order at Magnolia Home Theater
the 7701( and 7702) though is in stock at most of the larger Magnolia Home theaters
I have seen 7701's for as low as $650 recently there
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 LG 47LE8500 Denon 4520 Celestion 305 speaker system
Rm 3 Samsung 51E8000 Pioneer SC77 Kef 2005.2 speaker system
Rm 4 Panasonic 50ST50 Onkyo 5009 Mirage Omni sat speaker system
turnne1 is online now
post #12814 of 12819 Old 06-01-2015, 05:50 AM
chingon510's Avatar
I just meant going to bestbuy.com search av8801 and add to cart and they have them available to ship.
post #12815 of 12819 Old 06-01-2015, 10:04 AM
btran33's Avatar
Hi:
I'm very sure the answers is NO, however just checking to see if anyone knows how to create, save and recall two difference profiles for the Audyssey? OK, let me explain...I have two amplifiers, one is the multichannel amp for movie and one small tube amp for music. I love what the Audyssey XT32 has done to correct my room with the multichannel amp, so I want to see if I can create a diff. profile for the tube amp and just recall that profile when I swap out the amp for music.
thanks
BT
btran33 is offline
post #12816 of 12819 Old 06-01-2015, 10:23 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 4123 Post(s)
Liked: 2279
You can save multiple configurations (using the Web Control feature, p. 106 Owner's manual) to a PC by simply assigning a different file name to each configuration. You would then LOAD each file when you wanted to use it. Each SAVE/LOAD process takes about 10 minutes each.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #12817 of 12819 Old 06-01-2015, 12:02 PM
btran33's Avatar
Oh...so there is a way...just not an easy way!
btran33 is offline
post #12818 of 12819 Old 06-01-2015, 12:08 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2279
Correct. Although you cannot store multiple configurations on the pre/pro itself, you can using the Web Control feature.
post #12819 of 12819 Unread Today, 02:43 PM
Quoted: 35 Post(s)
Liked: 8
There are many vendors selling the AV8801 at $1500 brand new with free shipping. Music Direct, Amazon, Crutchfield. If you just search for "AV8801 sale" in Google you will still find many that have it in stock. I think this is the lowest price it will ever get before inventory runs out.
STIGUY2014 is online now
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
Gear in this thread - Av8801 by PriceGrabber.com
