Marantz AV8801 Preamp/Processor Official Owner's thread - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 294Likes
post #1261 of 13537 Old 12-28-2012, 11:11 AM - Thread Starter
exm
exm's Avatar
Quoted: 136 Post(s)
Liked: 83
Originally Posted by hifiaudio2 View Post
Markertek has good XLR cables at good prices.
http://www.markertek.com/Cables/Audio-Cables/XLR-to-XLR-Cables/TecNec/SC50XXJ-B.xhtml
Bluejeans cable does too, although maybe a bit more expensive.
I am using BJC, which I think offer a great price/performance point.
exm is offline
post #1262 of 13537 Old 12-28-2012, 11:43 AM
Quoted: 1701 Post(s)
Liked: 731
Originally Posted by cat3600 View Post
I had the Cary Cinema 12 sold it and was wondering about the sound quality of the 8801 vs it. The Cary does have true balanced connections though.
The next question has to be "does your amp also have true balanced connections?"
I don't think mine does but for whatever reason, on my previous system, XLRs were quieter than RCA cables.
JimP is offline
post #1263 of 13537 Old 12-28-2012, 12:05 PM
audiofan1's Avatar
Quoted: 1821 Post(s)
Liked: 1867
Get good cables regardless of price! I use Morrow audio's MA3 & MA4 balanced cables and also AudioQuest Columbia rca and balanced and yes balanced in my setup does sound better, if you have to spend more for a better sounding cable then you have to spend more for a better sounding cable! $3599 on your pre should say enough! You wouldn'd buy a BMW M5 and put wagon wheels on it ! oh yeah! it can get the job done but how do they handle that raw power on tight turns?tongue.gif
audiofan1 is offline
post #1264 of 13537 Old 12-28-2012, 01:34 PM
Diesel 48's Avatar
Quoted: 71 Post(s)
Liked: 33
Is the only way to adjust level trims through the setup menu? Ran audyssey but want to up the bass a bit. Also do the trim levels stick per source or globally.
Diesel 48 is offline
post #1265 of 13537 Old 12-28-2012, 02:20 PM
cat3600's Avatar
Yes my Cary cinema 7.125 does have balanced connections!
cat3600 is offline
post #1266 of 13537 Old 12-28-2012, 03:12 PM
joerod's Avatar
Quoted: 719 Post(s)
Liked: 653
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is online now
post #1267 of 13537 Old 12-28-2012, 11:48 PM
Ian13's Avatar
was just wandering if anyone would know if the 4K upscaling on the AV8801 would have a noticeable difference when upscaling SDVD's compared to units like the AV7005 that upscale SDVD's to 1080P?
Ian13 is offline
post #1268 of 13537 Old 12-29-2012, 05:35 AM
Rosano's Avatar
Well my baby finally ariived....so now I have to find the time to start playng ! I will aslo take the opportunity to do a major clean up with wiring and getting rid of stuff I really don't need anymore like a tuner etc....I haven't been back there for so long ! Now I will put my Lex MC12 HD for sale.....its fully loaded and I even have the mic kit....wonder what its worth.
Rosano is offline
post #1269 of 13537 Old 12-29-2012, 05:53 AM
Liked: 731
In my setup, I find that I like it better with Audyssey turned off. Just a tad more dynamics with it off. A little clearer too.
Anyone else?
.....I do have an assortment of accoustical panels around the room. That may account for the difference.
I'll rerun Audyssey in another week and see if the additional burn in makes a difference.
JimP is offline
post #1270 of 13537 Old 12-29-2012, 06:23 AM
Diesel 48's Avatar
Quoted: 71 Post(s)
Liked: 33
I can confirm that the av8801 does sound better than my older Onkyo TX-SR805. Well they should as they really are not even in the same league. I feel like all of my speakers opened up. I am just running 5.2 as I have an older 5 channel outlaw audio amp. I think it was their 250watts per channel one about 7 years ago. I am using ascend acoustic speakers and they have never sounded better. I am running everything in a dedicated room with lots of bass traps and panels on the walls. The room is roughly 13ft wide by about 16ft long. Right now I am running the originally sb-13 ultra in the front and a PCi-25/39 in the back. It is one of there older subs. My question is should I put both subs up front? Just curious on peoples opinions. One front and one back with their phase at 0 degrees sounds pretty good. First time running dual subs.
post #1271 of 13537 Old 12-29-2012, 06:46 AM
thrang's Avatar
Quoted: 1934 Post(s)
Liked: 1626
Anyone else?
Audyssey can be a love hate, or at leas like dislike relationship. But lately I have been liking and loving - for me audyssey pro is a substantive benefit with the 8801.
Of course I just ripped out o huge wall unit and change four speakers so ill be re-running again....whoop whoop whoop whoop....
thrang is online now
post #1272 of 13537 Old 12-29-2012, 08:46 AM
Rosano's Avatar
Jim...I find your comment intersting....i am very curious to use Audessy but I will run the system for sure with out it for a while and see how things go.....I like to get all the basic stuff done first and out of the way before applying any correction or auto this and auto that.
I am sure the answer is yes but since I am new to the 8801 and reading the manual before i start playing..whats the simple way of turning Audessy on and off....is there a one button deal or do i have to navigate in the menus....is there an easy way to do a comparison?
Rosano is offline
post #1273 of 13537 Old 12-29-2012, 08:54 AM - Thread Starter
exm
exm's Avatar
Quoted: 136 Post(s)
Liked: 83
Let us know your impressions... I used to own Lexicon processors before I moved to Marantz. You can put your old Lexicon on either eBay or Audiogon.
exm is offline
post #1274 of 13537 Old 12-29-2012, 08:56 AM
Rosano's Avatar
Thanks I will give it a shot....any idea of what they are selling for?
Rosano is offline
post #1275 of 13537 Old 12-29-2012, 09:04 AM
dryeye's Avatar
Quoted: 126 Post(s)
Liked: 89
Rosano as a fellow MC12HD owner and while you are getting to know your new AV8801 I'd sure appreciate if you would please help me out with a question I posted a few pages back that went unanswered.
I am considering this model as a replacement for my beloved Lexicon MC12HD even though that unit still meets most of my needs. Would someone who already has posession of one test for the ability to reuse a HDMI video signal and map it to another input?
What I want to replicate is the way I have an input customized on my Lexicon unit. Specifically I'm looking for the ability to use the HDMI audio and video output of my cable box as say input 1 of the AV8801 and reusing the same cable box HDMI video only portion with the SPDIF audio of my CD player. This way I can play music and watch television at the same time and swap between the two by pressing just one button when the television program looks interesting.
dryeye is offline
post #1276 of 13537 Old 12-29-2012, 10:10 AM
Liked: 731
A simple approach is to run Audyssey so that levels and distances are set and then turn it off. You also have to change some other setting dealing with dynamic range.
To turn Audyssey on/off, go to setup, audio, audyssey, highlight with enter then left arrow to turn off. There may be a single button on the remote way of doing it but I haven't read about it yet. Let me know if there is such a way.
JimP is offline
post #1277 of 13537 Old 12-29-2012, 11:47 AM
jdsmoothie's Avatar
Quoted: 15037 Post(s)
Liked: 7255
What I want to replicate is the way I have an input customized on my Lexicon unit. Specifically I'm looking for the ability to use the HDMI audio and video output of my cable box as say input 1 of the AV8801 and reusing the same cable box HDMI video only portion with the SPDIF audio of my CD player. This way I can play music and watch television at the same time and swap between the two by pressing just one button.
Although not possible with the HDMI input, possible if you also connect a component video cable from the cable box to the 8801 and use that video source with your music source via the "Video Select" feature (p. 136 OM). Other option is to connect HDMI to the TV with optical to the 8801.
jdsmoothie is offline
post #1278 of 13537 Old 12-29-2012, 12:30 PM
audiofan1's Avatar
Liked: 1867
Anyone else?
I found I lean a little to Audyssey flat, as it seems more akin to what I'm use to coming from the analog outs of an Oppo 95, seems to be a good mix of both with an overall increase in dynamics and better soundstage and surround integration, having said that I haven't watched enough movies to say its my preferred setting its as you say still burning in!
post #1279 of 13537 Old 12-29-2012, 01:18 PM
stieger's Avatar
I had the 7705, really enjoyed it. Sold it, now have a 80.1 (wanted THX), but realize the 7705 sounded better (duh). Anybody do a direct comparison between the 7705 and the 8801? Just curious how much better it may actually sound on movies/BD? Oddly, I sold the 7705 for a very hi-end piece, and honestly didn't notice much of a difference (cost difference was over $10K, so diminishing returns really came into play on this one - yes, dedicated HT room with Triad in-room golds...).
stieger
We Make Home Theater A Reality
stieger is offline
post #1280 of 13537 Old 12-29-2012, 01:29 PM
jdsmoothie's Avatar
Liked: 7255
The general consensus of owners is there is a very noticeable improvement in audio fidelity upgrading from an XT model (7005) to XT32 (4520CI or 8801).
erhurd likes this.
post #1281 of 13537 Old 12-29-2012, 01:47 PM
dryeye's Avatar
Quoted: 126 Post(s)
Liked: 89
Thanks very much jdsmoothie.
dryeye is offline
post #1282 of 13537 Old 12-29-2012, 02:27 PM
Geronimo.USMC's Avatar
Quoted: 153 Post(s)
Liked: 96
Originally Posted by GerryWaz View Post
I also currently have a Denon AVR4311ci and am thinking about getting the AV8801/MM8077. Can you speak more about how you feel the sound quality is better than the 4311ci and how you are enjoying it better?
TIA!
P.S. for Everyone: I've read the entire thread (and other web pages on the subject) and am confused by connecting the AV8801 to an amp. Do most folks do unbalanced or balanced? I've never had separates before and am a bit of noob on the subject
I get waaaaay better separation now, while still having my bass smoothed out, & better integrated throughout. Very good/fast dynamics, and oh so quiet....then "BAM!" when it needs to be. To me, my 4311CI was way too harsh & overly bright on music no matter what I did, or how many 8pt calibrations. Personally, I would do XLR just b/c of the robust connection and added gain, which helps in calibration levels sometimes. I have XLR on my front 3 channels and on both of my subs, but use RCA on all 4 of my rears.
SOUND: 7.2 via Marantz AV8802A | Wyred4Sound monoblocks + Halo A51 | Paradigm 100'sV5, ADP590'sV5, 690v5, 20v5's | Dual SVS SB16-ULTRA Subs
VIDEO:
SONY OLED 65A1E | OPPO UDP-203 and SONY UBP X800 UHD Blu Ray Players
- 40TB of Blu ray .iso's in a Synology DS1815+ controlled by a Dune Solo 4K
- HTPC/Gaming Rig:
Silverstone CW02B, Core i7-5820K, ASUS X99-A, 16GB, EVGA GeForce GTX 1080 SC GAMING ACX 3.0, Auzen HDMI XFi
Geronimo.USMC is offline
post #1283 of 13537 Old 12-29-2012, 02:31 PM
comfynumb's Avatar
Liked: 411
Hi guys, I've been following this thread and others for awhile now, so I decided to join AVS. I'm ordering the AV8801 Monday and was looking for your thoughts on connecting it to my Sunfire cinema grand amp via XLR cables. The way I see it is, the #1 and #2 pins are reversed on the Marantz (European design). Some are saying it will connect to my amp without a problem, it just reverses the polarity. But the way I see it is, I'll be plugging the hot off the 8801 into the ground on my amp not the negative. That doesn't sound good to me. Your help would be appreciated, thanks.
comfynumb is offline
post #1284 of 13537 Old 12-29-2012, 03:13 PM
GerryWaz's Avatar
Quoted: 42 Post(s)
Liked: 27
Thank you for your thoughtful reply smile.gif.
And thanks also to those who commented on the XLR/RCA connectors question. Much appreciated. smile.gif
Sony XBR-75Z9D | Lumagen Radiance Pro 4446 | Marantz AV8802A | Marantz MM8077 (2) | Denon AVR4311ci | Denon AVR3311ci | Oppo UDP-205 | Roku Ultra | NVidia Shield | Joseph Audio Pulsar (2) | Joseph Audio RM7si (6) | Martin Logan Motion AFX (4) | JL Audio e112 SW | RSL Speedwoofer 10 SW | Goldenear Aon 3 (2) |
GerryWaz is offline
post #1285 of 13537 Old 12-29-2012, 03:54 PM
jh901's Avatar
Quoted: 515 Post(s)
Liked: 186
Ah. My current plan involves the 7 channel Cary. I have the 200.2 for my stereo system. Wouldn't mind a 7 channel like the 200.2!!
Balanced (versus unbalanced) gets a bad rap or is otherwise under appreciated since the presence of XLR ins or outs is presumed to indicate legit balanced. Too bad.
HT: Panasonic DMP-UB900 | JVC RS600 | 106" x 45" Stewart ST 100 | Marantz AV7005 | NAD M27 | Elac Uni-Fi UF5, UC5, Debut B6; Focal CMS Sub
Stereo: Cary Audio 306 SACD Pro | Cary Audio SLP-05 tube line level | Cary Audio SA-200.2 | Focal Diablo Utopia III
Den: 60" Panasonic VT60
jh901 is offline
post #1286 of 13537 Old 12-29-2012, 04:07 PM
DHF
DHF's Avatar
No worries. It will connect without a problem. I have it connected via XLR to a SimAudio, and previously to a Sherbourn amp without any issues.
On the whole XLR thing, I did it with expensive cables and heard absolutely o difference between that and RCAs. I just like that the XLRs snap into place.
comfynumb likes this.
DHF is offline
post #1287 of 13537 Old 12-29-2012, 04:12 PM
DHF
DHF's Avatar
stieger
I had the AV7005. Very noticeable improvement in SQ on the 8801. Some is attributable to XT32, for sure. But I believe there is more to it than just XT32. The sound is much more detailed. Makes listening to old favorites fun again. On movies and TV, same level of detail is apparent. It is a big upgrade in SQ.
DHF is offline
post #1288 of 13537 Old 12-29-2012, 06:33 PM
comfynumb's Avatar
Liked: 411
Thanks for the reply DHF and the info. I guess the statement from Marantz about it may not connect properly has mr worried.
post #1289 of 13537 Old 12-29-2012, 08:25 PM
jima4a's Avatar
Quoted: 287 Post(s)
Liked: 153
It is interesting how many touted the 4311 as a great prepro but now so many saying how much better the 8801 is for SQ. I am not yet a big Audyssey fan for music but am interested in how good the DACs and analog section are for music, not movies. Has anybody compared some of the key competition on the music end?
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is online now
post #1290 of 13537 Old 12-29-2012, 08:44 PM
DHF
DHF's Avatar
Same questions came up on the 7005. I am lucky because I don't read the manuals until way after I have hooked the thing up ;-).
DHF is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
