Marantz AV8801 Preamp/Processor Official Owner's thread - Page 432 - AVS Forum | Home Theater Discussions And Reviews
post #12931 of 12939 Unread 07-28-2015, 08:04 PM
Kal Rubinson's Avatar
Quoted: 271 Post(s)
Liked: 255
Originally Posted by orcrone View Post
Got it. Thanks. I'm beginning to think that it I should just use the front height speakers all the time.
Instead of turning them off, why not just choose an audio mode that doesn't use them.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #12932 of 12939 Unread 07-29-2015, 03:10 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 4825 Post(s)
Liked: 2510
Why would that turn off Audyssey? Is it because I'd be running Audyssey and then removing two speakers - using a different configuration than when Audyssey was run.
It won't.
Originally Posted by Kal Rubinson View Post
Yup. When you change the speaker configuration, Audyssey usually bows out unless you run another calibration.
Note that simply setting a speaker to None should not turn off Audyssey as would changing the AMP ASSIGN setting.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective? Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #12933 of 12939 Unread 07-29-2015, 07:30 AM
Quoted: 271 Post(s)
Liked: 255
If you say so. I vaguely recall some issues with that but I have not tried it in quite some time.
I do wonder why the OP cannot simply avoid modes that use the height channels.
Kal Rubinson
post #12934 of 12939 Unread 07-29-2015, 07:54 AM
orcrone's Avatar
Quoted: 106 Post(s)
Perhaps I need to think this through some more. The height channels are driven by the SpeakerCraft amp which sucks some power and gets fairly hot. The amp is brought out of STANDBY using one of the 8801's triggers. Avoiding modes that use the height channels will kill the height channel outputs of the 8801 but the trigger will still turn on the amp... unless I use the amp's auto sensing instead of the trigger input. Duh!!! I'll give this a try.
orcrone is offline
post #12935 of 12939 Unread 07-29-2015, 08:51 AM
Ou8thisSN's Avatar
Quoted: 140 Post(s)
Do height and wide matrixed channels really add anything? I've never been a fan of extra DSP. If it isnt discrete, I dont mess with it, am I missing out?
Ou8thisSN is online now
post #12936 of 12939 Unread 07-29-2015, 08:59 AM
AustinJerry's Avatar
Quoted: 2976 Post(s)
Liked: 1614
It is purely personal preference. I was running a full 11.1 configuration prior to implementing Dirac Live with a MiniDSP DDRC-88A, which is a 7.1 solution. For action movies, the extra channels would provide some improvement in the experience. For music, I never used the extra channels. Since down-sizing to a 7.1 configuration, I have never for a moment missed the Heights or Wide speakers.
AustinJerry is online now
post #12937 of 12939 Unread 07-29-2015, 09:09 AM
orcrone's Avatar
Quoted: 106 Post(s)
I do find that the height speakers add something when playing the right source material. I watched some scenes that occur during the final battle of the Avengers movie with and without the height speakers and it expanded the audio vertically. With that said it would not be that big a deal if I did not have those channels.
According to Audyssey the front wide channels make more of a difference in the sound, but I don't have those setup.
orcrone is offline
post #12938 of 12939 Unread 07-30-2015, 07:39 PM
turnne1's Avatar
Quoted: 1243 Post(s)
Liked: 264
Originally Posted by kbarnes701 View Post
It's important to understand that there are no sonic differences between XLR and RCA connectors.
XLR are better at noise rejection, so if you have long cable runs and the signal and mains cables run parallel to each other, then XLR can be a better choice. But only if you have any noise issues. If you don't, then the XLR cable won’t bring any benefits.
The XLR connector itself is favored by some as being mechanically superior, but decent RCA cables also make a good connection IME.
XLR output is 6dB higher than RCA and this can be a blessing, a curse, or neither, depending on the rest of your setup.
In short, there is no reason inherent in the differences between XLR and RCA as to why either should be more, or less, suitable for your subwoofer connection, so use whichever you feel most comfortable with.
does this change if the XLR's are "fully balanced"....as in the ultra high end equipment?
I say this..because I have not seen a pre/pro under $11-12K that has fully balanced XLR's
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 LG 47LE8500 Denon 4520 Celestion 305 speaker system
Rm 3 Samsung 51E8000 Pioneer SC77 Kef 2005.2 speaker system
Rm 4 Panasonic 50ST50 Onkyo 5009 Mirage Omni sat speaker system
turnne1 is offline
post #12939 of 12939 Unread Today, 11:49 AM
etc6849's Avatar
Quoted: 82 Post(s)
Liked: 71
I'm not sure why you've had to do resets of the unit. I've never had to do that. I think I did initially run the wizard, but later changed a lot of the settings when I bought the Audyssey Pro kit for it.
At the price you got, you should seriously consider picking up an Audyssey Pro kit with the extra money. Well worth the upgrade if you want the most out of the AV8801.
Until Ultra bluray's are common place and nice 4k projectors are affordable, I don't see the point in going with the much higher priced AV8802a.
Even then, if you use a PC or don't mind an adapter, it will only be a matter of time before some sort of playback option is available (if you are worried about HDCP 2.2).
Originally Posted by turnne1 View Post
Not sure I would pay $1K for a used Marantz 8801...I paid just a little more than that for a brand new unit
Based on the resets I have had to do...not sure I would trust the unit without some sort of warranty
According to what I see in the Marantz paperwork factory warranty does not transfer from the original owner
Premise, a FREE home automation program. Open-source Z-Wave Premise Module found here.
etc6849 is online now
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
Gear in this thread - Av8801 by PriceGrabber.com
