Marantz AV8801 Preamp/Processor Official Owner's thread - Page 441 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
post #13201 of 13503 Old 11-09-2015, 12:18 PM
YellowC4S's Avatar
Got new unit. Set up Audyssey but can't get more sub volume unless I turn up actual sub.
Panasonic TCP-65VT25, Denon AVP-A1HDCI (on the fritz and looking to replace), Denon POA-A1HDCI, B&W 802D, B&W HTM2D, B&W DS8, JL Audio Fathom F113, Oppo BDP-83SE
Bedrom: Panasonic TCP-58VT25, Denon AVR-5308, B&W LM1, Sunfire HT12, Oppo BDP-83SE
Guestroom: Panasonic TCP-42, Denon AVR-1911, B&W LM1, B&W ASW8, Oppo BDP-83
YellowC4S is offline
post #13202 of 13503 Old 11-09-2015, 12:52 PM
jdsmoothie's Avatar
Quoted: 12460 Post(s)
Liked: 5696
You can raise the subwoofer level using Manual Setup - Test Tones - Subwoofer.
jdsmoothie is online now
post #13203 of 13503 Old 11-09-2015, 04:40 PM
YellowC4S's Avatar
doesn't do anything
post #13204 of 13503 Old 11-09-2015, 05:04 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6779 Post(s)
Liked: 3751
doesn't do anything
If you are saying increasing the sub channel trim setting in the AVR doesn't raise the output of your sub, something is very wrong.
AustinJerry is online now
post #13205 of 13503 Old 11-11-2015, 10:39 AM
LarryMagoo's Avatar
Quoted: 154 Post(s)
Liked: 57
Hey Yellow,
Did you notice that when setting up Audyssey, it asks you first to turn your Sub's Volume level to about 50% before starting to run the program. This might make a difference.
Cheers,
Larry
Sony XBR75X940D | Marantz AV8801 | SunFire Cinema Grand 5-Chan. | 5.2 system w/ 5 Monitor Audio Gold 2 Velodyne HGS 12's | Oppo BDP 105 | MAC Mini for Streaming, View on the XBR | Harmony Ultimate Remote | DDRC-88A| Comcast Internet 90Mb's | 2 Dedicated 20 AMP circuits. | Apple TV4 | Cans: Sennheiser HD 650 + Sennheiser HD 800S | Oppo HA-1 DAC/HEADPHONE AMP |
LarryMagoo is offline
post #13206 of 13503 Old 11-11-2015, 04:50 PM
YellowC4S's Avatar
In the past 3 months I've had to replace my AVP-A1 due to center ch going out, Now within the last 3 days I've lost a channel on my POA-A1 and my Fathom F113 won't power on. Maybe I should do that bose thing.
Kevin
post #13207 of 13503 Old 11-11-2015, 08:35 PM
Liked: 3751
Kevin
Earlier you reported an issue of not being able to raise the subwoofer channel level. Did you get that resolved?
Equipment failures are an opportunity to introduce newer and better technologies, unless it breaks your budget!
post #13208 of 13503 Old 11-11-2015, 09:27 PM
YellowC4S's Avatar
The problem with the sub is that it won't power on. Luckily my B&W 802D's have a decent bottom end. Called JL Audio and for $250 they will completely refurbish my F113 along with a 2yr warranty. As for the amp, I had bridged 2 channels together for my surrounds so I just undid that.
Kevin
post #13209 of 13503 Old 11-16-2015, 08:48 AM
romavictor's Avatar
Quoted: 200 Post(s)
Liked: 68
Why raise the SW level in the pre/pro and not at the sub itself? Trying to understand why....
romavictor is offline
post #13210 of 13503 Old 11-16-2015, 10:37 AM
Liked: 3751
Assuming that you use Audyssey calibration, if you change the subwoofer level, you may not like the change and want to return it to its original setting. The AVR subwoofer trim is a digital setting, so returning it to its original value is easy. A typical subwoofer gain control is an analog control, so if you change the gain and want to return to its original value, it is much more difficult. Of course, if your sub has a digital gain control, it probably doesn't make much difference.
romavictor likes this.
post #13211 of 13503 Old 11-16-2015, 03:26 PM
Liked: 3751
DirecTV users: how is the volume on the Sonic music channels compared with the volume on broadcast TV channels? The former is PCM, the latter is DD5.1. I am noticing a 15dB difference when switching between the two, PCM being louder. I don't know of any way to control the level difference between PCM and DD5.1. Is there a way?
post #13212 of 13503 Old 11-16-2015, 05:13 PM
jdsmoothie's Avatar
Liked: 5696
On Denon AVRs you could set up two different Quick Selects with level differences for each one, however, the equivalent Smart Selects on Marantz models was only just introduced starting 2014, so no featured on the AV8801.
post #13213 of 13503 Old 11-16-2015, 05:49 PM
Liked: 3751
As a long-time Denon owner, I really missed Quick Select when I transitioned to Marantz.
post #13214 of 13503 Old 11-17-2015, 01:30 AM
romavictor's Avatar
Quoted: 200 Post(s)
Liked: 68
Hey what's the significance of a buzz vs a hiss coming out of your tweeters?
I hear buzz with RCA's and Hiss with XLR's
post #13215 of 13503 Old 11-17-2015, 06:08 AM
Liked: 3751
As with any noise problem, the first step is to try and identify the source. I would start by disconnecting all source components (cable box, Blu-Ray player, etc.) to see if the noise goes away. If yes, then return the components one-by-one until the noise returns.
If that doesn't work, it gets more difficult. A buzz could be a ground loop. I am not sure that a ground loop would result in a hiss with balanced connections. But the real question is how loud is the noise--loud enough for you to hear at the MLP when the system should be quiet? I have a very feint hiss in the tweeters which is completely inaudible from more than six feet, so I don't obsess about it.
post #13216 of 13503 Old 11-17-2015, 06:40 AM
jdsmoothie's Avatar
Liked: 5696
Another option for you would be to also connect an optical/coax digital cable from the DTV box to another input on the AV8801 (eg. CD) and then set the CD Source Level setting to -12db (max setting).
post #13217 of 13503 Old 11-17-2015, 08:21 AM
romavictor's Avatar
Quoted: 200 Post(s)
Liked: 68
Jerry
I only hear it when I'm about 6 inches away....no biggie but was just wondering if there's any temporary solutions until I get the mc452. I'll try your methods to isolate the problem and let's say the cable box or Bluray player is the cause, what do I do than?
post #13218 of 13503 Old 11-17-2015, 08:24 AM
Liked: 3751
Jerry
Live with it or replace it.
post #13219 of 13503 Old 11-22-2015, 02:35 PM
jbjbjbjb's Avatar
Hi all. I just setup my new AV8801. Is there any way to set different levels for the sub on each input & have the preamp remember these settings. . I'd like to set a -2.0 for cable and a +2.0 for the blu-ray input. When I set using test tones it changes for all inputs. Same when I use the subwoofer level under audio settings. Am I missing something.
jbjbjbjb is offline
post #13220 of 13503 Old 11-22-2015, 02:38 PM
audiofan1's Avatar
Quoted: 1661 Post(s)
Liked: 1688
It will remember each setting (including audyssey settings,Deq on off etc..) per input on its on
audiofan1 is offline
post #13221 of 13503 Old 11-22-2015, 03:13 PM
jbjbjbjb's Avatar
Where will it remember, under audio settings/subwoofer level or test tones?
jbjbjbjb is offline
post #13222 of 13503 Old 11-22-2015, 04:00 PM
Liked: 3751
I would like to know as well. I set the sub level for +5 on one input, and when I cycled through the other inputs, it stayed at +5 for all inputs. I tried setting the sub level in the speaker/levels menu, but the results were the same.
With Denon processors we had Quick Select. I don't see the per-input settings memory on Marantz processors.
post #13223 of 13503 Old 11-23-2015, 03:53 PM
Audiguy3's Avatar
Quoted: 123 Post(s)
Liked: 69
Jerry
Please give us a update
Reggie
Family Room:75" 4K HDR Sony 940D/Marantz AV8802A/MM8077/GoldenEar:Triton Ones (superseding Triton 2s),/SuperCenter XXL center channel/ SuperSat 60surrounds/Oppo BDP-105/Directv C61K/Roku 4K
Basement: 70" Sharp Elite/Marantz AV8801/Marantz MM8003/PSB Stratus Gold Front,Center,Left, Surrounds/ Directv Genie HR-54/Roku 4K
Audiguy3 is offline
post #13224 of 13503 Old 11-23-2015, 09:10 PM
jdsmoothie's Avatar
Liked: 5696
Sorry, but no, not possible on the AV8801. Test Tone settings are global. The newer models 2014/2015 (AV7702, AV7702MKII, and AV8802A) have a new "CH Level Adjust" setting which can independently set speaker/sub levels per input.
Audiguy3 likes this.
post #13225 of 13503 Old 12-13-2015, 04:54 PM
vince32837's Avatar
Quoted: 125 Post(s)
Liked: 111
Guys-
I picked up a new sealed AV8801 unit. I fed my media player via HDMI to input 5(media player) input.
HDMI out (monitor 1) to small TV until my projector shows up. When I play a bluray, the sound from the left and right main channels is very low, have to put you ear 3" from speaker.
when I turn on static test tones, per speaker, they play at normal volume.
I moved the media player, to my family room setup, with the same hdmi cable and feeding a SR7008 Marantz receiver, left and right main channels played fine!
I moved to the av8801 DVD HDMI input same thing super low volume......
The AV8801 is connected to Crest CC5500 pro amps via XLR. Left and right channels to one amp,,and center channel to a 2nd amp.
I would think, since the speaker tones played normal, that proves the signal path from av8001 to crest amps to speaker wire to speakers is good.
could the hdmi board on a new sealed av8801 go out???
any thoughts?
thanks Vince
vince32837 is offline
post #13226 of 13503 Old 12-13-2015, 04:54 PM
vince32837's Avatar
Quoted: 125 Post(s)
Liked: 111
Guys-
any thoughts?
thanks Vince
post #13227 of 13503 Old 12-13-2015, 08:55 PM
Liked: 3751
Originally Posted by vince32837 View Post
Guys-
any thoughts?
thanks Vince
As with strange problems like this, reset the processor and try again.
post #13228 of 13503 Old 12-13-2015, 11:30 PM
JanJankovsky's Avatar
Could 8801 passthrough 4k60P video signal?
JanJankovsky is offline
post #13229 of 13503 Old 12-14-2015, 01:15 AM
jdsmoothie's Avatar
Liked: 5696
No, as it is only HDMI 1.4a, however, it will pass 4k/30fps when not encrypted with HDCP 2.2. The newer HDMI 2.0 chip which can pass 4k/60fps was only first introduced on the 2014 D+M models. The newer AV8802A is both HDMI 2.0a (HDR) and HDCP 2.2.
post #13230 of 13503 Old 12-14-2015, 01:24 AM
jdsmoothie's Avatar
Liked: 5696
Guys-
any thoughts?
thanks Vince
What master volume level do you have selected? Is it at least 60? Have you run Audyssey to calibrate the speakers yet?
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
