Marantz AV8801 Preamp/Processor Official Owner's thread - Page 449 - AVS Forum | Home Theater Discussions And Reviews
 288Likes
post #13441 of 13458 Old 10-21-2016, 10:16 AM
GIEGAR's Avatar
Quoted: 682 Post(s)
Liked: 1158
Hi fellas, I have a new 8801 owner I'm trying to help out in another thread.
He'll be running a pair of Berry iNuke NU6000DSP's for his (DIY) subs and a NAD M25 for his speakers. I wanted to confirm that it's possible to run the iNukes off the balanced/XLR pre-outs and the NAD off the RCA/single ended pre-outs. Or more broadly, do the RCA pre-outs remain active (line level available) when one or more XLR pre-outs are being utilised? I couldn't see any switches on the back panel or "software" switches in the menu so I presume so, but just wanted to run it by the experts.
A quick yay or nay will do.
Cheers!
Edit: Nevermind fellas. Got my answer.
podboy likes this.
GIEGAR is online now
post #13442 of 13458 Old 10-24-2016, 12:24 PM
Liked: 1
Cheers!
What was the answer to this?
siddforuall is offline
post #13443 of 13458 Old 10-24-2016, 03:24 PM
GIEGAR's Avatar
Quoted: 682 Post(s)
Liked: 1158
This was it:
Originally Posted by ultrabubu View Post
In the Marantz pre/pro speaker setup guide you must select the connection type (xlr or rca) for each channel; for SW1 and SW2 select xlr and for the other go to Nad select rca.
post #13444 of 13458 Old 11-06-2016, 07:02 PM
nezff's Avatar
Quoted: 126 Post(s)
Liked: 56
Originally Posted by AustinJerry View Post
Not sure what you mean by a "true 4K video processor", but the 8801 can upscale an incoming signal to 4K, and it will pass a 4K signal if you have a 4K source device. However, as I recall, the 8801 is not HDMI 2.0, nor does it support HDCP 2.2. If you plan on purchasing a 4K source device like a UHD player, then the player will need to be connected directly to a HDMI 2.0 HDCP 2.2 compliant port on your display, bypassing the 8801. This is why I upgraded to the AVP8802A.
Not sure why you would ever want to up-scale to 4K in the AVP, since up-scaling is best left to the TV.
From page 130 of the users guide:
So the chance of it passing a 4k HDR signal from a xbox one S or PS4 is a NO?
thanks
nezff is offline
post #13445 of 13458 Old 11-06-2016, 07:28 PM
jdsmoothie's Avatar
Quoted: 11237 Post(s)
Liked: 5169
thanks
Correct.
jdsmoothie is offline
post #13446 of 13458 Old 11-06-2016, 07:32 PM
nezff's Avatar
Quoted: 126 Post(s)
Liked: 56
Correct.
The game systems would have to be plugged directly into my Sony 4k tv then. I dont think the sound quality over ARC would be that great.
nezff is offline
post #13447 of 13458 Old 11-08-2016, 11:27 AM
Liked: 0
How do I start a topic in this thread?
Excuse my ignorance with Forums, but I want to put my questions where they will do the most good. Can't seem to find a way to start a topic in this Marantz 8801 Owners thread..just the ability to reply to posts already left..
huh?
John
jclipka is offline
post #13448 of 13458 Old 11-08-2016, 11:41 AM
AustinJerry's Avatar
Quoted: 5918 Post(s)
Liked: 3316
huh?
John
Well, a thread is a topic. If you want to ask a question, simply click the "Reply" button and ask your question. No need to quote a previous post. If you want to start an entirely new thread, click on the "Forums" link at the top, browse to the Audio section, and click "Start new discussion".
AustinJerry is online now
post #13449 of 13458 Old 11-08-2016, 12:30 PM
LarryMagoo's Avatar
Quoted: 149 Post(s)
Liked: 57
Hey everyone,
Just so you know....we are very lucky to have Jerry on this thread...he's an 8802A owner but still enjoys helping people out on this thread....He can answer any questions on Marantz Pre-Pros from his vast experience of equipment he has owned over the years!
Sony XBR75X940D | Marantz AV8801 | SunFire Cinema Grand 5-Chan. | 5.2 system w/ 5 Monitor Audio Gold 2 Velodyne HGS 12's | Oppo BDP 105 | MAC Mini for Streaming, View on the XBR | Harmony Ultimate Remote | DDRC-88A| Comcast Internet 90Mb's | 2 Dedicated 20 AMP circuits. | Apple TV4 | Cans: Sennheiser HD 650 + Sennheiser HD 800S | Oppo HA-1 DAC/HEADPHONE AMP |
LarryMagoo is offline
post #13450 of 13458 Old 11-08-2016, 12:32 PM
Liked: 3316
Originally Posted by LarryMagoo View Post
Hey everyone,
Aw, shucks, Larry.
post #13451 of 13458 Old 11-24-2016, 10:49 AM
nezff's Avatar
Quoted: 126 Post(s)
Liked: 56
Ran into a little snafu this morning with audyssey on my 8801. All speakers being the same and same distance from each other. The center channel is a tad different being that it is built just a little bit different same drivers excetera. Audyssey found my Center Channel at 90 Hertz my surrounds at 60 hertz and my fronts at 80 Hertz. Audyssey also found my left surround at -12 decibels and my Center at -12 decibels.
I was under the assumption or thought I read somewhere that audyssey didn't apply filters or the correct corrections to speakers at -12 decibels. I also thought I read somewhere that it was okay to go up in crossover but not down in crossover? Meaning would it be ok to put the center Channel at 80 Hertz by going down from 90 Hertz? Thanks in advance
ID:	1787945   Click image for larger version
nezff is offline
post #13452 of 13458 Old 11-24-2016, 02:06 PM
Liked: 3316
A trim of -12 indicates that you have very efficient speakers. Audyssey will attempt to set the trim according to the efficiency, but -12 is the AVR's limit. The problem is that you don't know if the correct trim is even lower than -12 because Audyssey has reached the limit. Others who encounter this situation use signal attenuators to provide Audyssey with more headroom to set the proper trim.
And regarding the crossovers, Audyssey determines the speaker's "F3 frequency", the point at which the frequency response drops by 3dB. It uses the F3 to recommend the crossover value, and does not correct below the F3. So, if you lower the crossover, there will be a gap in the room correction, and this is not recommended.
post #13453 of 13458 Old 11-24-2016, 05:26 PM
nezff's Avatar
Quoted: 126 Post(s)
Liked: 56
thanks.
I will definitely keep the center channel at 90hz. I do have some harrison labs -12db attenuators I bought a while back from parts express. As far as the trim level, Audyssey is still applying filters and correcting even though Im at the 12db?
nezff is offline
post #13454 of 13458 Old 11-24-2016, 07:11 PM
Liked: 3316
thanks.
Yes. The filters should be fine. It is the trims that are suspect.
post #13455 of 13458 Old 11-25-2016, 03:24 PM
nezff's Avatar
Quoted: 126 Post(s)
Liked: 56
quick question guys. Im searching for this now. What is the volume used if you want to use outside test tones from say a bluray and a SPL meter. Wasnt sure what 75db is on the 8801 display. Would 0db be reference and refer to 75db?
thanks.
nezff is offline
post #13456 of 13458 Old Today, 08:24 PM
rockcod's Avatar
Hi, It's been awhile since I've calibrated my system or used it. For some reason, my 8801 got wiped out. I'm trying to run Audyssey in the setup. Got that finished and went in and manually changed the fronts/center/rears to small. I noticed all the speakers are all set to 40Hz with the sub being set at 80Hz. Should I change the crossover for the speakers to match the sub?
Marantz 8801, KEF r700/r600c/r300 and HSU sub, Parasound a31/a21
rockcod is online now
post #13457 of 13458 Old Today, 08:47 PM
Liked: 3316
There is no crossover for the sub. You may be looking at the HPF for the LFE channel, which is typically set to 120Hz. The crossovers for the mains normally would be set to a higher value than 40Hz. 80Hz is a typical setting, which lets your subs produce everything lower than 80Hz.
post #13458 of 13458 Old Today, 09:20 PM
rockcod's Avatar
Thanks for the reply. Yes, I'm looking at the LPF for LFE and that's set at 80Hz. So I should change the small speakers to 80Hz and the LPF for LFE to 120Hz?
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
