AV Receiver sound processing Question. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-01-2012, 05:40 PM - Thread Starter
Vergil2501's Avatar
I can't decide between just using a 5.1 setup for my house or going 6.1 or 7.1 since plenty of BD movies support both. Can an AVR upmix audio that is 6.1 to sound proper on a 7.1 receiver and 7.1 to sound proper on a 6.1 set up. Also any recommendations for good AVR that is under 500 USD. I'm looking for something supports HDMI 1.4, BD audio tracks, 5.1/ 6.1/ 7.1, video upscaling (in regards to order video game consoles such as xbox, ps2, gamecube, and n64), and plenty of inputs for said consoles (ie composite and component).
Vergil2501 is offline
post #2 of 5 Old 10-01-2012, 07:54 PM
derrickdj1's Avatar
Quoted: 984 Post(s)
Liked: 719
A 7.1 or 7.2 avr should handel all the formats without any problem. Most of the new avr's have 7 channels.
derrickdj1 is offline
post #3 of 5 Old 10-02-2012, 05:47 AM
jdsmoothie's Avatar
Quoted: 15046 Post(s)
Liked: 7258
Very few movies are true 7.1 audio, although today's AVRs can generally downmix a 7.1/6.1 audio track to a 5.1 setup as well as simulate 7.1 from a 5.1/6.1 audio track. So whether you go 7.1 really depends on whether you have the space and which model you get depends on whether you want the extra 2 speakers to be rear surrounds, front height, or front wide. All 7.1 AVRs will have capability of adding rear surrounds, many will have the capability to add DD PLIIz (front height), but fewer will have the capabilty to add either front wide or height (Audyssey DSX). So first decide whether a 5.1 model will suit you or if you want a 7.1 model. In the Denon line you can review the first few posts in each of the Denon AVR-XX12 (last year's models) and AVR-XX13 (this year's models) threads linked in my sig.
jdsmoothie is online now
post #4 of 5 Old 10-02-2012, 08:22 AM
NorCalJason's Avatar
Liked: 30
Sounds like you're on the right track.
The trick is getting video upscaling from composite to HDMI at this pricepoint.
You might look at used "high end" models from a generation or two back....
NorCalJason is offline
post #5 of 5 Old 10-02-2012, 06:42 PM
Kilian.ca's Avatar
Liked: 37
A few points:
1. If room size is limited, better to have a 5.1 well set-up than a 7.1 poorly done.
2. 6.1 is not recommended.
3. Game upscaling is going to be problematic even with ext. video processors, there is some discussion in the vp forum about games. Keep your expectations well on the ground.
4. Legacy inputs are getting rare in lower models.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
