Android app for RX-A1010 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 10-01-2012, 09:38 PM - Thread Starter
brwsaw's Avatar
Quoted: 176 Post(s)
Liked: 108
Every few days my phone stops recognizing my 1010.
Any suggestions, its become an issue...
Sorry this was to go in the owners thread....Noobs....
Proud owner of an Axiom Audio home theatre, powered by Axiom Audio.
brwsaw is offline
post #2 of 16 Old 10-02-2012, 11:03 AM
benso37's Avatar
Quoted: 45 Post(s)
I had this issue as well. The solution was to manually add the IP Address of the AVR to the APP. Go to setting->Manual IP list.
benso37 is offline
post #3 of 16 Old 10-06-2012, 09:56 AM - Thread Starter
brwsaw's Avatar
Quoted: 176 Post(s)
Liked: 108
Not sure how but the IP address has changed 3 times.
brwsaw is offline
post #4 of 16 Old 11-12-2012, 09:33 AM - Thread Starter
brwsaw's Avatar
Quoted: 176 Post(s)
Liked: 108
Turns out it was pretty simple.
The wifi on my phone was turning off.
brwsaw is offline
post #5 of 16 Old 03-22-2013, 11:59 PM
nemoreborn's Avatar
ip on the amp !??? i own the 1010 ... how can u communicate with your phone to the rxa1010 !??? i know u can use sonos .. any1 can explain !?
nemoreborn is offline
post #6 of 16 Old 03-25-2013, 07:33 AM
JBWIII's Avatar
Liked: 44
The receiver has to be connected to your home network, and your phone has to be connected to the same network. I downloaded the Android app from the Google Play store (it's free); I'm sure the iPhone/iPad app is available from the App Store.
JBWIII is offline
post #7 of 16 Old 03-25-2013, 12:52 PM
nemoreborn's Avatar
and what can u do once your receiver is connected to the router ? i mean once u have the connectiondone and the app ? can u control Rdio.com from your cellphone ?
post #8 of 16 Old 03-25-2013, 01:03 PM
JBWIII's Avatar
Liked: 44
You can control the inputs, the volume, certain DSP and sound settings, pick songs to play from a (home) music server. I think that you can stream music straight to it from Android, but not sure about streaming services like rdio. It's free so why not just try the app out for yourself.
JBWIII is offline
post #9 of 16 Old 03-25-2013, 04:48 PM
nemoreborn's Avatar
any wifi possible ?
post #10 of 16 Old 03-25-2013, 06:15 PM
JBWIII's Avatar
Liked: 44
JBWIII is offline
post #11 of 16 Old 03-25-2013, 09:18 PM
nemoreborn's Avatar
awsome !!! thx you
post #12 of 16 Old 03-25-2013, 10:41 PM
cbatc's Avatar
Quoted: 99 Post(s)
Liked: 37
Don't buy the wifi adapter its too expensive. You can use a older router if you have one and flash it with DDWRT and make it a bridge. That's what I did. You can find tutorials online and it's fairly easy to do. I ended up using my old linksys blue router that had been sitting in the closet for years.. If you plan on going this route, check the ddwrt website to see if your router is supported. Also I use ps3mediaserver with my 1010. It makes accessing your music from your phone or tablet a lot faster.
cbatc is offline
post #13 of 16 Old 03-25-2013, 11:15 PM
cbatc's Avatar
Quoted: 99 Post(s)
Liked: 37
cbatc is offline
post #14 of 16 Old 03-26-2013, 03:06 AM
nemoreborn's Avatar
so i can pretty much buy the cheapest router available to my local store and setup it this way right !????
EDIT : d-link have one for sale at 25$ and supporting dd-wrt
post #15 of 16 Old 03-26-2013, 08:06 AM
JBWIII's Avatar
Liked: 44
Just get a model that supports DD-WRT since most wireless routers don't have bridge mode normally (DD-WRT adds that ability). For $25, go for the D-Link.
JBWIII is offline
post #16 of 16 Old 03-26-2013, 04:05 PM
nemoreborn's Avatar
yup i found a website that was listing the model of router supporting dd-wrt .. and the d-link 601 model was there ... so ill buy that at bestbuy for 25$
Yamaha Rx A1010bl Receiver
