Yamaha rx-v573 and dts hd ma decoding feedback - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-02-2012, 02:22 PM - Thread Starter
ayiana44's Avatar
HI all,
I have a slight problem which is driving me crazy.
I don't seem to be able to know if my receiver really is decoding HD MA audio or if it's down sampling it to a "normal" dts level.
So far, when I play a blu ray with dts hd ma audio, the front screen just display DTS, and the OSD input source display as well DTS, 48khz, 1536 kbps.
My bluray player is a panasonic bdt500.
Does any of you would be able to shed some light on my problem ?
ayiana44 is offline
post #2 of 5 Old 10-02-2012, 02:42 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
1. Are you connected via HDMI?
2. Is your BD player setup properly? Usually you have to turn off secondary audio on the Panasonic player setup menu in order to stream TrueHD and DTS-MA properly.
Afro GT
afrogt is offline
post #3 of 5 Old 10-02-2012, 02:48 PM - Thread Starter
ayiana44's Avatar
hi,
for
1. yes I'm connected through HDMI
2. I think my player is set up correctly, I went through the menu again and everything seems fine
ayiana44 is offline
post #4 of 5 Old 10-02-2012, 03:34 PM - Thread Starter
ayiana44's Avatar
Well, following what you've said point n°2), I double and triple (maybe even huh fourth) checked the settings on the panasonic player and IN FACT, I had missed the option to turn off the secondary audio output, so any audio going through HDMI was downsampled.
Thank you again for your advice, you made my day
ayiana44 is offline
post #5 of 5 Old 10-02-2012, 04:51 PM
afrogt's Avatar
Liked: 755
Glad it works...
Afro GT
afrogt is offline
Yamaha Rx V573 Receiver
