Help choosing a new receiever - AVS Forum | Home Theater Discussions And Reviews
Old 10-03-2012, 03:07 PM - Thread Starter
langers_2004's Avatar
Hi,
Im looking for some advice. I have a Marantz sr7200 but im currently having to switch hdmi cables from devices to my projector and back again as the amp doesn't support hdmi cables. Im also using a optical splitter to change the audio sources.
Basically i dont want the modern equivalent of the marantz, i want something that is currently available that performs to the same standard. i have the tannoy mx or mercury range speakers.
Any help and advice greatly appreciated.
langers_2004 is offline
Old 10-03-2012, 03:41 PM
jdsmoothie's Avatar
Quoted: 12180 Post(s)
Liked: 5548
A max budget and features/inputs/output required would help. For the Denon line, you can review the first few posts in the Denon AVR-XX12 (last year's models) and XX13 (this year's models) threads linked in my sig to compare models and their features. The 2112CI/2113CI is most likely the best buy as they both offer the the more advanced version of Audyssey MultEQ XT.
jdsmoothie is offline
Old 10-03-2012, 03:54 PM - Thread Starter
Ok thanks.
Well feature wise i want the same as the marrantz but with hdmi. Standard dolby or dts, and hdmi 1.4 support. 4 hdmi inputs and 1 out, same amount of optical inputs, 4 and maybe an out if this is a common feature.
Im not sure on budget but dont want to be spending hundreds of pounds, the cheapest possible really.
Old 10-03-2012, 03:57 PM
jdsmoothie's Avatar
Liked: 5548
Pounds puts you over the pond, so you may be better served using the European based AVForums.com site. Most any model going back 2 years should be HDMI 1.4, although optical inputs are becoming a thing of the past so you may have to settle for using an optical switch to provide additional inputs. Look for an older model from 2010 to likely get the most optical inputs. Also note that when reviewing the XX12 and XX13 Owner's threads, not all models are offered in the UK.
