Marantz SR5007 Owner's Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
Old 01-29-2013, 08:52 AM
theSeaHawk's Avatar
Originally Posted by jlpowell84 View Post
Does anybody know the true RMS/continuous wattage when running all 7 channels? I read somewhere it's 67 watts/channel. And for example if you ran the MM7025 to your front L/R towers would it not also free up more power for the remaining speakers?
I haven't come across the actual rating with all channels driven but it's bound to be less than the rating when only two channels are being driven. Also, the impedance of your speakers would factor into the power output.
Running an external amplifier for two or more channels would definitely free up power in the AVR for the remaining channels. I am debating myself whether to go ahead with a two-channel or three-channel external amp, more than likely an Emotiva.
I have Apple tv which I believe inputs a 2 channel signal. Do some of the other settings that are "released," in the selection list when a multi channel input is detected sound better? If so what would be a way to input your music in that format?
Try the different settings in real time by pressing/holding the music button on the remote and switching between them. The input is limited by the original source (be that a streaming signal or media etc.) and the settings of the input device. Does Apple TV pass a multi-channel audio program? Also, input sources will sometimes allow one to process a two-channel source into fake surround or downmix multichannel into stereo.
Also on my Onkyo I listened to music in 'all channel stereo' mode which played through all speakers. This multi channel doesn't include the center.
This may be because either the source signal/recording is in two-channel or the input source is not feeding multichannel to the Marantz. Did you try the "virtual surround" setting on the Marantz?
theSeaHawk is offline
Old 01-29-2013, 09:22 AM
MusicHead's Avatar
From Marantz glossary page:
70% Power Guarantee
Marantz has the 70% power guarantee, meaning that a minimum of 70% of the stereo power indicated in the specification section will be available when 5 channels are simultaneously used. A lot of misunderstanding about power rating has been created by claiming the highest possible output power as a unique selling point. Measurement often has been done on only 1 speaker drive, with lower impedance than 8 ohms and high THD (total harmonic distortion) acceptance. A standard THD value is 0.08%. The lower the better.
The url is here, just scroll down to the "70% Power Guarantee" paragraph:
http://us.marantz.com/us/support/pages/glossary.aspx
Interestingly enough, on the SR5007 specs published on Marantz's UK site there is a clear reference to this "70% Power Guarantee", but there is NOT such note on the Marantz US SR5007 published specs. Marketing screw-up or real difference between US and UK versions of the SR5007???????
At any rate, depending on how the power supply has been designed, if on 5 channel the SR5007 is supposed to deliver at least 70W (being 100W the power on 2-ch), power output on 7-ch is probably going to be in the 55-60 Watts range (just my guesstimate).
For example, according to Home Theater tests, the SR7007 (the top of the SR line), which is rated 125W on 2-ch at 8 Ohm, measured at 90W on 5-ch (72%) and 71W on 7-ch (57%).
I would not get too obsessed about those figures, though. Although ability of driving all channels simultaneously at a certain percentage of the 2-ch power can tell you something about how beefy the power supply is, in real listening situation I see dynamic headroom as more important. That depends on a lot of factors, including speakers sensitivity, your preferred listening level, adding an external amp for the fron channel, settings of your sub-woofer and dynamic of the source you are listening to or watching.
Just my two cents.
MusicHead is offline
Old 01-29-2013, 03:42 PM
jlpowell84's Avatar
Quoted: 1613 Post(s)
Liked: 712
I was looking at emotiva's and also the marantz mm7025 I think it is. 140watt/2channel amp. I have (8ohm) Definitive tech 8060 towers, 8040 center, 8040 rears, and pro monitor 1000's for front high. hsu 15h for sub.
70% Power Guarantee
I'm thinking a 2 channel for the front towers would free it up a bit and allow them to shine a bit more.
jlpowell84 is offline
Old 01-29-2013, 04:14 PM
Redge55's Avatar
New to this thread, but have read through all pages. So, I recently hooked up my 5007 and am learning as I go. However, any advice on how to connect my Sennheiser wireless headphones would be appreciated. In my prior stereo system I used the tape out on an Adcom GTP 502 preamp, which worked flawlessly. The connection is with 2 cord RCA and I've tried the Zone 2 analog out, with little success. Thanks for any advice.
Redge55 is offline
Old 01-29-2013, 06:20 PM
jdsmoothie's Avatar
Quoted: 12103 Post(s)
Liked: 5508
The Zone 2 pre-outs are your best bet if not using Zone 2 speakers; however, note that only network audio, USB, and analog external sources will pass to Zone 2 (ie. no HDMI or optical/digital coax connected sources). So then for HDMI sources, you'll also need to double cable with a RCA cable as well or in the case of a source without analog outputs (eg. AppleTV), you'll need to also purchase an optical ---> analog converter.
Written for Denon models, but applies to Marantz as well ....
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#user_M
jdsmoothie is offline
Old 01-29-2013, 07:06 PM
jlpowell84's Avatar
Liked: 712
I am interested to know others thoughts on adding external amplification? I understand every application is a little different than the next. I have a Definitive Technology speaker setup. Front L/R is 8060 powered towers (built in amp and sub) rated 20-300 watts. Center is 8040 rated at 20-200 watts. Surrounds are 8040 rated at 20-150 watts. Front highs are pro monitor 1000's rated at 10-200 watts. I did hear the entry level 8020 towers that were hooked up to a pioneer elite that put out 150 watts for 2 channels. It did sound good and I decided on my speakers from that. According to the previous posts if all 7 channels are being run are only outputting 55-60 watts a channel. Being new to the home theater/audio world I'm trying to figure out how external amps make the sound/experience better. I could run a 2 channel to just my towers but then how much? How do you feel about Emotiva? How about the Marantz dedicated amps?
Old 01-29-2013, 09:07 PM
jlpowell84's Avatar
Liked: 712
Old 01-30-2013, 08:08 AM
theSeaHawk's Avatar
If your towers already have internal power why would you want to add additional amplification to them? is there an input to them that by-passes the internal amplification?
Old 01-30-2013, 08:27 AM
jlpowell84's Avatar
Liked: 712
sorry about confusion. I heard them and bought them after hearing them powered by a Pioneer 2 channel 150 watt elite hifi amp. I have Marantz 5007. The built in amp is just for the sub.
So the xpa-3 provides 200x3. My towers are rated 20-300 watts so that would be good. My center is rated 20-200 watts. So thats too much for the center? I could just run to the two towers and leave the center alone. Perhaps an upgrade someday. I could get the xpa-5 for future proof. Although I don't see myself changing my speaker setup for some time considering I just bought them and love them. If I went with the Marantz MM7055 it puts out 140 a channel and then I could run 5 channels from that and let my Marantz SR5007 AVR run cooler and just power the surrounds. Thoughts? The only thing is the Marantz is more expensive. But in the big picture a few hundred dollars isn't too much considering I'm about 5,000 invested as of now.
Old 01-30-2013, 09:56 AM
simp1yamazn's Avatar
Quoted: 109 Post(s)
Liked: 77
Hey guys, I have a new SR5007 on order (EXCITED!) but I was wondering if anyone knows if there is a rack ear kit for this model? I've found the RMK6504SR on the Marantz website but it doesn't specifically list the 5007 as a compatible model.
simp1yamazn is offline
Old 01-30-2013, 12:00 PM
raaj's Avatar
Quoted: 96 Post(s)
Liked: 132
How about just using the headphone output, and using a 1/4" stereo headphone to RCA Y-cable to connect to the base station of the wireless headphones? Would there be any difference between this approach versus using the analog outputs or optical outputs?
raaj is offline
Old 01-30-2013, 07:17 PM
jdsmoothie's Avatar
Liked: 5508
Yup ... connecting to the headphone jack you have to unplug the 1/4" plug every time you you want to use the surround speakers while in the other configuration you just leave it permanently. smile.gif
Old 01-30-2013, 10:14 PM
raaj's Avatar
Quoted: 96 Post(s)
Liked: 132
SMH !! Yes, of course. That makes perfect sense! smile.gif I am more used to using my Sennheiser HD650 with a LOONG extension cable out of the headphone out on the receiver. Wireless headphones would dictate finding a more permanent connection like the one recommended using zone 2 pre-outs, but looks like even that is not an option without compromises regarding the input sources that can be used.
raaj is offline
Old 01-31-2013, 03:56 AM
jdsmoothie's Avatar
Liked: 5508
Correct. Requires additional cables to get the job done, but in the end, audio still gets to the wireless headphones. smile.gif
Old 01-31-2013, 04:48 PM
Redge55's Avatar
jdsmoothie and raaj; thanks for the input. Your information will be very helpful. Cheers
Redge55 is offline
Old 02-01-2013, 08:26 AM
jlpowell84's Avatar
Liked: 712
Ok so I have everything set, successful audyssey calibration ran. I understand when I use apple tv it only inputs a 2 channel source so my listening presets are limited. But after I did audyssey I put in the Dark Knight to test and it gave me the same 4-5 listening preset options. Shouldn't I have access to the multi channel modes? Like Dolby true HD and others. OR are these selected when I use 'multi ch in." I do wish there was more for music. I can only use Dlby Pl2 hieghtz to utilize my front height speakers. It sounds good but is center channel focused. I just wish more would go to my towers.
Old 02-01-2013, 09:52 AM
Selden Ball's Avatar
Quoted: 3054 Post(s)
Liked: 1494
jlpowell84,
I assume you mean that you put DK in a BD player. What model of player do you have?
How is the BD player connected to the receiver? HDMI? S/PDIF (opical or coax digital audio)? Red+White stereo connections? More than one of these types of connections?
My suspicion is that your BD player is configured to output stereo because it used to be plugged directly into a TV. Most BD players include a "reset" option in their menus, which should undo that stereo setting.
However, just to be complete... you need to use an HDMI connection for the receiver to receive high definition audio. If you want the receiver to do the audio decoding (i.e. if you want the receiver to report that it's receiving Dolby TrueHD or DTS HD-MA) you also have to set the player to "bitstream" the audio over HDMI, and set to not "mix" menu sounds and secondary audio. If both of these seetings are not enabled, the player will do the audio decoding and you'll get multichannel LPCM going to the receiver. While you're at it, look at the player's other settings to make sure they're reasonable.
Selden
Selden Ball is online now
Old 02-01-2013, 10:09 AM
jlpowell84's Avatar
Liked: 712
Originally Posted by Selden Ball View Post
jlpowell84,
However, just to be complete... you need to use an HDMI connection for the receiver to receive high definition audio. If you want the receiver to do the audio decoding (i.e. if you want the receiver to report that it's receiving Dolby TrueHD or DTS HD-MA) you also have to set the player to "bitstream" the audio over HDMI, and set to not "mix" menu sounds and secondary audio. If both of these seetings are not enabled, the player will do the audio decoding and you'll get multichannel LPCM going to the receiver. While you're at it, look at the player's other settings to make sure they're reasonable.[/quote
It's connected via hdmi to my receiver. I run all through the receiver and one hdmi to the tv. I will check the configurations of outputing stereo...It is a cheap Panasonic blu-ray I got in august free with my plasma.
Old 02-01-2013, 10:22 AM
jlpowell84's Avatar
Liked: 712
Is there a way to get my apple tv to output other than stereo?
Old 02-01-2013, 01:33 PM
jlpowell84's Avatar
Liked: 712
It most likely needs to be reset considering I did have it plugged into the tv when I first got the blu-ray...
Old 02-01-2013, 05:25 PM
jdsmoothie's Avatar
Liked: 5508
To add to Seldon's response ... when the AVR display reads "Mult CH IN" it means the BDP is decoding to PCM. Also, the only surround mode available for the Front Height speakers on the 5007 is DD PLIIz. Upgrading to the 6007 would also add Audyssey DSX which adds both Front Height and Front Wide speaker capability.
Old 02-01-2013, 08:35 PM
jlpowell84's Avatar
Liked: 712
Well I guess I upgraded and downgraded when I moved from my Onkyo TX-NR609 to the Marantz SR5007. The only thing the Onkyo didn't have was audyssey multi eq xt. It had more settings and customization than the Marantz. Hmm, maybe I should see if I can trade in and upgrade. I bought it 5 days ago...
Old 02-01-2013, 08:37 PM
jlpowell84's Avatar
Liked: 712
^ I did like the audyssey dsx for movies...
Old 02-01-2013, 09:04 PM
jlpowell84's Avatar
Liked: 712
The blu ray was set on pcm. I might see if I can take it back and upgrade. My guy sells denon and marantz...
Old 02-01-2013, 09:06 PM
jlpowell84's Avatar
Liked: 712
I set it to bitstream and still no dolby tru hd...Only the same options...
Old 02-02-2013, 04:20 AM
jdsmoothie's Avatar
Liked: 5508
Old 02-02-2013, 08:46 AM
Weirssy's Avatar
new owner.
have there been any firmware updates for this unit?
feel a bit silly asking but if there are updates, I have searched but can't find where these updates are ( I am in Canada) nor how to do the update confused.gif
can it be done via usb or by connecting a laptop to the avr? I wont be able to connect an ethernet cable that reaches from my avr to the modem and be still able to view the on screen display to follow instructions.
thanks
Weirssy is offline
Old 02-03-2013, 08:46 AM
olfac87's Avatar
For ARC to work, in addition to plugging the HDMI cable into the HDMI input on the TV labeled ARC, the TV's HDMI-CEC feature (VierraLink for Panasonic) must be set to ON and the TV speakers must be set to "external speakers". On the AVR the HDMI Control setting must be set to ON. However, note that when talking about only DD 5.1 using HDMI provides no better quality than using optical, and in fact, the HDMI(ARC) can only pass "stereo" while your current configuration using optical can pass DD 5.1, so you're getting the best quality audio now.
jdsmoothie - I thought this was the post I was looking for but no luck so far. P65VT50 TV. Viera Link is on. Internal speakers set to off. Default speakers set to home theater on TV. New HDMI cable from TV HDMI ARC to SR5007 ARC. Using pre-outs from SR5007 to Krell 2-channel amp (with home theater bypass) which has the main speakers connected to it. SR5007 set to TV Audio. No sound from TV to external speakers. What did I miss? (FYI, Oppo blu-ray plays fine via similar setup).
olfac87 is offline
Old 02-03-2013, 09:13 AM
jdsmoothie's Avatar
Liked: 5508
HDMI Control set to ON? Also, sometimes once HDMI Control is changed to ON, all devices must be powered OFF and then powered ON again, ... TV, wait a few seconds, then AVR. If it's setup correctly you shouldn't have to select the TV source, rather it will be selected for you when you power on the TV and the AVR.
Old 02-03-2013, 09:28 AM
olfac87's Avatar
Genius! I saw something in passing called "hdmi control" and found it in the manual once you suggested it. Thank you!
olfac87 is offline
Marantz Sr5007 Home Theater Av Receiver
