Marantz SR5007 Owner's Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #631 of 1067 Old 06-01-2013, 10:05 AM
xcrazydx's Avatar
Originally Posted by jdsmoothie View Post
They can't at present, however, I'll post them when I am able.
thank you, sir!
Sent from my SAMSUNG-SGH-I727 using Tapatalk 4 Beta
xcrazydx is offline
post #632 of 1067 Old 06-01-2013, 03:22 PM
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
So I have a klipsch Sub 10 and the SR5007. Have dialed the sub to gain to 50% and get -12 on the sub level. Turningn it to about 9 o clock i get -8.
I have heard that im supposed to get atleast -3.5.
My initial reaction is to turn the gain even more, but that would leave me without any bass. What should i do?
Sent from Samsung Galaxy Note II
blue13x is offline
post #633 of 1067 Old 06-01-2013, 03:34 PM
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
"A general rule when level matching the subs and the speaker channels is to run the gain hotter at the subs and the AVR sub trim level cooler. That keeps the AVR sub signal clean and allows upward adjustability to run the sub hotter if needed."
So from what i understand from everyone was that i shoukd turn my gain down to get in the sub in the -3 to 0 range.
But reading the quote above it seems i should raise the gain on the sub and use to get a level of about -10/-12 by the Audysey and use the AVR to adjust the sub level to -3 to -2.
Am i understanding this correctly?
blue13x is offline
post #634 of 1067 Old 06-01-2013, 07:59 PM
jdsmoothie's Avatar
Quoted: 15006 Post(s)
Liked: 7233
Subs are generally very efficient so you may have to dial it back to as much as 7 or 8 o'clock noting the sub will still pass plenty of bass.
Your understanding is correct. Bottom line is that as long as the sub trim is NOT set to -12db then you'r'e good to go; however, getting within that -3db to 0db range generally ensures the AVR will pass a strong enough signal to trigger the sub ON when it's set to Auto.
jdsmoothie is offline
post #635 of 1067 Old 06-02-2013, 01:13 AM
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
That means the two practices contradict each other.
A. "A general rule when level matching the subs and the speaker channels is to run the gain hotter at the subs and the AVR sub trim level cooler. That keeps the AVR sub signal clean and allows upward adjustability to run the sub hotter if needed."
B.you adviced to turn the gain down on the sub lower than 50%, to 9 o clock or even lower, so that the Audeyseey can set the sub closer to around -3 to 0.
Statement B implies lowering that gain below 50% on the sub, so that Audeyssey lowers the sub level.
Statement A implies raising keeping the gain at 50% on the sub or above, so that audeyssey can set it to around -12. And this way you can manually adjust it to the level you want on the Avr.
Which is right, cause it seems each one is contradicting?
blue13x is offline
post #636 of 1067 Old 06-02-2013, 02:35 AM
jdsmoothie's Avatar
Liked: 7233
Okay .. so I see where your confusion lies now. The general guideline provided in Statement B is where you want the "final" sub trim level to be set regardless of whether you make any further "preference" adjustments or not. So for example, if you prefer to boost your sub say 5db hotter than what it is set to after running Audyssey, then you will want to raise the gain on the sub a bit and run Audyssey again which will result in a lower negative sub level setting (eg. -8db); however, after you raise the sub level to suit your preference (say +5db) the final result will be -3db and so still within the range in Statement B. Bottom line is not to get caught up with trying to be exactly in that range, rather simply that when your preference settings are complete, you want the sub trim level closer to 0db than to either +12db or -12db.
post #637 of 1067 Old 06-02-2013, 06:53 AM
xcrazydx's Avatar
I do method a. If you don't you won't have any bass. I used the other method and thought I had a junk sub. Got on the chat with svs and they told me to run hotter at the sub. And they know all about audyssey. It's all use preference.
xcrazydx is offline
post #638 of 1067 Old 06-02-2013, 11:35 AM
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
[/quote] I do method a. If you don't you won't have any bass. I used the other method and thought I had a junk sub. Got on the chat with svs and they told me to run hotter at the sub. And they know all about audyssey. It's all use preference.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 4 Beta[/quote]
Thats what I was afraid of. I think most people like with the sub running a bit "hotter". Lowering the sub to the levels of what Audyseyy says is best is indeed more "reference", but not what most people like.
blue13x is offline
post #639 of 1067 Old 06-02-2013, 11:38 AM
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
But if you do option B, you could also raise the bass level from the AVR.
blue13x is offline
post #640 of 1067 Old 06-02-2013, 01:20 PM
xcrazydx's Avatar
You can do the same with option a, only it gets a cleaner signal that way. A is the way to go for hot bass. I like obscenely hot bass in the words of ed mullen from svs.
xcrazydx is offline
post #641 of 1067 Old 06-03-2013, 04:54 PM
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
Just noticed that today that when its really quiet and the Sr5007 is in standby, there 's a very faint hum. Is this normal?
blue13x is offline
post #642 of 1067 Old 06-03-2013, 05:32 PM
Taza's Avatar
Im having issues with my 5007 that when I exit from playing a dvd thru my playstation 3 it is like it looses connection between either ps3 and amp or tv and amp.
changed hdmi leads and ports on both tv and amp.
marantz couldnt help either
cheers
Taza
Taza is offline
post #643 of 1067 Old 06-03-2013, 05:56 PM
xcrazydx's Avatar
I haven't heard anything but maybe it hasn't been quiet enough in the room to hear it.
xcrazydx is offline
post #644 of 1067 Old 06-03-2013, 05:57 PM
xcrazydx's Avatar
cheers
Taza
I haven't experienced any issues with my ps3 and amp.
xcrazydx is offline
post #645 of 1067 Old 06-04-2013, 02:54 AM
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
Got my unit exchanged. Will report back on the hum/buzz.
I also realized that im one of those people that can actually hear and be by this high pitched sound and most wont even notice it.
blue13x is offline
post #646 of 1067 Old 06-04-2013, 06:55 AM
sven1olaf's Avatar
I'm having intermittent issues with the iPod interface on my 5007.
To get consistent handshaking between the ipod and the 5007, I need to plug in and turn on the ipod, then turn turn on the 5007, and then select the ipod/usb input on the remote. Without doing this, the 5007 shows either "no connection" or "no results" when looking at the ipod.
Also, at times, the ipod gets locked up in the middle of playback and just sits there... hard boot required to fix this, but does.
Has anyone else ran into either of these issues?
I am wondering if my 5007 is the culprit, or if its my ipod thats causing the issues. I haven't gotten a chance to test another ipod, but will when I can.
"Great spirits have always encountered violent opposition mediocre minds..." A. Einstein
sven1olaf is offline
post #647 of 1067 Old 06-04-2013, 10:11 AM
BigEyeFish's Avatar
Anybody see this on the Crutchfield.com site about the SR5008 ??
http://www.crutchfield.com/p_642SR5008/Marantz-SR5008.html?tp=179
Looks exactly the same as the 5007 at least through the compare feature.
BigEyeFish is offline
post #648 of 1067 Old 06-04-2013, 04:19 PM
lysoleverywhere's Avatar
Quoted: 69 Post(s)
Liked: 93
I don't think the 5007 has HDAM does it?
Marantz's Hyper Dynamic Amplifier Module (HDAM) offers improved dynamic range and detail while reducing noise
lysoleverywhere is offline
post #649 of 1067 Old 06-04-2013, 06:41 PM
jdsmoothie's Avatar
Liked: 7233
post #650 of 1067 Old 06-05-2013, 01:05 AM
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
Got a new Sr5007. The hum is much less but still there. I guess they all have this and is normal. A lot of people cant hear this.
blue13x is offline
post #651 of 1067 Old 06-15-2013, 01:53 PM
J2d
J2d's Avatar
Is anyone experiencing itunes randomly pausing songs when listening through airplay? It happens often to me, don't know if it's itunes or the sr5007 losing contact.
I stream through an airport express and have it connected to the sr5007 through a network cable.
And sometimes when watching movies on a ps3 the screen goes dark and I have to switch to another source and then back again to get it back.
J2d is offline
post #652 of 1067 Old 06-15-2013, 02:12 PM
jdsmoothie's Avatar
Liked: 7233
On the PS3, try setting the "Deep Color Output" to OFF. For the Airplay audio dropouts, try shutting down background applications on your iPhone or iPad, otherwise try a "wired" connection from the Airport Express to the router.
post #653 of 1067 Old 06-16-2013, 07:13 AM
kjohn's Avatar
Can anybody tell me what video scaler is in the Marantz sr5007.
KJ
kjohn is offline
post #654 of 1067 Old 06-16-2013, 07:16 AM
pagan97's Avatar
I have had this unit for a few months now. I am now trying to get airplay to work. The unit is not showing up on my home network, itunes, or airply. The unit is connected with ethernet and spotify, pandora, etc. are all functioning. Have performed the most recent firmware update as well. Not sure if this is related, but my IP address on the unit keeps changing. Is that normal? Anyways, any help on getting the home networking features to work would be greatly appreciated. BY THE WAY, I did try to set up using the instructions in the manual, but the first step is to select the receiver in the devices area and is never available or there despite it being turned on....darn it
pagan97 is offline
post #655 of 1067 Old 06-16-2013, 12:38 PM
jdsmoothie's Avatar
Liked: 7233
post #656 of 1067 Old 06-17-2013, 01:00 PM
granttickle's Avatar
Hey guys.
Im seriously considering an SR5007. I want to hook up 5.2 system with passive tops and active subs, and i want the assignable amped outputs to power a pair of stax Electrostatics. Would the SR5007 allow this or would it automatically implement the crossover between the subs and tops when listening in 2 ch. stereo mode?
Thanks in advance
Grant
granttickle is offline
post #657 of 1067 Old 06-17-2013, 02:40 PM
jdsmoothie's Avatar
Liked: 7233
The crossover can be set independently for each speaker pair as well as setting the sub to OFF when using the Front B setting.
post #658 of 1067 Old 06-17-2013, 03:17 PM
pagan97's Avatar
Thanks, i will give this a go next weekend!
pagan97 is offline
post #659 of 1067 Old 06-17-2013, 03:21 PM
Sweet thanks! Also do you know if the subs can be set up so that you get stereo bass rather than double mono bass. Don't want to assume, but guessing almost certainly yes?
post #660 of 1067 Old 06-17-2013, 03:30 PM
jdsmoothie's Avatar
Liked: 7233
Actually no ... except for the former Denon flagship AVP ($7500), AFAIK there are no D&M models that can do stereo sub signals, most certainly not at this mid level model range.
Marantz Sr5007 Home Theater Av Receiver
