Marantz SR5007 Owner's Thread - Page 33 - AVS Forum
post #961 of 967 Old 08-13-2014, 10:07 PM
Garet Jax's Avatar
Owner's manual p. 95
Thanks a lot. Got that part figured out. It turns out my back up failed so there was nothing to restore anyway.
Even with the reset and the reconfiguration, I still got the same shut down problem. I swear it is over heating, but can't imagine what changed to cause it now after 2 years of identical use.
Garet Jax is offline
post #962 of 967 Old 08-13-2014, 11:29 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 747 Post(s)
Liked: 1412
A slow flashing standby light (once every 2 sec)would mean there is a ventilation/overheating issue, while a faster flashing (twice every sec) more likely means amp failure in your case if loose wiring has been ruled out. Keep in mind if purchased from an authorized dealer, there is a 3 year warranty so suggest you call Marantz and send the unit in for warranty repair.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AV Gear
Mon - Fri: 8am – 8pm EST (Sat/Sun too, will return call if I don't pick up)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Atlantic Tech
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #963 of 967 Old 08-17-2014, 11:38 PM
Liked: 0
I have just updated the firmware on my SR5007 and also updated the ipad marantz app - Spotify is now well and truly broken and will only stream for a few seconds to a few minutes before stopping. I have a fibre web connection so bandwidth is not an issue, nothing else has changed. Has anyone got any ideas on how to resolve this issue?
Twistee is offline
post #964 of 967 Old 08-18-2014, 03:49 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 747 Post(s)
Liked: 1412
Try resetting the router and unplug the power to the 5007 for 10 minutes. What router is used?
post #965 of 967 Old 08-18-2014, 09:23 AM
Garet Jax's Avatar
First off dude - you rock. Thanks for all the helpful replies.
Secondly - it appears to be a heat ventilation issue. I installed a fan that blows from left to right just above the receiver. With this fan running, the receiver was able to run without issue for an entire day 10+ hours. Without the fan, I was lucky to get 30 mins before it reset itself. I read somewhere else that the speed of the blinking light indicated the type of issue, but could swear that it blinked for one second. I even recorded it for 5 seconds to try and get a reading - it blinked 4 times in that window.
I did buy it through an authorized dealer, but am holding off taking it in. I guess I will turn off the fan and see what happens.
post #966 of 967 Old 08-18-2014, 12:08 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 747 Post(s)
Liked: 1412
Better to have the fan pulling the hot air "away" from the unit not blowing dust over the top of it.
post #967 of 967 Old 08-23-2014, 02:16 PM
Liked: 0
Thanks, tried that and it appears to have solved the issue. The router is a FritBox , no apparent model number as it is generic for the ISP that supplied it.
Marantz SR5007
B&W 683 x 4
B&W ASW610 x 2
B&W HTM61
Panasonic PTAX100
Twistee is offline
Marantz Sr5007 Home Theater Av Receiver
Gear in this thread - Sr5007 by PriceGrabber.com
