Marantz SR5007 Owner's Thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #991 of 1058 Old 01-25-2015, 01:08 PM
Liked: 0
Hi, I have had the Marantz SR5007 for about 2 years now and occasionally see a dash on the display when the unit is both switched on and off. Also, the unit remains warm when in standby. I don't have IP control on and have played with that setting. Any ideas as to what could be causing this? Thanks.
Veemal is offline
post #992 of 1058 Old 01-25-2015, 01:48 PM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5501
Yup. Zone 2 is powered on. See p. 136 in your Owner's manual.
jdsmoothie is offline
post #993 of 1058 Old 01-25-2015, 11:20 PM
CadillacJim's Avatar
I'm using a Klipsch sw 350 with my SR5007. The bass never sounded quite right. Now its clipping, I turn it up all the way on some channels and its just not right. Anyone know How I should have it set(the sub) and the 5007 for that matter? Appreciate any help.....
Jim
CadillacJim is offline
post #994 of 1058 Old 01-26-2015, 01:04 AM
Liked: 0
Great thanks! I've never setup a 2nd zone, so I suspect my daughter got hold of the remote (again )
Veemal is offline
post #995 of 1058 Old 01-26-2015, 04:26 AM
jdsmoothie's Avatar
Liked: 5501
Jim
Set the sub gain/volume knob at about 9 o'clock and run Audyssey Auto Setup for just 1 position. As long as the sub volume level has not been set to -12db, you're good to go to run Audyssey again for all 8 mic positions, otherwise if = -12db, lower the sub gain/volume knob a bit more (eg. 8 o'clock) before running Audyssey. Once run, most prefer to bump up the sub volume about +3-5db (do this using AVR Sub Level setting).
post #996 of 1058 Old 01-26-2015, 02:08 PM
Thanks, I'll try that.
post #997 of 1058 Old 01-31-2015, 10:00 PM
R Stevens's Avatar
New Problem
Hey Guy's
I have not posted in a while, but I'm having a issue.
When I switch to network from the remote I can't see the menu screen on the tv. All I see is a blank screen on the tv with the current audio settings in the lower left corner when you change a input. I can see the menu in the little round window of the avr, but not on the tv?
In the past I have done a microprocessor reset and have fixed the problem. For some reason that is not working now. Spotify, Pandora, Media Server etc. can not be seen on the TV but can be viewed on the AVR window, selected and used without issue. I can only see on the AVR itself. Why can't I see it one the TV anymore?
Any help would be appreciated.
R Stevens is offline
post #998 of 1058 Old 02-01-2015, 07:45 AM
jdsmoothie's Avatar
Liked: 5501
The following worked for a Denon owner with the same issue:
Starting with the unit already powered up and (any) NETWORK source selected;
a. Verify from the unit's front panel display that the source is indeed the network,
and the monitor device (TV) is not showing the network GUI.
b. Imagine a line at the back panel just above where the hdmi connectors are that extends across the unit from left to right side.
c. Repeatly exert some moderate finger pressure on the unit's back panel along the imaginary line while watching the output video device until the network GUI displays.
If still no joy, try loosening the screws at the back that attaches the cover to the back panel to give it more "give", then repeat the above process.
post #999 of 1058 Old 04-14-2015, 09:53 PM
davida280's Avatar
My SR5007 started shutting off on its own recently. I've had it for 2 years and never had any problems. It didn't seem to be getting hot. The first few times that it shut off, I was able to turn it back on, and it would work for a while before it would shut off again. Now, when it shuts off, the red standby light flashes. I read that this could be caused by loose speaker wires touching the wrong post, and when I checked, I found one of the wires on my right front tower had come out. I fixed it, but still had the same problem. Then I read about reseting the receiver, I tried that, and I still have the same problem. Any ideas on what could be causing this?
Dave
davida280 is offline
post #1000 of 1058 Old 04-15-2015, 04:06 AM
jdsmoothie's Avatar
Liked: 5501
Dave
Is there sufficient room around the unit (eg. 3-4" above)? A slow blinking light would mean a ventilation issue. A fast blinking standby light can also mean amp failure or trying to power 4-ohm speakers too loudly. Power the AVR off and disconnect all wires and source cables on the AVR. Power it back on. If the unit shuts down again, you'll likely need to send it in for repair. If not, connect one speaker at a time to see if it shuts the unit down as that would mean a defective speaker.
post #1001 of 1058 Old 04-15-2015, 09:54 PM
davida280's Avatar
Thanks for the quick response. I disconnected everything from the AVR and powered it back on. It shut off again and the red light began flashing. I bought this as a refurbished unit from accessories4less. It looks like they only have a one year warranty. Do you know where I can send it for service? Any idea of a range for the cost of the repair?
post #1002 of 1058 Old 04-16-2015, 02:22 AM
jdsmoothie's Avatar
Liked: 5501
Correct, refurbs only have 1 year warranty while brand new units have a 3 year warranty. You can check Denon's website for authorized repair facilities in your area although for quicker turn around may be better served sending it to United Radio, NY if on the east coast or Hitechtronic, CA if on the west coast. Best to check with repair facility to get an estimate on cost but likely $200-$300.
post #1003 of 1058 Old 04-16-2015, 11:39 PM
Liked: 0
Hi all,
First time on this site, hoping to get some help. Have googled and searched wide for an answer, and no luck so far
I just got an SR5007 and I connected it to my router/modem with a cat5, and it downloaded a firmware update. But when I try the internet connection test, it fails. I have no idea why, it obviously connected before, and I haven't changed a thing so far. Any help would be much appreciated.
bobgoodman is offline
post #1004 of 1058 Old 04-17-2015, 05:10 AM
jdsmoothie's Avatar
Liked: 5501
Try rebooting the router and do a Network reset on the SR5007 (ie. press/hold the MDAX and Zone 2 Source buttons on front panel while powering on the unit ... release the power on button but continue holding the other two buttons for about 4-5 seconds).
post #1005 of 1058 Old 04-17-2015, 06:54 AM
Liked: 0
Thanks for the quick response jd,
I have tried all your suggestions but no luck. I have looked through my manual, which led me to another issue. Some menu items under NETWORK on my SR5007 are literally greyed out, I cannot select them (including SETTINGS, how lucky am I) and there is no explanation that I can find. I have done all the resets that I know of, multiple times; I have ruled out cable and modem issues, they are working fine. As far as I can tell this is not covered in any documentation I know of, including google searches. It's almost like those PCs/laptops which have options disabled by an administrator, which is the closest thing I can compare to; I'm stymied as to why I cannot change SETTINGS of all things Anyone else experienced similar problems?
Cheers
post #1006 of 1058 Old 04-17-2015, 07:22 AM
jdsmoothie's Avatar
Liked: 5501
Settings will be "greyed out" if a specific audio signal is not being received or a specific configuration is not set.
post #1007 of 1058 Old 04-17-2015, 07:37 AM
Liked: 0
As far as network settings, there is no configuration setup/option which I am aware of, that would cause the network settings to be inaccessible/"greyed out". The front display even shows my MAC address as non-sensical symbols (like wingdings). IP address is blank, so is the firmware page, so I cannot even tell what firmware is running. I'm surprised that I have come across what seems to be a glitch I hope no on else has to go through this, it's very frustrating
post #1008 of 1058 Old 04-17-2015, 07:57 AM
jdsmoothie's Avatar
Liked: 5501
Sounds like the network card is defective and will require repair. Return it to the seller and let him get it repaired if still under 3 year warranty.
post #1009 of 1058 Old 05-26-2015, 09:52 AM
worldww3's Avatar
Seems like my power board is dead due to some liquid damage. Anywhere i can get a replacement? or just get a new avr?
worldww3 is offline
post #1010 of 1058 Old 05-26-2015, 10:24 AM
jdsmoothie's Avatar
Liked: 5501
The SR5007 comes with a 3 year warranty if purchased new from an authorized dealer so see if Marantz will cover it, otherwise, you've likely got Home/Renter's insurance that may cover repair or replacement.
post #1011 of 1058 Old 05-27-2015, 11:17 AM
anon812's Avatar
HI Bobgoodman.. i have had issues with my 5007 and getting it connected to internet. but what you have indicated is not common. I havent ever had an issue with settings being grayed out, unless you have chosen DHCP. If you live in the US you can call Marantz, they do an awesome job trouble shooting over the phone. they helped me get my settings right for sound.
are you connecting your lan cable directly to the marantz or are you using a splitter or an additional router to get it connected? Marantz does not recognize splitters or lan ports (even powered ones). It prefers a direct connection from your router to its ethernet port.
Last edited by anon812; 05-27-2015 at 11:22 AM. Reason: Quoted reply for bobgoodman
anon812 is offline
post #1012 of 1058 Old 05-27-2015, 11:27 AM
anon812's Avatar
7.2 setup using SR 5007
Has anyone tried setting up two subwoofers on the SR 5007? Does it affect the receiver performance in anyway if 2 woofers are connected.. since these are powered subwoofers i presume they shouldnt suck power from the Amp however wanted to be sure that it doesnt affect the performance before i try it..
Also how have you placed the subs in your rooms? Diagonally across each other?
anon812 is offline
post #1013 of 1058 Old 05-27-2015, 01:11 PM
jdsmoothie's Avatar
Liked: 5501
No impact on performance of the AVR at all, rather only improvement in low bass audio quality in the room. Simply connect with a RCA "Y" splitter cable to the sub pre-out on the AVR.
Ideally, you want them to be identical and each placed equidistant from the main listening position (ie. mic position ##1). Set initial volume on each to about 10 o'clock before running Audyssey. Common placement configurations are on either side of the TV, half-way point along each side wall, and front/back diagonal corners. Best if you can do a subwoofer crawl (see below) for more ideal placement.
post #1014 of 1058 Old 06-03-2015, 10:26 PM
anon812's Avatar
https://www.youtube.com/watch?v=AV3oLLMgS-M
Thanks jd.. I will try that. Btw audyssey does mess with sub levels a lot. I called marantz to get the settings right as my klipsch reference series sub hardly put out any bass. It's much better since. Going to try sub crawl as you suggested
anon812 is offline
post #1015 of 1058 Old 06-04-2015, 04:51 AM
jdsmoothie's Avatar
Liked: 5501
Audyssey "messes with" all the speaker and sub levels which is the point as they will be calibrated to put out the same volume at your main listening position (ie. mic ##1 position). With dual subs, the volume of the combined sub output will increase about 6db which is why the gain knobs on the subs should start out lower 9-10 o'clock) to begin with so you don't get a -12db volume setting. Once Audyssey has been run, most prefer to raise the sub level on the AVR about 3-5db for a little more bass.
post #1016 of 1058 Old 06-20-2015, 06:49 PM
Sub working fine now, thanks. New question. I have SR5007 direct line to modem. When playing audio files, only files in ITunes come through Airplay to the unit. I use Winamp to play all my other flac files on the PC but can only play them through the computer speakers. How can I ply these files through the receiver?
Thanks for any help.
Jim
post #1017 of 1058 Old 06-30-2015, 09:45 PM
anon812's Avatar
SR5007 already obselete? No Atmos, DTS-EX or Auro 3D?
I love my SR5007, until...the launch of Dolby Atmos and DTS-EX. It is understandable that technology does become obsolete, but it is sad to see that there is no way to upgrade the firmware (purchase firmware through Marantz) to the new codecs like Auro 3D, Atmos or DTS-EX. Anyone listened to the new formats ? Is it worth the upgrade to a new Marantz receiver?
anon812 is offline
post #1018 of 1058 Old 09-05-2015, 07:24 PM
unfrostedpoptart's Avatar
Question about Audyssey:
My SR5007 is driving a 7.1 setup of all ADS speakers plus an SVS sub. The fronts are ADS L1590s with dual 10" woofers and the surrounds are ADS L1290s with dual 8" woofers. Yet, Audyssey shows these speakers as "small" with high crossover frequencies! What's going on? Also, it keeps calculating the distance of the sub (PB12-NSD/2 - dual 12", freq down to 16HZ) as 16' when it's actually about half that distance. It got all the other distances right so what's the problem?
How do I fix this? Is Audyssey XT just broken?
David
unfrostedpoptart is offline
post #1019 of 1058 Old 09-05-2015, 07:29 PM
jdsmoothie's Avatar
Liked: 5501
David
Audyssey measures how your speakers are reacting given your room's dynamics. With a dedicated sub in the setup, even if the speakers were set to LARGE, you would want to reset the speakers to SMALL/80Hz as the sub is far more capable than the speakers at producing the lower bass frequencies. Also, the sub distance accounts for the delay caused by the sub filters so there is no issue with the longer distance.
post #1020 of 1058 Old 09-06-2015, 01:27 PM
Thanks for the reply. I understand the sub distance thing now but it's not a great way for them to display the value! As for the large/small, it seems like a huge waste. I guess the bass management in Audyssey XT just isn't smart/powerful enough to handle this correctly. My fronts are rated to -3db at 28Hz so they should be treated as additions subs which would help even out standing waves and sub response. Would higher end Audyssey (XT32/Pro) handle this better? What about Dirac?
David
Marantz Sr5007 Home Theater Av Receiver
