denon avr 2809 hissing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-04-2012, 05:23 AM - Thread Starter
ward1983's Avatar
i guys wondering if any one can help me im running a avr 2809 when using adussey dynamic i get hissing from all of my speakers in every input blue ray cd tv ect when i put manual on or any other mode it clears no hissing ive tryed everythink i can think of i realy want to upgrade my reciever to new denon but worryed it will sound the same my old denon 1910 had the same fault is it me doing somethink wrong or just unlucky with both recivers haveing a fault please can some one help
ward1983 is offline
post #2 of 6 Old 10-04-2012, 05:25 AM
jdsmoothie's Avatar
Quoted: 12103 Post(s)
Liked: 5508
More than likely it's your setup ... the wiring ... the speakers ..... as it's unlikely the issue would present in two different model AVRs.
jdsmoothie is offline
post #3 of 6 Old 10-04-2012, 05:34 AM - Thread Starter
ward1983's Avatar
many thanks in geting back to me ive recently changed all my hdmi cables to chord and last week bought new denon blue ray 3d player also reinstalled everythink but still hissing im running russ andrews power leads to amp and player so everythink that could cause hissing should have gone im so stuck in what to do
ward1983 is offline
post #4 of 6 Old 10-04-2012, 05:39 AM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
Sorry to ask the obvious, but are you experiencing "hiss" or "hum"? Sometimes these two can easily be confused. "Hiss" sounds like when the wind blows (Sssshhh...), "hum" is caused by a ground loop resulting in audible mains frequency (50 Hz in Eurpoe/ 60 Hz in N.America) through the speakers.
+1 to jd, I also do not think the problem is inside any of your AVRs. smile.gif
mogorf is offline
post #5 of 6 Old 10-04-2012, 06:45 AM - Thread Starter
ward1983's Avatar
more of a hum now to think of it would you suggest to put a seperate ground loop to avr or seek some expert help or should i try puting old power lead back insted of russ andrews power lead thanks for the reply
ward1983 is offline
post #6 of 6 Old 10-04-2012, 07:25 AM
mogorf's Avatar
Liked: 613
Don't wanna seem pedantric, but the job here is not to "put a separate ground loop to avr", but to get rid of it. wink.gif
Try this please: disconnect the coax cable from the TV set-top-box and see (hear) if the hum goes away. In majority of the hum cases the ground loop builds up between mains ground and cable TV ground.
When I had my own ground loop problem in my system the solution was to buy a Belkin power strip with coax protection. Some thing (or similar) like this.
For more on the subject you may visit the Hum FAQ thread.
mogorf is offline
