Do most receivers not have built in ATSC tuners? Is there another device I need to output the coax signal to HDMI? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-04-2012, 10:33 PM - Thread Starter
akevit's Avatar
I am looking at buying the Denon AVR-2312CI receiver. I'd like to plug all my devices into it and output all of the video to my TV using a single HDMI cable that needs to get wired in. From what I can see, this receiver doesn't mention having a built-in tuner, and I'd simply like to get my TV through OTA channels, I don't plan on getting Comcast/Dish TV right now.
So are there simple/cheap digital tuners out there that will convert the HDTV Antenna signal into HDMI out? I think what I'm looking for is an External TV Tuner, but before I spend too much time looking for one I want to make sure this is the right solution. For those of you without leased set top box from a Cable company, what do you use to convert the antenna signal? I also have a HDTV without a built-in tuner so I assume this solution would work for that one as well.
I've been searching for a bit and I don't think I know exactly what I need to be searching for. I'm an extreme lurker of these forums and haven't posted questions for what I haven't been able to figure out myself.
Thank you.
akevit is offline
post #2 of 9 Old 10-05-2012, 12:03 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
How can you have a tv without a tuner? You just have a monitor? I don't think I've ever heard of an AVR with a television tuner, though. What model is your "tv"?
lovinthehd is offline
post #3 of 9 Old 10-05-2012, 12:14 AM - Thread Starter
akevit's Avatar
Not all TVs have tuners built in, the one that doesn't is a Westinhouse
I think I might try this one http://www.amazon.com/Kworld-HDmi-External-Digital-Tuner/dp/B002RL8I2W
akevit is offline
post #4 of 9 Old 10-05-2012, 12:16 AM
lovinthehd's Avatar
Liked: 4775
It's not a tv without a tuner....what specific Westinghouse model do you have?
post #5 of 9 Old 10-05-2012, 10:17 AM - Thread Starter
akevit's Avatar
Excuse my phrasing, it's a 37" monitor without a TV tuner.
akevit is offline
post #6 of 9 Old 10-05-2012, 10:17 AM
oztech's Avatar
Liked: 101
As was said its a monitor if it does not have a tuner and you could use a TiVo if you want to pay a subscription which is cheap and allows recording to drive.
oztech is offline
post #7 of 9 Old 10-05-2012, 11:08 AM - Thread Starter
akevit's Avatar
OK I don't want to focus too much on this monitor, my real issue is wanting to plug coax into something that can output via HDMI to my receiver so that I don't need to run coax to my TV and digital out to my receiver. I believe the Tivo requires a monthly subscription to use the built-in tuner, I'm hoping there's something without a subscription.
Whatever solution I find for the above I plan on also using for my other display in a separate room.
akevit is offline
post #8 of 9 Old 10-05-2012, 12:29 PM
oztech's Avatar
Liked: 101
http://www.solidsignal.com/pview.asp?p=cm-7001&d=Channel-Master-CM7001-ATSC%2FQAM-Digital-HD-Antenna-Tuner-CM-7001
oztech is offline
post #9 of 9 Old 10-05-2012, 01:26 PM - Thread Starter
akevit's Avatar
Thank you, this has led me down a rabbit hole of other forums posts, leading me to the PHD-VRX and PHD-8RX devices. This is a bit more complicated than I had thought, but I'm headed in the right direction now.
akevit is offline
