Pioneer Elite VSX-42 Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-05-2012, 06:38 PM - Thread Starter
Rock16MHS's Avatar
Hello.. I'm new to AVS and frankly surround sound all together. I own a VSX-42 reciever and have setup up with a 5.1 speaker system. My problem is I'm not sure if I have my settings correct for best performance. I've used the MCACC feature and have heard sounds from all 6 speakers. I noticed this week (after being hooked up for 2 weeks) that i only had sound coming from front speakers and really nice bass. No matter what I played through the reciever ( DirectTV box, blue ray movie....) that was the only place I have sound coming out. This being my first system, I thought it sounded pretty good..... but I want to hear what it is REALLY suppose to do and with all my components (DirectTV box, dvd/blueray player). Any pointers as to what settings I should tinker with, and if there is a setup that works best for all components without having to switch a bunch of stuff everytime I am playing something different??
Rock16MHS is offline
post #2 of 11 Old 10-05-2012, 07:20 PM - Thread Starter
Rock16MHS's Avatar
Been playing around some, and it seems that I had it in a front stage surround advance mode.... which sounds great, but doesn't allow for listening with back speakers. However when I change that mode it seems to have a lot of echo types sounds (sports, game...etc) The other option is EXT. Stereo and it seems to push sound to all speakers and sounds just ok.... all these options come from pressing adv. suround button....
post #3 of 11 Old 12-05-2012, 05:49 AM
cdudek's Avatar
I just bought the VSX-42 and am having the same exact experience. I was going to post on here but then read yours. Have you figured anything out? I think I might call Best Buy or Pioneer later today, but would rather get some advice from the pros on this site.
cdudek is offline
post #4 of 11 Old 12-05-2012, 06:07 AM
cdudek's Avatar
I think the issue is just with the advanced surround settings. I'm going to throw mine back to Auto and see how it sounds. I am using a universal remote an couldn't find a way to get off of advanced settings. Not sure if you tried just letting the receiver decide or if you always wanted to use advanced surround.
cdudek is offline
post #5 of 11 Old 12-06-2012, 01:27 PM
nyrmetros's Avatar
I also haven't found the best combination for getting a 5 speakers to sound incredible...... One option I found gives me awesome sound from the front speakers, but then when I went surround sound it doesn't sound as rich. Any ideas?
nyrmetros is offline
post #6 of 11 Old 01-25-2013, 03:12 PM
MGTR420's Avatar
Quoted: 34 Post(s)
Liked: 40
Hey guys, I am having the same issue with my vsx-42, have you guys come up with settings that sound good?
MGTR420 is offline
post #7 of 11 Old 02-24-2013, 03:32 PM
linvestor's Avatar
I recently purchased this same unit. I hooked up my Bose Acoustimass 10 system to it and I am experiencing the same issues previously mentioned in this thread. Is this a systemic issue withe the vsx42 or is there a solution? Anyone???
linvestor is offline
post #8 of 11 Old 04-25-2013, 04:38 PM
OCMike80's Avatar
Hey guys, You need to go into the home menu and go into 2. manual speaker setup then go into a. speaker setting and change them all to small. This will make your system sound alot better and your volume will go up alot louder.
Also make sure to run your mcacc after doing this and check to make sure it didn't change your speakers to large, and if it did change them back to small. If you have any other questions feel free to ask.
Panasonic Plasma Fan TC-P65ZT60 TC-P65S1 TC-P65S60 TC-60PU54-2 TC-P50U50-2 2 pioneer elite Vsx 42's XBOX 360 PS3 Verizon Fios QIP 7232 2
OCMike80 is offline
post #9 of 11 Old 07-11-2013, 10:15 PM
nyrmetros's Avatar
That's a good idea, I will try that out. Thanks.
post #10 of 11 Old 09-14-2013, 06:53 AM
Elevatorguy's Avatar
nyrmetros,
Did you do this and, if so, did it work? I am looking at buying this receiver used from a friend at a good price, but would like to know if this issue has been resolved. I am only driving small Cambridge speakers and would like to get the best sound out of all of them. Thanks for the help.
Elevatorguy is offline
post #11 of 11 Old 12-04-2013, 01:39 AM
nyrmetros's Avatar
I didn't get a chance yet. Hopefully I can work on it on Thursday !!
Pioneer Elite Vsx 42 7 1 Channel Network Ready Av Receiver
