Receiver for a 4 ohm speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-06-2012, 05:31 PM - Thread Starter
demisod's Avatar
I am considering getting a Triad Mini LCR 3.0 soundbar as part of a new system. That equipment is rated at 4 ohms. I had hoped to spend about a thousand on a mid-level AVR receiver from Denon/Yamaha/Onkyo, but i am wondering if a mid-range receiver will work for a 4 ohm speaker. Any thoughts?
demisod is offline
post #2 of 6 Old 10-06-2012, 08:21 PM
NorCalJason's Avatar
Liked: 30
Do you need the preamp/processor stage of a receiver?
I could recommend a few inexpensive amps that will happily push 100wpc into a 4ohm load, all day every day. You can pickup a Sonance 260 / Niles amp for under $100 used...
NorCalJason is offline
post #3 of 6 Old 10-06-2012, 09:03 PM
Aja1's Avatar
I purchased 4 ohm speakers (Dynaudio Focus 110) and was prepared to use my HK AVR 635 to power them after getting H/K's approval. I connected them and could tell immediately that the receiver was going to struggle to handle the load. I had an Adcom amp that I was able to immediately use to relieve the receiver of those duties and was amazed at the difference in sound quality. The receiver couldn't come close to the bass that the amp was able to produce. My point is that any of those receivers may be able to handle 4 ohm speakers, but consider an external amp to get the most out of them.
Aja1 is offline
post #4 of 6 Old 10-07-2012, 06:52 AM - Thread Starter
demisod's Avatar
Yes, I would be starting from scratch. I'll think about used equipment. Obviously, much cheaper than new but there's a greater chance of problems.
demisod is offline
post #5 of 6 Old 10-07-2012, 07:35 AM
Theresa's Avatar
Liked: 51
Many of today's receivers cannot handle low impedance speakers. I use Emotiva amps and they handle my four ohm speaker drivers effortlessly.
Theresa is offline
post #6 of 6 Old 10-07-2012, 09:45 AM
Liked: 30
Generally, you're going to need to go the separates route to drive 4ohm speakers well...
