5.1 Need input for a amp and receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 10-07-2012, 07:29 AM - Thread Starter
03SONIC's Avatar
I am new to this so bare with me. Here is what I am looking to run, its a decent size room but I would like to run a 5.1 system. I know RTIA9's need power, here is the set up.
1) 2 RTIA9's (front)
2) CSIA6 (center)
3) RTIA3's (rear)
4) SVS sub
I welcome the feedback before I pull the trigger. Looking for the best bang for the buck.
03SONIC is offline
post #2 of 15 Old 10-07-2012, 10:03 AM
vzphoneman's Avatar
Quoted: 82 Post(s)
Liked: 78
The Polks should be a nice speaker setup for you along with the SVS sub. What do you want to spend on a receiver? Do you have any brands you like or dislike?
The lazy man finds the easiest way ... Ben Franklin
Rouge Audio Cronus Magnum II integrated amp, Goldenear Technology's Triton 2+ speakers, Schiit Bifrost Multibit Dac, Technics SL-1200MK2 turntable with Audio Technica 440ml cartridge, Teac X-1000R reel to reel, custom computer as main music source
vzphoneman is offline
post #3 of 15 Old 10-07-2012, 12:31 PM - Thread Starter
03SONIC's Avatar
Well I guess what I need help with is, if I run a amp which from what i read i willl need I need to drive the RTI9's, I need a pre amp not a full blown receiver? The combo will be 60% music/40%movies. Also do you run the amp to all 5 speakers fronts/centers/rears? Thank you
03SONIC is offline
post #4 of 15 Old 10-07-2012, 03:14 PM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
I've never auditioned the RTiA9 speakers, but Polk's Web site claims they have an efficiency rating of 90dB. That's relatively high, meaning they don't need as powerful a receiver as most speakers, which often are in the mid 80s. Unless you have a large, highly sound absorbent room, just about any modern receiver should be able to drive them to decent sound levels.
The traditional rule of thumb is to spend about 2/3 of your audio budget on speakers and 1/3 on electronics to drive them, suggesting that it would be reasonable to keep your expenditure on electronics under $1K. A pre/pro plus external amps would be closer to $3K. If you want to use an external stereo amp to drive the front speakers, you need to get a receiver which includes pre-amp outputs. That'll push the cost of the receiver to near $1K.
For the best sound, you need to consider receiver models which include some form of room equalization, preferably Audyssey (Onkyo and Denon). The competing receivers with EQ and costing $1K or less (Pioneer and Yamaha) don't equalize the subwoofer channel.
Note that my cost estimates are based on list prices. Significantly lower prices are often available if you're willing to use refurbished equipment.
Selden
Selden Ball is offline
post #5 of 15 Old 10-07-2012, 03:48 PM - Thread Starter
03SONIC's Avatar
What would you run to drive this array of speakers?
03SONIC is offline
post #6 of 15 Old 10-07-2012, 04:19 PM
Liked: 1494
Among this year's models:
Denon's AVR 2313ci has preamp outs for just front channels, and lists for slightly under $1K. Their 3313ci has preamp outs for all channels for about $200 more.
Onkyo's TX-NR717 has preamp outs for all channels and lists for slightly under $1K. Their next lower model has only subwoofer out.
Emotiva is well known for their quality, cost-effective amplifiers.
I suggest you look at the receivers' other features to help you decide among them.
Selden
post #7 of 15 Old 10-07-2012, 04:40 PM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
The Denon 331XCI series is the lowest level model with main zone pre-outs, while the Marantz models offer a minimum of FL/FR pre-outs (1403, 1603) and full 7.2 pre-outs starting with the 5007. However, all Denon/Marantz models (except the 1513) offer at a minimum of Audyssey MultEQ, while the Onkyo 717 and lower models only offer Audyssey 2EQ which cannot EQ the sub and has 1/2 as many speaker control points as does MultEQ.
jdsmoothie is offline
post #8 of 15 Old 10-07-2012, 04:42 PM - Thread Starter
03SONIC's Avatar
Do I need to run a amp and receiver, or a amp and a pre amp or just a receiver? Thanks Guys
I want this to pound...lol
03SONIC is offline
post #9 of 15 Old 10-07-2012, 04:46 PM
jdsmoothie's Avatar
Liked: 5502
As Seldon noted, unless you're in a large room, you should not require an external amp, rather the AVR's amps alone should suffice. If you still want to use an external amp (which will likely cost as much as the AVR, eg. Emotiva XPA-2), you'll need to connect the amp to the main zone pre-outs on the AVR.
post #10 of 15 Old 10-07-2012, 05:06 PM
NorCalJason's Avatar
Liked: 30
As has already been noted, the Polks you chose are reasonably efficient, and are 8ohms.
They will be easy for nearly any receiver to drive them to very very loud sound levels.
IMO, pick a receiver that fits your feature set needs. Be less concerned with output power.
NorCalJason is offline
post #11 of 15 Old 10-07-2012, 05:08 PM
Liked: 30
With a good subwoofer, you'll be directing all low end frequencies to it. This will free up a receiver to drive the easier load of pushing the higher frequencies.
It'll pound because of the sub.
post #12 of 15 Old 10-07-2012, 05:22 PM - Thread Starter
03SONIC's Avatar
So just a receiver? no amp sorry new to this stuff.
03SONIC is offline
post #13 of 15 Old 10-07-2012, 07:56 PM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
I'd look at either the Denon 33xx series, either the 3313 or the 3312 (last years model) or the Onkyo 818 . All have capable amps built in, Audyssey XT32, and a full line of pre-outs. All can be found for under 1K. Then if you feel you need louder, or just want an external amp, you'll be able to add one easily. Whether you NEED an external amp... opinions will vary, but your own specifics will determine that. Room size, in cu ft, and distance from the speakers , together with how loud you listen, primarily.
hope it helps
Joseph
mods, can we have a 'dislike' button ?
wlhungdude is offline
post #14 of 15 Old 10-07-2012, 08:14 PM
jdsmoothie's Avatar
Liked: 5502
Note the Denon models only use XT, while the Onkyo 818 uses XT32.
post #15 of 15 Old 10-07-2012, 08:30 PM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
good point JD,
and if having 'just' XT is a viable option, then include the Onkyo 809 (last years model) in your research.
