Recommend a Receiver - AVS Forum
post #1 of 4 Old 10-08-2012, 05:28 PM - Thread Starter
sentryman's Avatar
Just purchased a Panasonic AE7000U, 8 pairs glasses, new ceiling mount, and 50 ft HDMI cable.
I am replacing a Sharp 9000. I need to replace my existing Pioneer Elite 7.1 receiver since it is not 3D ready or HDMI.
I also have a Panasonic 3D Blu Ray and a Sharp DVD just for intros.
My speakers are M&K and I have a transducer in my raised rear platform.
Room is 14x21.
Any ideas for a new receiver?
Jim
sentryman is offline
post #2 of 4 Old 10-08-2012, 10:20 PM
lespurgeon's Avatar
Liked: 40
Price?
I'd say everybody is going to suggest Denon.
Personally I would split my signal video bypassing the receiver and straight to the AE7000u - the cheap option, but then you don't get all the fancy switching and all.
lespurgeon is offline
post #3 of 4 Old 10-09-2012, 05:51 AM - Thread Starter
sentryman's Avatar
Thanks for the suggestion.
Any thoughts on what wattage I should be considering?
post #4 of 4 Old 10-09-2012, 06:12 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 269 Post(s)
Liked: 1301
Depends on whether you listen at only average volume levels or prefer louder (near reference levels) audio for music and movies. If the latter, and the M&K are 4-ohm speakers, in the Denon series you'll want to go with either the older 4311CI on clearance, it's replacement the 4520CI, or either a 3312CI or 3313CI with an external amp (eg. Emotiva XPA-2).
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - AVSForum sponsor for 15 years
Mon - Fri: 8am – 8pm EST (Sat/Sun, leave message)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is offline
User Tag List
