Marantz SR6007 AV Receiver Owner's Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 388 Old 04-25-2015, 04:21 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 4410 Post(s)
Liked: 2370
1. Depends on default audio selected on the DVD/BD.
2. Possibly. Although a Harmony remote would also be able to operate your other components as well ... so worth trying.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #362 of 388 Old 04-26-2015, 09:44 AM
SherazNJ's Avatar
Quoted: 484 Post(s)
Liked: 53
2. Possibly. Although a Harmony remote would also be able to operated your other components as well so worth trying.
Thx a bunch. I guess best option is to check all the surround options available while playing movie and then choose the best one .
Harmoney remote it is then.
SherazNJ is online now
post #363 of 388 Old 05-02-2015, 05:47 PM
dragpeace's Avatar
Latest Firmware Version?
Does anyone know the latest firmware version? I have 1490-1119-0000-2350-1867
I can't find a site anywhere that gives this info.
dragpeace is offline
post #364 of 388 Old 05-02-2015, 05:49 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2370
The D&M servers have been down the past couple of weeks ... but when they are back up again, the AVR will indicate whether it has the latest firmware loaded when you select the "Check for Update" setting (p. 138 Owner's manual).
post #365 of 388 Old 05-02-2015, 05:55 PM
dragpeace's Avatar
Ahh, ok. I only hitch it up to the Internet every other year or so, as it's nowhere near an access point. When I check for an update, I get:
Result
Update Firmware Latest
Update Time ------
Does that mean I'm good? Thanks!
post #366 of 388 Old 05-03-2015, 03:40 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2370
Yes.
post #367 of 388 Old 05-03-2015, 05:07 AM
dragpeace's Avatar
Well, my problem now is that, whenever I turn on the Marantz, it just says "Update Retry". I waited 15 minutes or so and it turned itself off. I turned it back on, and get the same message. That's somewhat disturbing. The Internet is working, as I'm on the same router it's connect to, as I type.
Just to update - no matter what I do, it always reverts to the "Update Retry" message with the arrows, as though it's doing something. I can't get it out of that mode. I've unplugged it, help the power key for a while (read that somewhere), etc. Any ideas?
post #368 of 388 Old 05-03-2015, 07:17 AM
dragpeace's Avatar
Ended up trying a processor reset - no luck (same issue with it trying to update). Tried again - no luck. Then tried a network processor reset (the + and - preset channel buttons). It reset, but no output to the TV (I could see the setup items on the front of the AVR, though). So, unplugged, another processor reset. Same problem. I then selected English from the screen on the Marantz, then exited setup, and voila! The TV came alive. Obviously, I have to redo my setup, but such is life. It tells me my firmware is:
I don't think I'll try and update the firmware again anytime soon!
post #369 of 388 Old 05-03-2015, 08:03 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2370
After running Audyssey again, you can use the Web Control feature (p. 97 Owner's manual) to save a copy of the config file (including Audyssey) to a PC file.
post #370 of 388 Old 05-03-2015, 09:06 AM
dragpeace's Avatar
I'm going to have to work out how to connect to my network, first. The AVR isn't near a good connection (which is probably part of my initial problem - I tried to rig up a temporary wired solution). I need to connect the AVR to my network via wireless, but have to do some research on how to get that done. It never ends, does it?
post #371 of 388 Old 05-03-2015, 09:35 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2370
Some owners have purchased a 100-200' ethernet cable for firmware updates only.
post #372 of 388 Old 05-03-2015, 11:19 AM
dragpeace's Avatar
I'm thinking wireless bridge, so it's always connected, but I may end going that route. Cable is pretty cheap, now-a-days. I appreciate your help and advice, btw! It's been useful.
post #373 of 388 Old 05-03-2015, 11:22 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2370
Wireless bridge is good for day-to-day networking requirements, but generally a "wired" connection is more reliable for a firmware update. Lay out the cable. Do the update. Withdraw the cable. Although the 6007 is not likely to get anymore updates at this point.
post #374 of 388 Old 05-06-2015, 02:57 PM
dragpeace's Avatar
Just to put a wrap on this, I used a 100ft cable to connect the AVR to the Internet and it updated with no problems whatsoever. It clearly hadn't updated properly, when I tried my previous attempt. So, I'm good to go. Thanks for the help!
post #375 of 388 Old 05-08-2015, 06:18 PM
Liked: 0
I am having issues with the voice syncing with the picture when watching blurays ONLY. TV and Internet work fine.
Any idea what the cause is? Audessey is off and 24fps is turned on on the blurays player. Audio & video are hdmi from the bluray.
mastfalk is offline
post #376 of 388 Old 05-25-2015, 12:27 PM
K5/SS's Avatar
Quoted: 46 Post(s)
Liked: 64
Hey guys, I just snagged a SR6007 for very cheap because it was missing the setup microphone. I tried downloading the manual but my iPad is acting up.
Can one of you guys please give me the SR6007's correct microphone model number?
Just bought a 5.1 Aperion system and a Emotiva 7 channel amp, I need the microphone to tie it all together
Thanks in advance!
Oppo BDP103, Sony 70" LED, Definitive Technology Mythos STS Towers, Definitive Technology Mythos 9's x3, Pioneer SC-1523-K, Furman Elite 15, Harmony Ultimate Hub and Rythmik FV15HP.
K5/SS is offline
post #377 of 388 Old 05-25-2015, 12:45 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2370
You can use either the ACM-1H or ACM-1HB .... both available on eBay for about $25.
http://www.ebay.com/itm/like/3315577...lpid=82&chn=ps
K5/SS likes this.
post #378 of 388 Old 05-25-2015, 12:55 PM
K5/SS's Avatar
Quoted: 46 Post(s)
Liked: 64
You have to be the most helpful member in the Receiver section.
Thanks for your help! Ordering now.
K5/SS is offline
post #379 of 388 Old 06-10-2015, 01:04 AM
darrenchong's Avatar
Liked: 0
Hi Experts,
I m wondering if we can set the FM channel to "even" number as 98.8 or 101.8. When using Direct Tune, it will change to odd number after the "." even i enter 98.8. Please advise.
darrenchong is offline
post #380 of 388 Old 06-10-2015, 02:59 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2370
No. AFAIK, all FM stations in the USA only use odd number extensions (ie. 0.1, 0.3, 0.5, 0.7, 0.9).
post #381 of 388 Old 06-16-2015, 06:55 PM
jewel5's Avatar
network problem
Hello guys. I have had my unit for about 3 yrs, and it seems my ethernet port is not working. I recently had Directv install genie in my home, and I thought maybe the genie settings was screwing with my receiver, but I've gone through all the settings and even completely disconnected it, and no change. I try to do a network setup and it fails every time. I checked the cable, but it is working. Any ideas or thoughts about what I can try would be greatly appreciated. Everything else works fine, but I miss streaming from my pc.
jewel5 is offline
post #382 of 388 Old 06-17-2015, 02:57 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2370
Is the AVR wired directly to the main router or to a bridge router? Have you tried replacing the cable? Reboot the router? Was a new router installed recently?
post #383 of 388 Old 06-17-2015, 02:27 PM
jewel5's Avatar
Hello again. I have an ethernet cable directly from my router to the receiver. I hooked the cable to my pc and it worked, so the cable is fine. I also rebooted my router, that didn't help. I checked all my windows steaming settings, and it looked fine. And I checked my network connections, and it isn't reading the receiver at all. Do you think a hard reset of the Marantz might do any good?
jewel5 is offline
post #384 of 388 Old 06-17-2015, 02:43 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2370
Try cycling the DHCP setting in the AVR to ON/OFF/ON. A "network reset" of the AVR would involve pressing/holding the Preset CH +/Preset CH - buttons while powering on the AVR, although doing so will also do a microprocessor reset as well so unless you want to run the Audyssey setup again, you can use the Web Control feature (p. 97 Owner's manual) to save the config file to a PC.
post #385 of 388 Old 06-17-2015, 03:43 PM
jewel5's Avatar
My network settings were completely grayed out and windows streaming said it was offline. Anyway, I just did a hard reset and my network if functioning once again. I'm so happy!! Thanks again for your help.
jewel5 is offline
post #386 of 388 Old 06-19-2015, 08:59 AM
archiguy's Avatar
Quoted: 1111 Post(s)
Liked: 1044
Got my dud-refurb 6007 back from United Radio yesterday and this time I hooked it up and tested it. Seems to be outputting sound on every output I tried, so I guess it's fixed. Noticed it doesn't have HDMI pass-thru when it's in its "off" or "standby" state, which I don't like and didn't realize it lacked when I bought it.
But the Denon X4000 covers that issue, it passes HDMI in standby, and that's the living room AVR anyways. It came back from United Radio from its repair job the day before (protection circuit problem) and it seems to be functioning properly as well.
The Marantz will be the theater room AVR and it just has to provide sound for the projector which means it will always be on when the projector is on, so HDMI pass-thru isn't an issue there.
archiguy is online now
post #387 of 388 Old 06-19-2015, 09:30 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2370
Although not a feature you like, it actually doesn't lack this feature, however, unlike the newer X4000 which has a dedicated HDMI Pass through setting which defaults to ON and is set to pass the CBL/SAT source by default as well, the SR6007 must have the HDMI Control setting set to ON and the Standby Source set to the specific HDMI source you want to pass through.
post #388 of 388 Old 06-19-2015, 12:16 PM
archiguy's Avatar
Liked: 1044
Ah, thanks. They sent along a printed note with the repaired receiver that said to set HDMI Control to "off" when hooking up HDMI devices to it. I never bothered to turn it back on when everything was done, thinking it unnecessary.
683 , b&w , Emotiva , Marantz , Marantz Sr6007 Home Theater Av Receiver , xpa5
