Marantz SR6007 AV Receiver Owner's Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #181 of 417 Old 08-19-2013, 08:26 PM
jdsmoothie's Avatar
Quoted: 12168 Post(s)
Liked: 5545
The X4000 like the 7008 features the much more advanced Audyssey MultEQ XT32 while the 6008 is more in line with the X3000.
jdsmoothie is offline
post #182 of 417 Old 08-21-2013, 06:42 PM
kweisen's Avatar
Question for anyone that knows. When im playing the marantz at its "loudest" around 85 on the 0-100 scale it sometimes shuts off spontaneously. Is this the amp becoming overloaded? Am I damaging the unit when this occurs? -Thanks
kweisen is offline
post #183 of 417 Old 08-21-2013, 07:09 PM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 757
yep, means there is too much clipping (distortion), running too hot, etc and the power supply's protection circuits are shutting it down. You're probably damaging your speakers first, especially the tweeter.
From the manual on page 157.
Protection Circuit
This is a function to prevent damage to devices
within the power supply when an abnormality
such as an overload, excess voltage occurs or
temperature for any reason.
In this unit, the STANDBY indicator blinks and the unit
enters standby mode when an abnormality occurs.
Afro GT
afrogt is offline
post #184 of 417 Old 08-21-2013, 07:51 PM
kweisen's Avatar
I thought my speakers could handle more power though than the marantz could output? They are definitive technology mythos 4
kweisen is offline
post #185 of 417 Old 08-21-2013, 08:05 PM
Sean Spamilton's Avatar
Quoted: 345 Post(s)
Liked: 398
I had an issue once where a small strand of speaker wire had gotten loose and was spanning the positive and negative speaker terminals - it kept shutting down at about 50percent until I figured it out - did you do any re - wiring lately? maybe make sure that the polarity is all properly set and there's no extra strands of speaker wire mucking about.
Sean Spamilton is online now
post #186 of 417 Old 08-21-2013, 08:25 PM
kweisen's Avatar
Just went through all of my connections and they are all solid. Possibly a higher gauge wire? Not sure what mine is but am I correct in saying the mythos 4 can handle all the power of the marantz even in a two channel?
kweisen is offline
post #187 of 417 Old 08-21-2013, 08:44 PM
Quoted: 345 Post(s)
Liked: 398
It has nothing to do with the gauge of the speaker wire. You're speakers are listed as being 8ohm @ 25 - 225 ... so from what I'm seeing they should have no trouble with the Marantz at high volumes, but I'm afraid beyond that I'll have to differ to some of the other members with more technical know how than myself. You checked the polarity right? not just loose strands? Did Audyssey give you any feedback when you did room correction ? I.E. did it give you any " out of phase " reports? ... How well ventilated is your AVR? .. if it's in a cabinet with no air circulation it could be contributing to it over heating. If it's out in the open, I'm stumped.
post #188 of 417 Old 08-21-2013, 09:25 PM
kweisen's Avatar
Yea im sitting here scratching my head as well. All the numbers are matching up but something here is not right. Polarity is correct (red and black speaker wire so it would be hard to mess up). I guess it could be the ventilation. Its on the bottom cabinet of a mini av rack with 4 other components. It has 3inches of breathing room above it and an open back with 6 inches from the wall. I suppose I could aim a fan at it and see if that helps and if it does install some ventilation... other than that im not sure what could be wrong
kweisen is offline
post #189 of 417 Old 08-22-2013, 02:32 AM
jdsmoothie's Avatar
Liked: 5545
Keep in mind that the mfr rating on the AVR is just an average when running 2 speakers at a THD of 0.08%. It is capable of far higher wattage at a higher THD which is why it's recommended you never go above 80/0db on the master volume to avoid the AVR from shutting down in protection mode. Also note the following as an indicator of why the unit may be shutting down ..
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#user_B10
post #190 of 417 Old 08-22-2013, 10:02 AM
kweisen's Avatar
Very helpful link jdsmoothie thank you! I will have to give my unit a look again tonight and see exactly what type of flashing it is. Also in regard to the 80/0db limit this is because of the avr limitations not the speakers correct? So if I went out and bought a used emotiva I could then push it in to the 90 region? -Thanks
kweisen is offline
post #191 of 417 Old 09-06-2013, 09:56 AM
ejn1's Avatar
Quoted: 75 Post(s)
Hi, I have a UK version of the SR6007 and was wondering if anyone knows if they can be voltage converted easily when I move back to the states?
ejn1 is offline
post #192 of 417 Old 09-06-2013, 11:09 AM
jdsmoothie's Avatar
Liked: 5545
post #193 of 417 Old 09-06-2013, 11:16 AM
ejn1's Avatar
Quoted: 75 Post(s)
You may want to check with these guys ....
http://www.220-electronics.com/?gclid=COfVlOCgt7kCFWJp7AodAWIAcg
Thanks, they don't do that... just offer a transformer. Some audio gear is easily convertible with dip switch settings under the hood, some need to have the internal power supply changed. Some mfg don't do it so that you get raped and have to buy new gear every time you move! Just checking if anyone has any experience on the Marantz side. thanks again for the quick response.
ejn1 is offline
post #194 of 417 Old 09-07-2013, 02:36 PM
mjcabral951's Avatar
Quoted: 13 Post(s)
Just picked one of these up. Can this device Bi-AMP and make use of zone two at the same time?
mjcabral951 is offline
post #195 of 417 Old 09-07-2013, 07:54 PM
jdsmoothie's Avatar
Liked: 5545
It's a 7.2 AVR so you have a choice of (5.1 + Zone 2) or (5.1 + bi-amp). To get both you would have to use a 2CH amp connected to the Zone 2 pre-outs.
post #196 of 417 Old 09-07-2013, 08:26 PM
Quoted: 13 Post(s)
Okay. I was just a little confused because it has two sets of Left and Right Front channel as well as two sets of surrounds for a total of nine speakers.
post #197 of 417 Old 09-08-2013, 05:37 AM
lapino's Avatar
Quoted: 73 Post(s)
I have a somewhat annoying problem. My SR6007 is connected to both my Panasonic plasma and a Benq w1070 projector. Sometimes, when I turn off the tv and the projector on, it seems the receiver does not detect the projector as being "on" and does not output a hdmi signal to the second hdmi output. Only solution to this seems to be turning off the projector and back on (which is not adviseable). On my previous Marantz, I could manually select which hdmi output was used, but it seems on the SR6007 it only does this automatically and there's no way to force either hdmi1 or hdmi2 (I know I can go into the menu and put it to hdmi2 only, but that's kinda hard to do when the tv is not on. Switching back would require me to keep the projector on, set it to hdmi1, turn it off and then the tv on).
So my question is: is there some way to use the remote to force either hdmi1 or hdmi 2?
lapino is offline
post #198 of 417 Old 09-08-2013, 05:56 AM
jdsmoothie's Avatar
Liked: 5545
Correct. The 6007 features a set of "Front B" speaker posts for convenience for those that prefer to use a second set of FL/FR speakers for music listening only.
post #199 of 417 Old 09-08-2013, 06:20 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I think that manufacturers use power supplies that only work in certain countries to maintain a pricing structure that is more favorable in the US.
I don't know how things are now, but audio gear is sold in the US on more of a credit card and carry basis, while personal service at the retail sales point was higher in Europe (back in the late 1960s).
arnyk is offline
post #200 of 417 Old 09-08-2013, 07:04 AM
jdsmoothie's Avatar
Liked: 5545
Nothing on the stock remote, although if you have a Harmony remote you could try copying the code from your previous remote into the Harmony. Otherwise, to mitigate any HDMI handshake issue, always start with all devices powered off and then power on the PJ, then AVR, then source device, and if you have a Harmony, the above sequence could be stored to a single button operation.
post #201 of 417 Old 09-08-2013, 03:35 PM
Ma Rantz's Avatar
I have been having difficulty tuning in a particular station with the internet radio . I am trying to listen to the Chicago Bears football game. It is broadcast on WBBM chicago. This station is listed in the station search/menu. The problem is when I select WBBM it doesn't tune to that station. It tunes to the station listed just below WBBM. (same content played for WBBM and station just below) It is obviously not tuning in to the selected station even though it is a listed station. I can get the station on my compute (same network as AVR) at the station's web site.
Any ideas what is the problem ? Solutions ? I have been looking online but can't seem to find anything. Can't find anything in the manual either. Thanks. This appears to be a random issue as I can repeat similar repeat content for different stations. This does not occur with most listed stations.
Ma Rantz is offline
post #202 of 417 Old 09-08-2013, 04:43 PM
ickabod665's Avatar
I don't have an answer for you, but i can tell ya 2 things. One, i'm able to tune into the channel here in Buffalo. And two, i've had a similar problem with the local Bills station (not that that's relevant, just pointing out the irony) but it happens randomly and not all that often. The few times i've noticed it happening have both occurred at times when i'd already had the channel tuned in for a few hours - it would just "go out". Interestingly enough, i checked the streaming to my computer a couple times when it happened - one time it streamed to the computer just fine, but the other time it didn't.
So i'd be interested if anyone had an answer also.
ickabod665 is offline
post #203 of 417 Old 09-08-2013, 07:47 PM
Ma Rantz's Avatar
Thanks for the information. This is like the old "bait 'n' switch". Advertise WBBM Cicago but receive another channel despite selecting WBBM. It's a mirror of the next listed channel in the selection menu of station names/freq. It's not like I'm in the Chicago land area and there was a blackout of the game or anything like that. Just receiving double channels at that particular area/station number.
I've had lots of internet stations just drop out and vanish after listening to them for a while. Sometimes after just minutes. Other times after several hours of having the receiver on to a particular station. Kind of annoying to say the least. It appears to be more of a station/site issue or internet service issue and nothing to do with the receiver. Not a big fan of the lag time between remote and change in function / channel with the internet radio.
Still can't get WBBM out of Chicago on the receiver but not a problem online through the computer. Running both through same modem & router.
Ma Rantz is offline
post #204 of 417 Old 09-10-2013, 02:18 PM
ickabod665's Avatar
Did you try setting it up as one of you "radiomarantz" favorites and trying to access it that way?
post #205 of 417 Old 09-10-2013, 03:52 PM
Ma Rantz's Avatar
Yes. Accessed the particular station in question (WBBM-chicago) every possible way I could think of including manually searching for it . Thanks.
Ma Rantz is offline
post #206 of 417 Old 09-17-2013, 05:55 PM
TheBucketOfTruth's Avatar
Quoted: 42 Post(s)
Newish SR6007 owner here. I just updated the Marantz app for my phone and now updating firmware from today for the receiver itself. Hopefully this means the app doesn't lose connection to the receiver every 3/4 times I use it.
I find it odd and disappointing that you can't adjust speaker levels from the remote and instead have to go into the menus and run test tones every time.
TV: Sony XBR55HX929
Receiver: Integra DTR-70.4
Speakers: Two Vienna Acoustics Beethoven Baby Grand towers, a Maestro center, and two Solus SR-C6 in-ceiling rears
Sub: WTB used Rythmik or JL Audio
TheBucketOfTruth is offline
post #207 of 417 Old 09-17-2013, 06:32 PM
jdsmoothie's Avatar
Liked: 5545
Sadly this is a feature on the older models which for some reason the D&M folks decided to remove. frown.gif
post #208 of 417 Old 09-17-2013, 06:58 PM
ickabod665's Avatar
Does anyone know what's included in today's firmware update?
I updated, but nothing is standing out.
post #209 of 417 Old 09-21-2013, 02:59 PM - Thread Starter
g12345567's Avatar
Also got the recent update for my Australian SR6007. No idea what has been fixed or updated. Its a shame this info is not readily available.
g12345567 is offline
post #210 of 417 Old 09-29-2013, 12:12 PM
symblized's Avatar
I have a Zone 2 set up with one MartinLogan Helos 22 Stereo speaker in my kitchen. If I am watching sports, and want to get something in/do work in the kitchen, I'd like to be able to hear the game. However, when I switch Zone 2 over to my cable input, all I hear are the right and left channels, so the center channel voice doesn't come through. Is there a way to fix this?
symblized is offline
683 , b&w , Emotiva , Marantz , Marantz Sr6007 Home Theater Av Receiver , xpa5
