Marantz SR7007 issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-14-2012, 04:27 PM - Thread Starter
russta's Avatar
Hi eveybody,
Just purchased the Marantz SR7007 and set it up, HDMI PS3 into Receiver, HDMI out from Receiver to TV, pretty simple. Was watching a movie on the PS3 and the video would flicker every now and then, and eventually it would happen a whole lot (sound would stay solid). I changed the HDMI cables thinking this may be the issue, but did not fix the problem.
Any suggestions?
russta is offline
post #2 of 6 Old 10-14-2012, 05:28 PM
maladjusted's Avatar
HI, TBH if i was after investing in an receiver like a marantz sr7007,id be looking at a decent marantz or denon BDP- or at least oppo's entry model...i had similar issues with the ps3 with my old pio vsx lx70,then i bought a bdp51 & never looked back wether or not using video conversion on avr. Are you using any motion interpolation on tv?, could be that either. ATB.
"Do your best & don't worry"
maladjusted is offline
post #3 of 6 Old 10-14-2012, 06:43 PM - Thread Starter
russta's Avatar
Thanks for your reply. I don't really know about the motion interpolation thing, I have a 55HX850 Sony TV with factory settings. I never had any problems with the PS3 playing movies when I had it hooked directly into the TV, just since the introduction of the receiver.
russta is offline
post #4 of 6 Old 10-17-2012, 10:25 AM
try a motionflow setting on your hx, standard or clear for example & it might cure your flicker problem. Is the sr7007 doing the scaling?..smile.gif
post #5 of 6 Old 10-17-2012, 11:46 AM
myriadcorp's Avatar
Quoted: 42 Post(s)
Liked: 69
My new Denon 2113ci does the flicker when in the PS3 menu screen. If I turn the AVR off and on it usually stops it. The problem is intermittent and has not happened in games or movies yet. I did the same as you by swapping HDMI cables. When I plugged the HDMI directly into the TV it stopped flickering. It has to be something with a setting or the way Marantz/Denon handle their HDMI.
myriadcorp is offline
post #6 of 6 Old 10-17-2012, 12:05 PM
jdsmoothie's Avatar
Quoted: 15335 Post(s)
Liked: 7489
On the PS3, set "Deep Color Output" to OFF.
Also note there is a dedicated thread for Marantz SR7007 Owners ....
http://www.avsforum.com/t/1420942/marantz-sr7007-av-receiver-owners-thread/0_100
jdsmoothie is offline
Marantz Sr7007 Home Theater Av Receiver
