Poor am radio reception from my Denon - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-17-2012, 09:57 AM - Thread Starter
ashofer's Avatar
What can I do to improve the reception coming from my Denon? I'm not sure what the model is (I'm at work) but I paid about $1000 6 years ago.
ashofer is offline
post #2 of 5 Old 10-17-2012, 11:30 AM
jdsmoothie's Avatar
Quoted: 15370 Post(s)
Liked: 7517
Try relocating the existing antenna to another location in the room, or add a powered antenna, or use a roof mounted antenna.
jdsmoothie is offline
post #3 of 5 Old 10-17-2012, 01:24 PM - Thread Starter
ashofer's Avatar
Thank you, What power antenna would you recommend.
ashofer is offline
post #4 of 5 Old 10-17-2012, 05:12 PM
jdsmoothie's Avatar
Liked: 7517
No specific recommendation although Best Buy is a good source and you can return it if it doesn't work any better.
post #5 of 5 Old 10-18-2012, 03:05 AM
has7738's Avatar
Liked: 24
Try this one:
http://www.amazon.com/Terk-Indoor-AM-Antenna-ADVANTAGE/dp/B000069EUW
The basic design isn't new, been around for years, and it does work well. Don't forget AM antennas are directional, the need to be perpendicular to the direction of the station.
has7738 is offline
