Best Room calibration software - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 10-19-2012, 10:06 PM - Thread Starter
TVMAN1991's Avatar
Quoted: 54 Post(s)
Liked: 54
I'm using the Pio Elite SC-55 with advanced MCACC. I'm wondering if the Audyssey XT32? is that much better of room correction software apart from sub EQ? I have a JL F112 and it has auto EQ anyways, so I don't need bass EQ. Or is there another Audyssey better?
TVMAN1991 is offline
post #2 of 12 Old 10-19-2012, 10:19 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
There's the pro version of Audyssey but not all units can support it from the little I know (I'd go review the Audyssey site), otherwise the XT32 is the top of the heap for now. I only have experience with advanced MCACC and Audyssey XT, but hard to compare because I changed speakers. I do like the Audyssey, though. The MCACC I can't check anymore because apparently the HDMI board died.
lovinthehd is offline
post #3 of 12 Old 10-20-2012, 04:04 AM
jdsmoothie's Avatar
Quoted: 12107 Post(s)
Liked: 5510
Audyssey XT32 is the top version. The Audyssey Pro Installer Kit can be used with either XT or XT32 and allows for more tweaking of either version. You'll find those that prefer Audysssey over MCACC and vice versa.
jdsmoothie is offline
post #4 of 12 Old 10-20-2012, 06:12 AM - Thread Starter
TVMAN1991's Avatar
Quoted: 54 Post(s)
Liked: 54
Which do you like better?
post #5 of 12 Old 10-20-2012, 07:27 AM
bfreedma's Avatar
Liked: 51
I made the switch from MCACC to Audyssey XT32 and for me, XT32 was far better, particularly in how it integrated the subs and the seamlessness of the surrounds. I have a pair of JL F113's and while ARO is beneficial, it can only tame one peak, leaving the rest of the bass range untouched. Running ARO then applying XT32 was a very significant improvement for my system.
I've installed the Pro kit on my system as well and while it was worth it for me, the improvement was much smaller than the original transition from MCACC to XT32.
bfreedma is offline
post #6 of 12 Old 10-20-2012, 09:22 AM - Thread Starter
TVMAN1991's Avatar
Quoted: 54 Post(s)
Liked: 54
I ended up grabbing an Anthem MRX receiver for Anthem Room Correction to pair with my Emotiva XPR-5. I've read so many incredible things about ARC.
post #7 of 12 Old 12-05-2012, 08:54 AM
dicksonchan's Avatar
How was the sound quality with Emotiva paired with Anthem MRx?
dicksonchan is offline
post #8 of 12 Old 12-05-2012, 10:50 AM
NorCalJason's Avatar
Liked: 30
I'm going to suggest something different...
From what I've learned about Room Correction over the years, it's meant to tame frequencies that interact with the room your equipment is in.
Your room is mostly influenced by low frequencies. Meaning, vibration of room/furnature/walls/etc. Therefore the largest impact room correction can have, is on the subwoofer channel.
This makes sense to me, and it's why I purchased a sub eq many years ago. I used REW and a microphone to generate my own test tones, and applied parametric filters at specific octaves.
IMO, the question should be: "what can I do to get a smooth in-room response from my subwoofer".
If it's already dialed in, there's no real benefit of different room correction. And dumping an expensive receiver to pickup another one, just for a different sub eq, sounds silly.
NorCalJason is offline
post #9 of 12 Old 12-05-2012, 08:50 PM
derrickdj1's Avatar
Quoted: 880 Post(s)
Liked: 591
All of the major systems can give you a smooth room response. Multiple subs help with the bass in the room due to standing waves and room modes. SQ EQ is good but, it is not the end all for smooth bass in the room. LOCATION, location of the subs is most important.
derrickdj1 is online now
post #10 of 12 Old 12-05-2012, 09:08 PM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
Right idea but not the whole story.  The frequencies that require attention are those below the "critical frequency" which is determined by the room's dimensions.  For a typical domestic room, that critical frequency is about 250 or 300Hz.   Consequently, correction only of the subwoofer(s) means that the range from where the main channels come on (again, typically, 80Hz) and the critical frequency need EQ as well.  In fact, one of the significant advantages of Audyssey MultEQ XT32 over its predecessors is its inclusion of more filter ability in that range on all the main channels.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #11 of 12 Old 12-06-2012, 12:19 AM
gurkey's Avatar
Quoted: 113 Post(s)
Liked: 89
Additionally to those "standard" room correction systems like Audyssey, YAPO (Yamaha) and MCACC (Pioneer) etc. there are specialized and highly regarded add-ons like the DSPeaker Antimode 8033, which tame only the sub-woofer channel up to either 160 Hz or 250 Hz (depending on model) and the Dual Core 2.0 version, which handles the complete frequency band for two channels. Antimode works in parallel with those mentioned standard room correction systems, in my case with Audyssey MultEQ XT32.
gurkey is offline
post #12 of 12 Old 12-06-2012, 04:23 AM
Theresa's Avatar
Liked: 51
I use a Omnimic with miniDSPs to do real time equalization after running Audyssey.
Theresa is offline
