Looking for opinions the following two ch. amps - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-21-2012, 05:47 PM - Thread Starter
Management's Avatar
I am looking at purchasing a pair of Paradigm Signature S2 or B&W PM1 and would like to know opinions on the following amplifiers. I would like to know how well they perform, opinions of the brand, matching to the aforementioned speakers. I like warm sound.
1. Parasound - 2250 250-Watt THX Ultra2 Two-Channel Amplifier
2. Emotiva - XPA-2
3. Rotel - RB-1582 (Class AB)
4. Rotel - RB-1572 (Class D)
Any others I should consider?
Management is offline
post #2 of 4 Old 10-21-2012, 08:04 PM
runnin''s Avatar
Liked: 45
I don't have an xpa-2, but a xpa-3 running my Paradigm Signature S6 and I found the amp to be somewhat bright with sibilance at higher volumes with peaks above 80db. Oddly enough I picked up a Parasound Halo A21 and the sibilance was gone.
runnin' is offline
post #3 of 4 Old 10-22-2012, 08:43 AM
derrickdj1's Avatar
Quoted: 883 Post(s)
Liked: 594
If amps sound bright or trouble with silibance, it is the pre-amp/room corrections software in my experience. Source material also makes a difference when selecting an amp. Will the main source be vinyl, digital stream, ect. Then the DAC's come into play. Myself, I use a vintage Yamaha M 80 which is hard to beat without spending several thousands of dollars.
derrickdj1 is offline
post #4 of 4 Old 10-27-2012, 10:45 AM
runnin''s Avatar
Liked: 45
While I generally agree with this, sometimes a certain speaker and amp combination just do not have synergy. In my particular system, there is no room correction or even pre amp, it's just an Oppo 95 and a Parasound A21 running Paradigm Sig 6's in a stereo set up. The room is large with 9 foot ceilings and carpeted with nothing between the speakers and the listening chair(like a coffee table) and I was getting sibilance with volume peaking at 82db or above which is maybe one watt per channel with the Emotiva amp. Mind you that was only with some recordings, not all.
Perhaps with some pre amps it would not be an issue, but I would be cautious in getting an Emotiva XPA amp if you have speakers known to have a brighter top end.
runnin' is offline
