VSX-52 "server error" message - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-23-2012, 11:05 AM - Thread Starter
Jmorabito25's Avatar
Please help. I've had no issues connecting to Pandora and Internet Radio from my VSX-52. All of the sudden, I am unable to connect through the receiver and I get a "server error" message when I try. I'm still able to pull an IP address, but that's it.
Any suggestions????
Jmorabito25 is offline
post #2 of 3 Old 02-01-2013, 01:32 PM
golfpar01's Avatar
I'm having the same issue as of late. Did you figure it out or ever get an answer??
golfpar01 is offline
post #3 of 3 Old 02-03-2013, 01:15 PM - Thread Starter
I never figured it out. I stopped caring when I found out you can stream pandora from your iPhone or iPad directly to the receiver so there is no need to have pandora on the receiver itself. If you do care and your using a wifi adapter, try plugging the Ethernet cable directly from a router.
Hope that helps.
