trying to reuse some satillite speakers - update: bought a new system :D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 10-24-2012, 04:21 PM - Thread Starter
northeast12's Avatar
ask me anything about video hardware/codecs/inputs/output and I'm all over it. but i dont know much of anything about sound - so i need some advice:
my klipsch promedia 4.1 system kicked the bucket after 10 years. I was really happy with it and never considered buying or upgrading to anything else. Just a couple days ago the sub blew out - it only makes rattling scratchy noises now. I opened up the sub and disconnected it, so i'm essentially using the satellite speakers now. Anyway, I'd like to get some bass back.
I'm thinking i'll toss the sub/amp and reuse the satellite speakers. I use the speakers for music and movies (usually always connected to my laptop, or ipod).
I'm thinking of getting this sub: http://www.amazon.com/gp/product/B0002KVQBA
Now, what exactly do I need to get up and running? I don't want to get a huge receiver. I don't need any functions except on/off and volume control (sound will come from computer). Is there a small amp I can use?
also a plus if it was vintage, or vintage looking. I don't want to spend more than $150 on the amp, or integrated amp, whatever it might be. Would love some suggestions on what would work best for the sub and satellite speakers i'm using.
thanks!
northeast12 is offline
post #2 of 15 Old 10-24-2012, 04:47 PM - Thread Starter
This is a photo of the back of that sub. do the satillite speakers connect to the amp or the sub? how does this all work. thx
post #3 of 15 Old 10-24-2012, 05:16 PM
Knucklehead90's Avatar
Quoted: 382 Post(s)
Liked: 332
Probably the best way to go is with a stereo receiver. Sherwood makes a decent one and it should power two of those promedia speaker just fine. I don't know if it'll power all four. With the Polk sub you'd need to route the speaker wires directly to the sub then out to the speakers. Thats how the sub picks up the audio signal. You'd adjust the crossover and gain level at the back of the sub.
You could go with a Lepai Tripath amp - sounds pretty good for its size. I've been playing around with one for a year or so. Works surprisingly good for what it is. It won't give you the functionality of the Sherwood but it will amplify the audio signal for those speakers.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #4 of 15 Old 10-24-2012, 05:53 PM
M Code's Avatar
Quoted: 716 Post(s)
Liked: 419
The Sherwood RX-4105 stereo receiver is a good budget choice, usually available for around $100..
Note that for connecting up see below:
1. The L/R satellite speakers connect to the subwoofer's Speaker Level L/R Out
2. The loudspeaker outputs (L/R) from the Sherwood go to the subwoofer's Speaker Level L/R In
M Code is online now
post #5 of 15 Old 11-11-2012, 12:55 PM - Thread Starter
thanks for the help, i understand how it all connects up now.
So i'm ready to buy, I found some cool integrated amps, I just want to know if they are powerful enough for my existing speakers (looks like I'll only be using 2 satellite speakers) and 1 sub (linked from amazon).
so with my speakers and sub, which one of these would work best (these will work, right?)
http://www.amazon.com/Qinpu-A3-Integrated-Amplifier/dp/B0057ODYX4/ref=cm_cr_pr_product_top
http://www.amazon.com/Qinpu-Q-2-Hybrid-Integrated-Amplifier/dp/B001TGDB9Q
http://www.amazon.com/NuForce-Icon-Amp-Stereo-Amplifier/dp/B002YDYIW2/
I def want to stay under $200 or less on the amp. most important i want the amp to be compact - i dont want a huge receiver.
thx
post #6 of 15 Old 11-16-2012, 09:30 PM - Thread Starter
can anyone confirm if one of those options will work? thx
post #7 of 15 Old 11-16-2012, 11:32 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Aren't the Promedia 4.1 speakers computer speakers? they're powered speakers that use a 3.5mm input. How exactly do you connect these to a standard AVR?
Afro GT
afrogt is online now
post #8 of 15 Old 11-17-2012, 07:09 AM
Mitchellin's Avatar
So if I understand the use (source) in the matter, it is mainly from a laptop or an Ipod? Planned connectivity is going to be the use of a y cable (mini-jack to RCA)? The 3 options you posted above will work...it's not the route I would go. The sound you are going to obtain from this idea is going to be shat...at the budgeted cost of $200.00?
Jump online and check out the Audioengine A2. The cost is relative to your budget and the sound quality will be MUCH better than the approach you are taking with this Klipsch sats. Purchase made, you can throw those sats on CL for sale and get some money back.
OR...
Denon has a two channel system (D-M37) that is desktop size. The cost is about $50.00 over your budget but (IMHO) well worth it as it allows for ample desktop sound with the available option for a future addition of a sub.
Mitchellin is offline
post #9 of 15 Old 11-18-2012, 12:59 PM - Thread Starter
ok ive been doing more reading.
I'm thinking of getting the Audioengine A2 + a subwoofer. how will this compare to the Klipsch system i was used to?
post #10 of 15 Old 11-19-2012, 11:47 AM - Thread Starter
alright, ive placed my order!
I've been doing a lot of reading in the last week or two learning a little bit about audio. @mitchellin - you really got me thinking about re-using the klipsch satillites. I decided, i've had those for 10 years, it's about time to put some $$ down for a proper upgrade. Here is what I went with:
Audioengine P4 Premium Passive Bookshelf Speaker Pair - $249
http://www.amazon.com/Audioengine-Premium-Passive-Bookshelf-Speaker/dp/B002FJVTGI/
Polk Audio PSW10 10-Inch Monitor Series Powered Subwoofer - $79
http://www.amazon.com/gp/product/B0002KVQBA/
FiiO A1 Mini 2x14W Class-D Digital Audio Amplifier - $59
http://www.amazon.com/gp/product/B004FSXON8
(also ordered 16g speaker wire to hook it all up).
Total cost of equipment: $387
I think it'll be worth the cost, and this system will sound a lot better than my old klipsch system did. looking forward to setting it up!! biggrin.gif
post #11 of 15 Old 11-19-2012, 06:51 PM
Mitchellin's Avatar
It looks as if this will be much better of an idea than trying to use the old sats. Have you thought about a DAC?
Post some pics when you get everything set up.
post #12 of 15 Old 11-19-2012, 10:49 PM - Thread Starter
mitchellin - you have me confused now lol. I just looked up what a dac is - so it coverts the digital signal coming from my laptop (apple)/ipod to an analog signal for the amp. Is this necessary? How much of a difference would it make, and how much would this cost. I was hoping i wouldnt break $400.
post #13 of 15 Old 11-19-2012, 10:55 PM - Thread Starter
this one is only $25 bucks. but now I would need some type of adapter to get my headphone out (from laptop/ipod) to a coaxial plug? bah, i think i'll just pass on this unless you can convince me otherwise.
http://www.amazon.com/D3-Digital-Converter-Optical-Toslink/dp/B005K2TXMO
post #14 of 15 Old 11-26-2012, 07:51 PM - Thread Starter
update:
read up on the DAC, decided I don't need one. Output from my macbook headphone port should be fine.
also I had to cancel the shipping on the Polk subwoofer because I was away for thanksgiving and it was going to be delivered while i was gone. On a whim, when re-ordering, I decided to get the PSW111 instead:
http://www.amazon.com/Polk-Audio-PSW111-Subwoofer-Single/dp/B000P0528U
Should have everything set up by the end of the week and I'll post some pics.
I'm thinking this new setup should be better than my klipsch promedia speaker/sub, is that a fair expectation? biggrin.gif
post #15 of 15 Old 11-26-2012, 08:32 PM - Thread Starter
one more question:
What should i set the subwoofers lowpass to for these speakers? I've been reading about lowpass filters for about an hour, and I understand what it is, but I still don't understand how to calculate the setting. My guess is the 58Hz is the low setting on the speakers, so it would be good to set my bass to Around 60?
here are the specs for the speakers:
P4 Technical Specifications
Type
2-way passive, front ported design
Sensitivity
88dB (2.83v@1m)
Frequency response
58Hz-22kHz
Nominal Impedance
4-8 Ohms
Crossover Frequency
2.8 kHz
