Looking for some receiver suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-26-2012, 10:34 AM - Thread Starter
erick.s's Avatar
I'm sure these kinds of threads pop up all the time, so I apologize in advance if this is rehashing old territory.
I currently have a Marantz 7000 series that's maybe 6 or 7 years old that has been great in regards to SQ (though menu GUI and navigation is a bit on the challenging side) but doesn't have any HDMI provisions. I just picked up a Panasonic 65" VT50 plasma this month and would like to bring my receiver up to date as well. I'm using 10 year old Mission speakers in this room (the main towers are the 775 model; can't remember the other pieces).
I'm having trouble knowing what to pair these speakers with as I haven't found any retailer near me that carries this brand anymore to do a listening session on so I'm turning to the forum for suggestions and guidance. I'm looking to spend maybe a grand on the new receiver. I'm only running 5.1 in this room and have no plans of changing that.
This is not my primary theater, but I'd like the best SQ possible while having the newest HDMI features (namely 3D compatibility and higher bitrate audio). If it helps the suggestion process, my "reference" system consists of an Integra DTC 9.8 pre/pro connected to a Sunfire 200~7 (using balanced cables) and Definitive Technology speakers (BP7000sc mains, C/L/R 3000 center, BPX side surrounds, and BP2X rears).
What brands and model numbers should I be considering? SQ is important to me, but so is ease of use and modern feature set. I could definitely consider a higher end 5.1 receiver if anyone makes such a thing anymore.
erick.s is offline
post #2 of 6 Old 10-26-2012, 09:20 PM - Thread Starter
erick.s's Avatar
Can anyone point me in a good direction to start my search?
erick.s is offline
post #3 of 6 Old 10-26-2012, 09:36 PM
afrogt's Avatar
Quoted: 1097 Post(s)
Liked: 783
Best Buy with Magonila carries Marantz, Pioneer Elite, Denon and Yamaha receivers. That's a good place start so you can see what they look like.
Do you have one in your area?
Afro GT
afrogt is offline
post #4 of 6 Old 10-27-2012, 01:39 AM
jdsmoothie's Avatar
Quoted: 12623 Post(s)
Liked: 5778
Keep in mind when demoing AVRs in a store that the AVR's Auto EQ program (eg. Denon/Marantz - Audyssey) is unlikely to be enabled so if you like the sound in the store, after running the Auto EQ, your speakers should sound even better.
jdsmoothie is offline
post #5 of 6 Old 10-27-2012, 08:36 AM
myriadcorp's Avatar
Quoted: 42 Post(s)
Liked: 69
I have a old Marantz 7000 series too. The receiver was for my bedroom running Def Tech Pro Cinema speakers. I sort of downgraded but it was actually an upgrade because the new receiver had tons more features due to technological advances. I went with a Denon 2113ci for $400 refurbished. So far its really nice. It does not have the power the Marantz did but with those tiny speakers it doesn't matter too much.
myriadcorp is offline
post #6 of 6 Old 10-27-2012, 10:24 AM - Thread Starter
erick.s's Avatar
Thanks for the thoughts so far. I do have a BB with Magnolia (that's where I bought my VT50 from) so I'll try looking there. I didn't have a lot of faith shopping there for audio because the rooms look pretty cramped and not ideal for listening but I guess I'll need to make do. All the higher end audio shops by me closed down so I don't have a lot of choice.
erick.s is offline
