Bringing in a 240VAC line... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-26-2012, 11:39 AM - Thread Starter
ECinOC's Avatar
Hi All,
It was recommended to me to bring a 240VAC line into my A/V equipment room, which will house an upscale array of amps, a/v components, etc. Being we live in the states, most equipment runs on 120VAC. I am going to purchase a power conditioner, some of which do input at 240VAC and output 120VAC. Is bringing in a 240 line a good idea? I was told 240VAC is cleaner. Thanks!
ECinOC is offline
post #2 of 8 Old 10-26-2012, 11:57 AM
ccotenj's Avatar
Liked: 101
recommended by who???
- chris
ccotenj is offline
post #3 of 8 Old 10-26-2012, 12:12 PM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
Are you thinking of installing a sub panel with breakers for the local circuit needs? That is the only reason I would run 240 to a room. I believe most people just run multiple 120 volt 20 amp circuits.
PeterK is offline
post #4 of 8 Old 10-26-2012, 01:27 PM
BillW's Avatar
A 240 volt line is no cleaner than a 120 volt line, as long as it is a dedicated circuit with it's own neutral.
BillW is offline
post #5 of 8 Old 10-26-2012, 01:56 PM
BeeMan458's Avatar
Liked: 813
Originally Posted by ECinOC View Post
Hi All,
FWIW, all 240V is, is one black and one red, both consisting of 120V and a common, white wire, return.
If one were to look at the service pole, they'd see three wires coming into the home, two hots and a neutral return.
BeeMan458 is offline
post #6 of 8 Old 10-29-2012, 09:59 PM - Thread Starter
ECinOC's Avatar
Well, several manufacturers make A/V power equipment with 240 in and 120 outs. Perhaps there is more to this than might be immediately apparent? I wonder what the "professional" theater builders that have actually done this and frequent this site would say.
ECinOC is offline
post #7 of 8 Old 10-30-2012, 05:57 AM
ccotenj's Avatar
Liked: 101
yes, they do...
but it's not due to what you think...
hint: not everywhere in the world is 120v...
- chris
ccotenj is offline
post #8 of 8 Old 11-01-2012, 01:32 PM
homeav's Avatar
The only real advantage of 240 would be for high current devices, where 240 would yield lower currents.
There is nothing cleaner about it, it's the same electricity that would be fed to any 120v circuit.
homeav is offline
