Panamax 4300-pm ok or go with the 5400-pm? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-29-2012, 07:06 AM - Thread Starter
Limp Fox's Avatar
Quoted: 32 Post(s)
I'm seeing the Panamax 4300-pm for around $200 new and although I love the 5400-pm I can't afford it right now. Is the 4300 a good bang for the buck or should I save up some more for the 5400? Is the 4300 better suited for a bedroom (TV, Blu-ray)? Below is the list of equipment I currently have. Let me know what you all think. I do sure like the display on the 5400 but there around $600 new from what I can see.
Emotiva UMC-1 (eventually going back to a Onkyo)
Emotiva XPA 5
Custom built HTPC with 600 watt power supply
Dish network 722 receiver
Sharp 70" LED
eD A7s-450 sub
eD A2-300 sub
Xbox 360 Elite
360 gig? PS3 - hardly ever used.
US ARMY: 11C48
Come on Retirement. May 2017, can't come soon enough!
Limp Fox is offline
post #2 of 5 Old 10-29-2012, 07:56 AM - Thread Starter
Limp Fox's Avatar
Quoted: 32 Post(s)
edited for subscription
US ARMY: 11C48
Limp Fox is offline
post #3 of 5 Old 10-29-2012, 09:21 AM
New_guy's Avatar
They look pretty similar and for a bedroom system the 4300 should be fine. With 9 devices it looks like with the 4300 you will have to use the front plugin as well, could be an aesthetic issue if that bothers you.
New_guy is offline
post #4 of 5 Old 10-29-2012, 09:40 AM - Thread Starter
Limp Fox's Avatar
Quoted: 32 Post(s)
Well right now I am looking for something in my living room where I have my Theater set up. Just wondering if there's an advatage to the 5400 PM - looks aside and besides the extra outlets and multiple power banks.
US ARMY: 11C48
Limp Fox is offline
post #5 of 5 Old 10-29-2012, 10:49 PM
New_guy's Avatar
Looks aside, mostly these units are good for being able to plug a bunch of stuff into it. It will help your audio/video system if you are getting alot of artifacts/noise/ground hum in your system, and of course you get the surge protection, but other than that its mostly a fancy power bar.
New_guy is offline
