Can you split a preout signal without degrading the signal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-30-2012, 07:37 AM - Thread Starter
michaelkingdom's Avatar
Quoted: 46 Post(s)
Liked: 26
I am splitting an integrated amp's preout signal and sending the signals to two different amps, both of which are within six feet of the integrated amp. I don't hear signal noise but I also don't have a golden ear.
Am I introducing noise? Or is the signal strong enough to be split happily?
michaelkingdom is offline
post #2 of 10 Old 10-30-2012, 08:15 AM
KidHorn's Avatar
Quoted: 1492 Post(s)
Liked: 982
I'm not sure what you mean by degrading, but you'll reduce the voltage by splitting it. In theory, you'll get the same wave form but at a lower amplitude.
KidHorn is offline
post #3 of 10 Old 10-30-2012, 08:22 AM
Kal Rubinson's Avatar
Quoted: 803 Post(s)
Liked: 569
The voltage is not reduced except under the rare condition* that the reduced load is excessive.  Normally, the output of each amplifier is unaffected in amplitude or quality.
(*Paralleled loads split the current and voltage is compromised only if the current capability of the source is exceeded. With normal amp input impedance, this is unlikely.)
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #4 of 10 Old 10-30-2012, 08:51 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
Noise should not be an issue.
If one or both of the amplifiers had an input impedance less than 5K ohms, you might load down the preamp signal enough to create some interfacing problems, but this is not likely. Most amplifiers have a much higher input impedance.
It sounds as if it is working fine, so there is no need to concern yourself.
commsysman is offline
post #5 of 10 Old 10-30-2012, 10:27 AM
KidHorn's Avatar
Liked: 982
I would be very surprised if maintaining the same volume for each amp didn't require turning up the volume. I've never split a signal without amplification where there wasn't a loss in signal strength.
KidHorn is offline
post #6 of 10 Old 10-30-2012, 10:33 AM
Quoted: 803 Post(s)
Liked: 569
Not my experience and not what theory would predict.  The preamp output is modulated voltage signal and the amp input stage detects voltage.  Assuming the two amps are identical, the only reason that the voltage seen by each of the two amps would be if the preamp output stage had inadequate current to maintain the same/original voltage across half of the original load.  Unless the amps had an atypically low input impedance or the preamp was a real weakling, that would not occur.  As I said, in my experience that won't happen.
Kal Rubinson
post #7 of 10 Old 10-30-2012, 11:16 AM
DonH50's Avatar
Quoted: 2217 Post(s)
Liked: 1825
A quick glance at a few spec sheets seems to run around 10k ohms for amp inputs and 100 ohms for preamp outputs. Assuming a perfect source before the preamp Rout, the input voltage at one amplifier is thus 10000/10100 = 0.9901 V for a 1 V source (-0.086 dB). With two amps in parallel the load is now 5k so 5k/5.1k = 0.9804 V (-0.172 dB), a difference of 0.0856 dB (about 0.01 V). Really doubt you'd hear that... I am sure there are exceptions, but in general I agree with Kal. Natch.
FWIWFM - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #8 of 10 Old 10-30-2012, 11:26 AM
M Code's Avatar
Quoted: 815 Post(s)
Liked: 499
You should be fine...
Assuming the preamp is a quality name brand...
Not some low end junker...
M Code is online now
post #9 of 10 Old 10-31-2012, 12:05 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 26
Yes, it does sound fine. And when it sounds fine, it's all fine.
post #10 of 10 Old 07-10-2017, 11:08 AM
chebowitz's Avatar
I realize this is an older thread however, I just started a new thread about connecting a subwoofer to a vintage receiver that, after someone chiming in with a nice simple solution, caused me to raise a question that appears to be similar to this discussion.
Here's the link to my new post and would greatly appreciate any additional feedback.
Connecting Yamaha RX-1100 to Pioneer SW-8MK2 subwoofer
chebowitz is offline
