Denon 2313SI switches to Audio when I chose CBL/SAT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-31-2012, 09:23 AM - Thread Starter
martytoo's Avatar
I have my TW Scientific Atlanta cable box hooked into my 2313 with an HDMI cable. I also have HDMI cable leading from the Denon receiver to my Samsung 40 inch LCD TV on monitor1 position. There is no other connection to the TV. ( No TV Audio).
Other connections to the 2313 are HDMI for my Samsung blue ray player and analog connections (red, white, yellow) from a Pioneer DVD recorder.
I have two problems.
One. When the cable box is on and the TV and Denon are off, the Denon will sometimes begin with the CBL/SAT as the input visible on the TV, but it will revert to TV Audio. This is true whether I turn the Denon on with the red power button on the 2313 Remote or by simply pushing the CBL/SAT button to turn the Denon on. Sometimes I have to hit the CBL/SAT button several times before this automatic selection of TV Audio finally stops. Until then there is no video from the box on the TV.
Sometimes HDMI passthrough works when the Denon is off and sometimes not.
I tried to search this forum for the answers to these problems to no avail.
martytoo is offline
post #2 of 5 Old 10-31-2012, 09:35 AM
jdsmoothie's Avatar
Quoted: 12082 Post(s)
Liked: 5501
Suggest you read the Denon guide linked in my sig (post #3 of the Denon AVR-XX12 owner's thread) which includes a troubleshooting section and the tip below ...
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#user_L5
Also note there is a dedicated thread for Denon AVR-XX13 Owners linked in my sig as well. Review posts #3-6 for additional helpful information.
jdsmoothie is online now
post #3 of 5 Old 10-31-2012, 10:29 PM - Thread Starter
martytoo's Avatar
Thank you. The reversion to TV Audio is no longer a problem. Hopefully I will be able to sort out the lack of consistent pass through if I read all that you have written.I apologize again that my use of the search function on this forum didn't produce the answer for me.
martytoo is offline
post #4 of 5 Old 11-01-2012, 03:03 AM
jdsmoothie's Avatar
Liked: 5501
post #5 of 5 Old 11-18-2012, 06:00 AM - Thread Starter
martytoo's Avatar
OK, help again.
I think I set HDMI passthrough on. It sometimes works.
If I turn the receiver and Samsung TV off and the turn the TV on, what I see is similar to what was happening with my original post concerning TV audio.
When the TV turns on I can see the HDMI signal from my cable box for a second and then nine times out of ten ( or more) the screen goes black. Is this due to a setting or is my gear incompatible with passthrough?
martytoo is offline
