How many watts for my deftech speakers - AVS Forum | Home Theater Discussions And Reviews
Old 11-02-2012, 12:48 AM - Thread Starter
Joji's Avatar
I have the definitive technology pro cinema 600
http://www.definitivetech.com/products/procinema-600-system
Here are the specs.
I listen to movies at a average volume and also medium to soft at night.
How many watts do i need to match these speakers and give the best sound at low volumes so i can still here details in audio
My living room is 19ft by 13ft but the ceiling is 2 floors up
Joji is offline
Old 11-02-2012, 12:52 AM - Thread Starter
Joji's Avatar
Sorry ignore the last duplicate threads. There was a error while posting
Joji is offline
Old 11-02-2012, 04:48 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5500
Those speakers should be fairly easy to drive and on average will only be drawing < 5W/CH so most any AVR (eg. 50W+) will provide more than enough power.
jdsmoothie is offline
Old 11-02-2012, 07:40 AM - Thread Starter
Joji's Avatar
How did you come up with 5watts per channel why do they say they can handle 150 watts?
Joji is offline
Old 11-02-2012, 07:48 AM
jdsmoothie's Avatar
Liked: 5500
Those speakers have an 88db efficiency rating which means if you're seated about 10' from them you will get roughly ...
1W = 78db
2W = 81db
4W = 84db (which is quite loud and generally louder than most folks listen at)
