Simultaneous multichannel and stereo outputs from each hdmi input? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-04-2012, 07:47 AM - Thread Starter
Citation4444's Avatar
Quoted: 186 Post(s)
Liked: 146
I expect I'll have difficulty describing what I want, but here goes. I have a home theater with 7.1 sound which I enjoy tremendously. However, I wear wireless hearing aids and sometimes, many times, want to stream 2-channel sound to my hearing aid streamer (which wirelessly streams to my hearing aids) at the same time I and everybody else are listening to multichannel sound. This sounds easy, right? Not so fast. If I connect the hearing aid streamer to the left and right preamp outputs, I am missing the center channel to my hearing aids that carries most of the dialog. With my current receiver (Denon AVR-4306) I have a workaround by creating an additional virtual output using zone 2 and using the stereo outputs from my DirecTV receiver for the input for this virtual output. This works fine and everybody else, including me, can enjoy the regular multichannel sound and I can have a little help using the wireless hearing aids. The problem is it only works for one input (DirecTV).
Now, here's my question. Does any AVR have the feature of a stereo output (not just FL and FR) that can be used simultaneously with multichannel sound, on ALL of the hdmi sources? That is, an output that is not devoid of the center channel info.
Citation4444 is offline
post #2 of 9 Old 11-04-2012, 10:41 AM
jdsmoothie's Avatar
Quoted: 14333 Post(s)
Liked: 6767
Are you not able to simply also connect a RCA cable from the other HDMI sources you want to pass to Zone 2?
jdsmoothie is online now
post #3 of 9 Old 11-04-2012, 11:17 AM - Thread Starter
Quoted: 186 Post(s)
Liked: 146
Some of my hdmi sources don't have analog outputs. Neither my Roku nor XBox 360 have analog audio outputs when using hdmi. My DirecTV , BluRay, HDDVD, and HTPC do however. This is a lot of cables, though, and I'd like a more elegant solution. Maybe it doesn't exist.
post #4 of 9 Old 11-04-2012, 11:24 AM
jdsmoothie's Avatar
Liked: 6767
post #5 of 9 Old 04-18-2013, 07:13 AM - Thread Starter
Quoted: 186 Post(s)
Liked: 146
I'm now in the market for a new receiver and want to ask my question again. Per the above, does any of the new AVR's have this feature?
post #6 of 9 Old 04-20-2013, 01:04 AM
jdsmoothie's Avatar
Liked: 6767
The new 2013 Denon "In Command" models (formerly "CI" and now "X") are to be announced on May 1 and released May/June and should provide what you're after. Refer to the 2013 Denon AVR thread linked in my sig for more updated information as more details become available.
post #7 of 9 Old 04-20-2013, 08:25 AM - Thread Starter
Quoted: 186 Post(s)
Liked: 146
Yes, it appears I can set zone 2 preamp outs to be stereo getting its signal from the same hdmi that is supplying the main zone. This would essentially allow a wireless headphone output for stereo sound. Is Denon the only mfgr that will allow this?
post #8 of 9 Old 04-20-2013, 09:18 AM
jdsmoothie's Avatar
Liked: 6767
Haven't researched other mfr's models so no information there.
post #9 of 9 Old 04-20-2013, 09:59 AM
Ross Ridge's Avatar
Liked: 81
The Yamaha RX-A3020 can do this, regardless of whether the same input, HDMI or not, is selected in both zones. I'm pretty sure this the only AV receiver you can buy today capable of having multichannel HDMI audio in the main zone while downmixing the same HDMI audio to stereo in zone 2.
Ross Ridge is offline
