Pioneer VSX 1122 or the Denon 1913? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-04-2012, 10:16 PM - Thread Starter
jpopperez's Avatar
I have the 1122 dealing with handshaking issues called bb they said they would swap it for the same or another receiver. I was reading reviews and they said that the denon was better out of the two what do you guys think keep the vsx or swap for 1913? Let me know input wanted. Thanks
Buffalo, NY
jpopperez is offline
post #2 of 9 Old 11-05-2012, 12:01 AM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
I would get the Denon 1913 because I like the Audyssey MultEQ room calibration over the Pioneer MCACC. Plus you get a Denon 2 year warranty vs only 1 year on the Pioneer.
Afro GT
afrogt is offline
post #3 of 9 Old 11-05-2012, 11:12 AM - Thread Starter
jpopperez's Avatar
Exchanged for the denon ran aides set twice set my fronts and center to full band and set my surrounds to 40 he I'm use to setting everything to small and 80 hz. Should I leave it or go and change to 80 and small?
Buffalo, NY
post #4 of 9 Old 11-05-2012, 11:25 AM
afrogt's Avatar
Liked: 982
Change them back to 80hz and small. What speakers and sub do you have? Don't see it mentioned in this thread.
How does it sound?
Afro GT
afrogt is offline
post #5 of 9 Old 11-05-2012, 12:03 PM - Thread Starter
jpopperez's Avatar
I have monitor 50s for fronts, CS1,monitor 40s for rears, and a ESW-V10 I set them back to small and 80hz
Buffalo, NY
post #6 of 9 Old 11-05-2012, 12:05 PM
jdsmoothie's Avatar
Quoted: 15332 Post(s)
Liked: 7488
For more info on proper Audyssey setup (to include using a camera tripod or mic boom stand), review the Audyssey 101/FAQ Guide linked in my sig.
jdsmoothie is offline
post #7 of 9 Old 11-05-2012, 12:15 PM - Thread Starter
jpopperez's Avatar
I ran audessey a lot when I had the onkyo 606.
Buffalo, NY
post #8 of 9 Old 11-05-2012, 12:25 PM
jdsmoothie's Avatar
Liked: 7488
A little different now as the 606 only uses the lowest version of 2EQ which cannot EQ the subwoofer while the 1913 uses MultEQ which can EQ the subwoofer, so it's even more important to transfer the lower frequencies < 80Hz to the sub.
post #9 of 9 Old 11-05-2012, 12:33 PM - Thread Starter
jpopperez's Avatar
Yeah I switched all the speakers to small and 80 hz and the bass management is at 120 hz and I saved it afterwards anything else I can do to bring out the best?
Buffalo, NY
