Best 750-1000$ AV receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-07-2012, 02:33 AM - Thread Starter
Guip2010's Avatar
Hi,
i'm searching for the best AV receiver for 750$ to 1000$. Pioneer Elite, Yamaha avantage, onkyo, denon, marantz? Thanks!
Guip2010 is offline
post #2 of 7 Old 11-07-2012, 04:58 AM
jdsmoothie's Avatar
Quoted: 12264 Post(s)
Liked: 5593
Best is in the eye (and ear) of the beholder, not to mention it also depends on what speakers you are using. You're much better served with a lower quality AVR and better quality speakers than vice versa. First determine what features you want and then research to find which models offer those features. Get out to some hi fi shops or Big Box stores and demo some models as well. You can review post #2 in each of the Denon AVR-XX12 and XX13 Owner's threads to get an idea of features offered on the current Denon models.
jdsmoothie is offline
post #3 of 7 Old 11-07-2012, 02:37 PM - Thread Starter
Guip2010's Avatar
Thanks for your reply,
I plan on buying a Klipsch RF-62 II seven speakers home theater with a Bic Acoustech PL-200 sub. My room is aproxymetly 10' X 14', and since I can't install surround back speakers (my couch is against the wall), I would have a 7.1 setup with front height instead of surround back. The HT will be be mainly used for movies (70%) and sometimes for music (30%). I'm not looking for a receiver with tons a features, i'm looking for one with excellent audio and video.
Guip2010 is offline
post #4 of 7 Old 11-07-2012, 03:55 PM
Kini62's Avatar
Quoted: 1441 Post(s)
Liked: 1332
Seems reviews of the current Pioneers get top marks for video and audio. You might want to add the Sony ES2800 to your list as well. Some really nice features and good video processing chip.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #5 of 7 Old 11-07-2012, 05:02 PM
jdsmoothie's Avatar
Liked: 5593
Budget? Consider the Denon AVR-4311CI on clearance now as it has been replaced by the newer 4520CI.
post #6 of 7 Old 11-07-2012, 08:03 PM
Avax's Avatar
I am in a similar search. I ruled out onkio as I was probably was going to go refurb and I figured most of them probably where returned for the hdmi failures. I didn't want to take the chance.
Then I started looking at the refurb Denon until my boss told me his horror story, he is on his 3rd Returned Denon and it has failed. I'm sure it is not most people's experience.
Now I am looking at the Pioneer Elite SC-61 street price at the bottom of your range. The newly designed class D3 amps have got pretty good reviews. From what I have read here some don't care for the way it is logically organized.
Avax is offline
post #7 of 7 Old 11-07-2012, 09:21 PM
jpopperez's Avatar
Denon is good buy fresh
Buffalo, NY
jpopperez is offline
