Denon AVP-A1HD vs. Mcintosh MX-151...Need Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 11-07-2012, 02:20 PM - Thread Starter
MV_Cinema's Avatar
Hi to All Members
I wanted to buy in first place a Denon POA-A1HD to give more power to my system...but then after searching i've decided to go the Processor also, so i tought on buying Denon AVP-A1HD and POA-A1HD and match them.
However since those are discontinued i and i am having a hard time finding them in Europe i tough is getting something similar with the Denon performance...so i am thinking on the Mcintosh MX-151 and instead of the POA buy 3 MC501 or 2 MC303 to make my 6.1 System. I tought on the MC8207, but has less power and the blue maters are digital...i don't like that.
Do you think for movies i will have less performance with the Mcintosh System than the Denon?
I watch 99% Movies and 1% Music.
My Speakers are:
- Klipsch RF-7 II (Front)
- Klipsch RF-82 II (Rear)
- Klipsch RS-62 II (Rear Center)
- Klipsch RC-64 ( Front Center)
- SVS PB-13 Ultra Subwoofer
MV_Cinema is offline
post #2 of 20 Old 11-07-2012, 02:59 PM
keyboardcat's Avatar
Mcintosh sounds good, but it cost to much compared to other good sounding brands. I think that the price on Mcintosh amps are just not worth it unless you have a lot of money that you don't mind spending. Mcintosh is out of my price range. denon sounds good also. I suggest the Denon
keyboardcat is offline
post #3 of 20 Old 11-07-2012, 03:15 PM - Thread Starter
MV_Cinema's Avatar
I also would like Denon, but where do i find an AVP-A1HD and POA-A1HD now in Europe? That's the issue...
post #4 of 20 Old 11-07-2012, 03:22 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
An AVP or a MX-151 + some mega amps like MC-303 x 2 seems like a bit of overkill for your speakers.
Sam S is offline
post #5 of 20 Old 11-07-2012, 03:24 PM - Thread Starter
MV_Cinema's Avatar
I don't think so...These are the Reference Line and you should check the specs....I had Monitor Audio RX8; RX6 and all the Silver line and these are WAY BETTER.....
I use the Pioneer SC-LX90 Susano to drive them...
post #6 of 20 Old 11-07-2012, 03:35 PM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
mogorf is online now
post #7 of 20 Old 11-07-2012, 03:41 PM - Thread Starter
MV_Cinema's Avatar
Denon Portugal doesn't has and cannot get, but Denon Germany i didn't.... But i will.
post #8 of 20 Old 11-07-2012, 03:49 PM
mogorf's Avatar
Liked: 613
Hi Sam. I think the overkill would come from the other way around, i.e. the Klipsch seem to me to be overkill. Honestly speakers, although MV didn't specify the size of his room, but those speakers with an ultra high sensitivity rated @ 101 dB may cause some "head-scratching" when Audyssey on the AVP will not be able to set the trims of each speaker, but will max out on the negative side (at -12 dB). Worry not, this is a known issue and the most practical (and cheapest) work around is to insert attenuator pads between the AVP outs and the POA ins. (One for each channel, except the sub, of course.)
post #9 of 20 Old 11-07-2012, 03:50 PM - Thread Starter
MV_Cinema's Avatar
In the case of the MX-151 and 2 MC303 for example i was checking, and where's the connection for the subwoofers? confused.gif
post #10 of 20 Old 11-07-2012, 03:54 PM - Thread Starter
MV_Cinema's Avatar
Sorry for my ignorance, but i never heard of attenuator pads. But i am a good learner smile.gif Should i buy those?
By the way do you think the option of the Mcintosh MX-151 and 2 MC's 303 will be better or worst than the Denon AVP + POA? The room has 30m2
Just discovered that the Mcintosh does not has any Video Processor inside like the Denon.. frown.gif
post #11 of 20 Old 11-07-2012, 04:31 PM
mogorf's Avatar
Liked: 613
If i were you I would first look around at some local electronic stores/depots to find out the availability, and when you have your HT gear and run into the trouble I mentioned then you may buy them. No need to spend money in advance.
I think if SQ (Sound Quality) is important for you you should either go for the Denon line (with Audyssey on board) or check out the MX-121 which also has Audyssey (MultEQ XT + DynEQ + DynVol) compared to the MX-151 with RoomPerfect only. You may compare the MC's here.
The room has 30m2
Normally pretty big, but with the extra high sensitivity of the Klipsches, I have a fear you will need those attenuator pads in the end. wink.gif
Not a big deal, IMHO audio processing is more inportant.
post #12 of 20 Old 11-08-2012, 07:51 AM
wagnerc's Avatar
Quoted: 26 Post(s)
I am a big McIntosh fan. They sound great!
wagnerc is offline
post #13 of 20 Old 11-08-2012, 02:21 PM - Thread Starter
MV_Cinema's Avatar
Yes i believe so...but after some reading i think the Denon has more "Dynamics" for Movies and that's what i am looking for.
Buying Denon AVP + POA from USa and using a "Voltage Stabilizer" is bad or they will perform as they should?
post #14 of 20 Old 11-08-2012, 02:36 PM
Selden Ball's Avatar
Quoted: 3046 Post(s)
Liked: 1494
It's best to get a model which is intended for your country.
While a Denon product made for the USA can be used in other countries if you have an appropriate power converter, some of their features won't work. Radio stations use different frequency ranges, for example, and network streaming services are not the same. Also, if the equipment has hardware problems, getting it repaired will be difficult.
Selden
Selden Ball is online now
post #15 of 20 Old 11-08-2012, 03:06 PM - Thread Starter
MV_Cinema's Avatar
Yes you are right...I will try to find those in Europe.
Next month i might travel to Germany so i can get them.
post #16 of 20 Old 12-15-2012, 11:25 AM - Thread Starter
MV_Cinema's Avatar
Why Mcintosh MX-151 doesn't has the "Audissey" and the MX-120 has it and it's cheaper?...eek.gifmad.gif
I think mcintosh should plan to make another Processor....people talk about an MX-160, but i think those are only rumors.... Mcintosh should make a processor that has lots of audio features like the Audissey and video processing.
post #17 of 20 Old 12-15-2012, 12:52 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 370 Post(s)
Liked: 240
For the MX-151, Mac chose to license Lyngdorf's Room Perfect correction. Whether or not it's better than the Audyssey version in the MX-121 is open to discussion.
RUR is offline
post #18 of 20 Old 12-15-2012, 02:32 PM - Thread Starter
MV_Cinema's Avatar
And the fact that the Mc MX-151 can beat the "dead" Denon AVP-A1HDA, is also something to discuss... Let's not mention the video features because video scalers can be bough apart....
post #19 of 20 Old 12-16-2012, 08:10 AM - Thread Starter
MV_Cinema's Avatar
From what i've read the Mcintosh beats the Denon....
post #20 of 20 Old 02-21-2013, 02:29 PM
scanido's Avatar
Quoted: 99 Post(s)
Liked: 33
Had both and the MX151 was easier to setup, manage, and sound was much more natural and less edgy.
See Profile
scanido is offline
