bose acoustimass 5 series 3 and Denon avr 1312 and 1513 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-12-2012, 10:20 PM - Thread Starter
swordfish86's Avatar
I bought new bose acoustimass 5 passive speaker .Acoustimass 5. specification is (10 - 200 watt rms at 4/8 ohm) and now i am looking to buy new denon amplifier/avr receiver for am5. i am confused between denon's two model avr 1312 or avr 1513, which one go best with am5. please help me out.
one more query in my mind please tell me what is difference b/w 4,6,8 ohm in speaker and amplifier/ avr?
swordfish86 is offline
post #2 of 9 Old 11-13-2012, 12:11 AM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Can you return the speakers?
lespurgeon is offline
post #3 of 9 Old 11-13-2012, 05:00 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5499
You would be much better served going up to the next higher model (either 1612 or 1613) both of which use Audyssey MultEQ to EQ the speakers, as well as returning the Bose speakers and replacing them with the Energy Take 5.1 Classic. Review post #2 in each of the XX12 and XX13 Owner's threads linked in my sig to see the difference between the models.
jdsmoothie is offline
post #4 of 9 Old 11-13-2012, 05:02 AM
madspeed's Avatar
you wont find much love for Bose on these forums!!
madspeed is offline
post #5 of 9 Old 11-13-2012, 05:23 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
The 1312 and 1513 are pretty much the same receiver. They will work with the AM5 equally well. The biggest difference between the two is that the 1513 has 1 HDMI input on the front and 3 on back while the 1312 has all 4 HDMI inputs on the back. Power and performance is the same.
Like JD said you should upgrade to the 1612 or 1613 for Audyssey MultEQ calibration.
You Bose are 8 ohm speakers which are the easiest to power. Pretty much any receiver will work with them.
4 ohm speakers are the toughest to drive and you'd need a more capable receiver with a better power supply and high current amps.
Afro GT
afrogt is offline
post #6 of 9 Old 11-13-2012, 09:01 AM - Thread Starter
Thanks guys for your revert. now the question is still around i hv listen bose am5 b4 buying and really love the sound out these speakers. i just want to setup these speakers and avr with my workstation for music listening. now please tell me which model of denon avr 1312 or 1513 is best deal with these AM5.
post #7 of 9 Old 11-13-2012, 09:07 AM
jdsmoothie's Avatar
Liked: 5499
Given a choice of only the 1312 or 1513, then get the newer 1513 as it will allow HDMI Standby pass through to the TV when the AVR is off if there are times you don't want to use the surround speakers (eg. listening to sports or news).
post #8 of 9 Old 11-13-2012, 09:07 AM - Thread Starter
@afrogt can i play my AM5 with denon 1312 at 6 ohm????
post #9 of 9 Old 11-13-2012, 09:09 AM
jdsmoothie's Avatar
Liked: 5499
You don't set the speaker impedance rather it varies based on the frequency of the audio; however, Denon AVRs are designed to work with 6-16 ohm speakers without issue, and can power 4-ohm speakers at lower volumes only.
Denon Avr 1312 Receiver
