denon 3313 vs. Marantz AV 7005 vs, Sherwood R-972 - AVS Forum | Home Theater Discussions And Reviews
Old 11-14-2012, 11:37 AM - Thread Starter
ss396's Avatar
I am finally going to be updating my processor from a B&K 307 receiver to one of these choices. I would appreciate input from any one who has compared 2 of these units head to head. I will be using separate power amps.
ss396 is offline
Old 11-16-2012, 11:41 AM
WestCoastD's Avatar
Quoted: 257 Post(s)
Liked: 96
Check out the AV7005 thread:
http://www.avsforum.com/t/1266725/marantz-av7005
Looks like the AVR-3313CI, which I'm sure is very good, is 7.2 (dual sub's), and uses Audyssey's MultEQ XT EQ system. Also is 4K compatible and more. AV7005 is 7.1 processing, uses Audyssey's MultEQ XT EQ system as well, and is not 4K compatible.
However many seem to prefer having Audyssey's MultEQ XT32.
I have AV7005, still waiting to set-up. But may consider upgrading to AV7701 before permanently installing AV7005.
Don't know anything about the Sherwood [performance] myself. But I think you'll be happy with the AV7005 in comparison to the B&K 307.
WestCoastD is offline
Sherwood Newcastle R 972 , Marantz Av7005 Pre Processor
